MES Lot # and SN reporting from MES v8.03.40x
That's very interesting. Similarly we record heat tracking numbers for
raw materials at receipt entry like you. We are slightly blessed in
that we do not currently have any regulatory requirements for
traceability but several of our customers require that we can trace
components and/or assemblies to a particular receipt of raw material
should there be an issue. While we do not serialize we record at the
job level what particular heat number (for plate steel) was used in that
process (typically laser, plasma, oxy-fuel). Service connect helps us
with this in that it integrates vantage with our third party nesting
software which also has heat/lot tracking and is synchronized with our
inventory in vantage. Are you using stock serialization from vantage or
did you come up with a unique solution for that as well?
Rob Bucek
Manufacturing Engineer
PH: 715-284-5376 ext 311
FAX: 715-284-4084
<http://www.dsmfg.com/>
(Click the logo to view our site)
Of Lee Ingalls
Sent: Tuesday, March 31, 2009 12:37 PM
Subject: RE: [Vantage] Re: MES Lot # and SN reporting from MES v8.03.40x
Rob,
My scenario is:
Our raw material receipts have lot numbers entered at receipt entry;
then
when we mix the raw materials we have to create a new batch/lot # for
regulatory purposes traceable back to original lots. On top of that when
that mixed batch/lot is used to make a component -- that component is
serialized and we need to record the SN of the component when the qty
completed, scrap, etc is entered through MES.
Thanks for your insights.
Regards, Lee
E. Lee Ingalls III
Andronaco Industries
Pureflex|Ethylene|Nil-Cor|Hills-McCanna|Ramparts
lingalls@... <mailto:lingalls%40andronaco.com>
616.554.4600 x107
Behalf Of
Rob Bucek
Sent: Tuesday, March 31, 2009 1:00 PM
Vantage does have native lot control functionality but it also comes
with some baggage that may be more weight than benefit for some. In our
case it was that when lot tracking (such as using lot number to track
heat numbers or PED with steel) you can no longer issue that item by
backflush method. So we developed our own low budget method.
Rob Bucek
FAX: 715-284-4084
<http://www.dsmfg.com/ <http://www.dsmfg.com/> >
Behalf
Of Lynn
Sent: Tuesday, March 31, 2009 11:52 AM
Subject: [Vantage] Re: MES Lot # and SN reporting from MES v8.03.40x
Rob B. gave me a good suggestion last week on this group thread:
"[Vantage] Lot Numbers in reported MES quantities for medical products"
It does require a MES customization plus the use of a UD table.
Lynn
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
<mailto:vantage%40yahoogroups.com> ,
"budelee23" <lingalls@...> wrote:
> Before I start another customization... does anyone have a method of
recording Lot Numbers and or Serial Numbers through MES?
> Regards,
> Lee Ingalls
Before I start another customization... does anyone have a method of recording Lot Numbers and or Serial Numbers through MES?
Regards,
Lee Ingalls
Lynn
> Regards,
> Lee Ingalls
Rob Bucek
FAX: 715-284-4084
Of Lynn
Lynn
> Regards,
> Lee Ingalls
Rob,
My scenario is:
Our raw material receipts have lot numbers entered at receipt entry; then
Regards, Lee
E. Lee Ingalls III
lingalls@...
616.554.4600 x107
Rob Bucek
Rob Bucek
FAX: 715-284-4084
Of Lynn
Lynn
> Regards,
> Lee Ingalls
