MES Labor Cost Bug - Vantage 8.03.409C
It is supposed to be corrected in 606, I don't have the SCR number.
A Mercer Sisson
Systems Manager - Insaco Inc
ams@...
215-536-3500 x 523
267-733-0641 (direct)
215-285-0332 (cell)
--- In vantage@yahoogroups.com, "pcivantage" <vantagegroup@...> wrote:
> Mercer;
> We have seen this once we moved to 8.03.409C also, through 9.05.604A and knew it was a bug but did not know why. Nice detective work!
> We are readying to move to 9.05.606 shortly, so I hope it is fixed? I did not see it in the SCR's on the SPK Release notes or did I miss it?
> Regards,
> Georeg Hicks
> Pacific Consolidated Industries
> --- In vantage@yahoogroups.com, "A Mercer Sisson" <onelist@> wrote:
> > We have come across a bug in the MES system that can cause major
> > problems with job costing in certain circumstances. This bug affects
> > Vantage 409C and possibly all versions of E9 before 9.05.606.
> > If you use MES and allow operators to override the scheduled resource,
> > be aware that the system will replace the LaborRate from the EmpBasic
> > table with that from the selected Resource.
> > This has caused a very significant undervaluing of our Labor Costs for
> > the 9 months since we upgraded to 409C to the tune of almost $900K,
> > since in our case the primary operation detail record is always tied to
> > a machine resource which all have a zero labor rate. Since we use
> > vantage scheduling very heavily we always have at least two operation
> > detail records, one for machines and one for labor. All of our labor
> > cost estimates come from the second (non-primary) op detail record.
> > Because Applied Labor is not used in our P&L (we use actual labor costs
> > on the P&L) the impact is really on WIP value, scrap value and
> > inventory.
> > I developed a BPM which fixes the problem on the fly and you can edit
> > the laborrate on UNPOSTED labor details by customizing the LaborEntry
> > screen. Epicor has also provided us a corrected labor.r.
> > So if you use MES and allow override, please look carefully at the
> > LaborRate field on the LaborDtl records.
> > Mercer Sisson
> > 215-536-3500
inventory.
Mercer Sisson
215-536-3500
Mercer;
Regards,
Georeg Hicks
> inventory.
> Mercer Sisson
> 215-536-3500
