I thought the OP was between 32bit and 64bit and did not notice mention
of Standard or Enterprise. Yes you need Enterprise or Datacenter
editions. You do not need 64 bit to access more than 4GB of memory.
You may want to use the /PAE switch if you have 4GB of memory and cannot
see all of it (you may never see all of it depending on how much is
reserved for hardware).
I've also heard mentioned if you have more than 16GB then you may want
to disable the /PAE switch, can't seem to find a link supporting that
though.
Jim
vantage@yahoogroups.com [mailto:
vantage@yahoogroups.com] On Behalf
Of Ari Footlik
Sent: Wednesday, January 14, 2009 2:28 PM
To:
Subject: RE: [Vantage] Re: MES Menu Customization 803.406A
Jim -
In that article, it specifically mentions "Enterprise Edition" and
"Datacenter Edition." It doesn't mention the standard edition at all.
Are you sure this is a valid configuration setting in the standard
edition?
--Ari
vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
[mailto:
vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
Behalf
Of Jim Mediger
Sent: Wednesday, January 14, 2009 2:00 PM
To:
You need to add the /PAE switch to the boot.ini to address more than 4
GB of ram on 32bit server system.
http://technet.microsoft.com/en-us/library/cc758228.aspx
http://technet.microsoft.com/en-us/library/cc758228.aspx>
Jim
[mailto:
Behalf
Of Ari Footlik
Sent: Wednesday, January 14, 2009 1:49 PM
To:
If you're not running on 64-bit, how do you get your system memory up
into the teens? Isn't 32-bit Server limited to 8GB RAM?
--Ari
[mailto:
Behalf
Of lsbestinc
Sent: Wednesday, January 14, 2009 11:10 AM
To:
Subject: [Vantage] Re: MES Menu Customization 803.406A
Ari,
2003 x64 has not tested well with Vantage. When I installed vantage
on a 64bit machine I had a lot of problems. I called Vantage on why I
was having these issues, without telling them I was using 64bit, and
they were stumped untill they looked at my operating system.
To make a long story short I scrubbed the whole thing, reloaded
Vantage on 32bit and never had a problem.
Jonathan Lang
Oil Rite Corporation
Sr. Network Administrator
Ph: (920) 682-6173 Ext: 126
Fax: (920) 682-7699
--- In
<mailto:vantage%40yahoogroups.com> , "Ari
Footlik" <ari@...> wrote:
> Jonathan -
> 1) One user - the MES station itself. We're a couple weeks away
from
> implementing the upgrade from v6.
> 2) DB (less than 1GB in size) is freshly upgraded from v6. Server
is
> dedicated to Vantage/Progress, has 8GB RAM with as 12GB pagefile on
a
> quad 3.0 GHz Xeon server. We only own 25 seats + 5 MES, so max is
30
> users. Windows Server 2003x64 is installed on a 32GB RAID-1 drive
using
> 15k-rpm SAS disks; database is stored on a 67GB RAID-1 drive using
> 15k-rpm SAS disks. I haven't tweaked RWIN, but we'll look into it.
> I don't think our hardware spec is that out of line. Plus, we
really
> don't *need* to use the pull-down style boxes for Assembly and
> Operation, since we use the barcodes to enter them, so that might
be an
> easy fix that fits our needs most appropriately...
> --Ari
[mailto:
Behalf
> Of Jonathan Lang
> Sent: Wednesday, January 14, 2009 9:50 AM
> Subject: [Vantage] MES Menu Customization 803.406A
> Ari,
> I would look at the Hardware first. These are the questions I would
ask:
> 1) How many users are hitting my DB. This includes Citrix and VMWare
> 2) Is my DB up to snuff:
> 2a) How old is my DB?
> 2b) How much RAM do I have? (16GB or more)
> 2c) How many processors do I have running? (For every 10 people 1
> processor)
> 2d) Do I have other programs running on my DB other than Vantage?
(One
> would hope not)
> 2e) What is your RWIN size? Do you have it at the largest setting?
> (Small tweek)
> 2f) what is the size of your pagefile? (HUGE)
> There are more things to look at but this is a great guide I have
used
> and expanded on:
> http://technet.microsoft.com/en-us/library/bb463205.aspx
http://technet.microsoft.com/en-us/library/bb463205.aspx>
http://technet.microsoft.com/en-us/library/bb463205.aspx> >
> <http://technet.microsoft.com/en-us/library/bb463205.aspx
http://technet.microsoft.com/en-us/library/bb463205.aspx> > >
> I would start there and work my way to software.
> Jonathan Lang
> Fax: (920) 682-7699
