MES Customiziations and Mandatory Fields
You can right click in a blank area on the MES screen and your tracing options will be there. I have a BPM or two running that monitor processes from the MES module. Let me know if you need further help.
--- In vantage@yahoogroups.com, "Brian W. Spolarich " <bspolarich@...> wrote:
> We have that option checked. It doesn't make the reasons mandatory.
> Brian W. Spolarich ~ Manager, Information Services ~ Advanced Photonix /
> Picometrix
> bspolarich@... ~ 734-864-5618 ~
> www.advancedphotonix.com
> Of Bruce
> Sent: Friday, March 20, 2009 12:25 AM
> To: vantage@yahoogroups.com
> Subject: RE: [Vantage] MES Customiziations and Mandatory Fields
> The short answer to your question if you are on 8.03.4xx - is go to
> company
> config->modules->Materials->inventory and check the box -use inventory
> adjustment reasons.
> sorry don't have an answer on manditory ..
> Bruce
> _____
> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
> Behalf Of
> Brian W. Spolarich
> Sent: Thursday, March 19, 2009 2:26 PM
> Subject: [Vantage] MES Customiziations and Mandatory Fields
> I want to make certain fields mandatory in some of the MES screens in
> 8.03.405. For example, in Issue Misc. Material, I want to make sure
> folks supply a ReasonCode.
> I added a rule via the Rule Wizard:
> Rule: ReasonCode is Null
> View: IR
> Field: ReasonCode
> Condition: Equals
> Value: Constant: NullValue
> Action:
> View: IR
> Field: ReasonCode
> SettingStyles: Mandatory
> I update the code and it builds without error. Vantage does bark at
> me about the fact that the Mandatory setting style isn't completely
> supported, I should test it, etc. etc.
> However when I submit the transaction, nothing happens. I can change
> the Setting Style to "Error" and it shows the ReasonCode field in Red
> until I put something in there, so the only difference is the
> SettingStyle.
> Anyone been able to make "Mandatory" work?
> Picometrix
> bspolarich@advanced <mailto:bspolarich%40advancedphotonix.com>
> photonix.com
> <mailto:bspolarich@advanced <mailto:bspolarich%40advancedphotonix.com>
> photonix.com> ~ 734-864-5618 ~
> www.advancedphotonix.com <http://www.advanced
> <http://www.advancedphotonix.com> photonix.com>
View: IR
Field: ReasonCode
Condition: Equals
Action:
View: IR
Field: ReasonCode
SettingStyle.
Picometrix
bspolarich@...
<mailto:bspolarich@...> ~ 734-864-5618 ~
www.advancedphotonix.com <http://www.advancedphotonix.com>
ive never found that approach to be very effective. A BPM would be a good tool to control this. We have many of those monitoring critical fields that will not allow the user to continue without filling in the information.
> View: IR
> Field: ReasonCode
> Condition: Equals
> Action:
> View: IR
> Field: ReasonCode
> SettingStyle.
> Picometrix
> bspolarich@...
The short answer to your question if you are on 8.03.4xx - is go to company
adjustment reasons.
Bruce
_____
Brian W. Spolarich
View: IR
Field: ReasonCode
Condition: Equals
Action:
View: IR
Field: ReasonCode
SettingStyle.
Picometrix
bspolarich@advanced <mailto:bspolarich%40advancedphotonix.com> photonix.com
Picometrix
Of Bruce
company
adjustment reasons.
Bruce
_____
Behalf Of
Brian W. Spolarich
View: IR
Field: ReasonCode
Condition: Equals
Action:
View: IR
Field: ReasonCode
SettingStyle.
Picometrix
photonix.com
I thought of that route, but I wasn't sure how to identify the BO
method when using MES since I'm not aware of a way to turn on tracing in
MES.
-bws
Picometrix
Of rob.bucek
Sent: Thursday, March 19, 2009 4:59 PM
Subject: [Vantage] Re: MES Customiziations and Mandatory Fields
information.
> View: IR
> Field: ReasonCode
> Condition: Equals
> Action:
> View: IR
> Field: ReasonCode
> SettingStyle.
> Picometrix
> bspolarich@...
