MES Performance Issue
If we have multiple users in MES with a 24 hour/ 5 days a week operation, will this clock out impact performance? At any give time you could have up to 10 users in MES and they do clock out at the end of their shift but system still seems slow. Does having employees not clocking out at the end of each day impact performance more than the number of users clocked in the system? For example, we could have five users not clocked out from previous days but up to 20 users clocked in. If we clocked out those five users, would this help with performance on the 20 users?
--- In vantage@yahoogroups.com, "jerrydwein" <jerry@...> wrote:
> Hi Kristin/Brian,
> You identified the problem. Some of our users were not hitting the clock out button at the end of the day. As soon as I clocked them out, the performance improved dramatically. We're now down to a 1-2 second login times again. Thank you very much for the input.
> Jerry
> --- In vantage@yahoogroups.com, "Kirstin Brandt" <kirstin.brandt@> wrote:
> > I read the scenario you listed below and had the same question as Brian. Do you clock out at the end of each day? This is different than completing the operation when ending activity or logging out. Check the Clocked In date next to the picture. It should have today's date. You can also check by pulling up the Labor Entry record for one of the employees having a problem. After you enter their employee ID, click on the Payroll Date. The search button should return one record for every day the employee worked.
> > If they are indeed clocking out at the end of the day, do you regularly close your jobs and capture WIP?
> > --- In vantage@yahoogroups.com, "jerrydwein" <jerry@> wrote:
> > > All of our users clock out of all operations they complete. We verify that their queue only contains operations they are currently working on. Since we track job status, and what operations on a job are completed, we have to have them correctly complete the operations they start.
> > > Thanks, Jerry
> > > --- In vantage@yahoogroups.com, "Brian Roberts" <broberts@> wrote:
> > > > To emphasis one word below: CLOCK out instead of just log out.
> > > > Otherwise a query intended to pick up just today's jobs from the
> > > > database is returning many months' worth of jobs.
> > > > Brian.
> > > > From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf
> > > > Of bw2868bond
> > > > Sent: Tuesday, June 19, 2012 6:13 PM
> > > > To: vantage@yahoogroups.com
> > > > Subject: [Vantage] Re: MES Performance Issue
> > > > I have no experience with this personally, but I recall seeing similar
> > > > threads in this group. AFAIK MES login sends job data that the user is
> > > > Active in. I seem to remember if they are clocking out of jobs properly
> > > > then the amount data reduces.
> > > > Again, this is what I remember reading......
> > > > --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ,
> > > > > I have additional information, we are on Epicor 904.507a. We used
> > > > Process Monitor and Wireshark to find out that the server is sending the
> > > > client a serious amount of data, for some users this is about 5.4M of
> > > > data. It appears the heavier the MES user is, the more data that is
> > > > accumulated and resent to the client from the server. Once a threshold
> > > > is hit, the client hickups on the packets and it takes it a couple of
> > > > minutes to recover. It then retreieves the remaining data.
> > > > > In looking at the data that is being sent to the MES client, it
> > > > appears to be all of the jobs that user has ever touched. What in the
> > > > world is Epicor doing sending all of this data to the MES client when it
> > > > isn't used for anything that I can see?
> > > > > My question is, how can we stop the transfer of this data? is there
> > > > something we can do to flush the system so it no longer sends it to the
> > > > client? In our Options Menu we do not have a way of flushing the Client
> > > > Cache, is there another way of doing this?
> > > > > Any help we be greatly appreciated, we have users who are now
> > > > experiencing 3 minute logins and 2-3 minutes to load the job screen.
> > > > > Thanks, Jerry
> > > > > > All systems using MES originally didn't have performance issues. As
> > > > users started bar code scanning more and more, the shop user accounts
> > > > started slowing down.
> > > > > > We have several shop user accounts that do not have any performance
> > > > issues at all. But, we have a significant number that do, even on the
> > > > same machine.
> > > > > > There appears to be some cache that is not being cleared or
> > > > something related.
> > > > > > Thanks, Jerry
> > > > John Driggers <waffqle@> wrote:
> > > > > > > It sounds like what you've got are performance issues rather than
> > > > a bug.
> > > > > > > Try the same thing on one of your best workstations, or even
> > > > directly on
> > > > > > > the server. If it runs fine there, you may just need to get a
> > > > better
> > > > > > > machine for your MES workstation.
> > > > > > > If it's slow everywhere, it's probably the server/network.
> > > > > > > If this is a recent development, check for new BPMs,
> > > > customizations, BAMs,
> > > > > > > etc.
> > > > > > > *John Driggers*
> > > > > > > *High End Dev, System Design, Profit Drinking*
> > > > > > > **:: 904.404.9233*
> > > > > > > *:: waffqle@*
> > > > > > > *:: NO FAXES*
> > > > > > > On Wed, Jun 13, 2012 at 1:55 PM, jerrydwein <jerry@> wrote:
> > > > > > > > Hi Everyone,
> > > > > > > > We have a single login account that we use to Login to Epicor
> > > > for shop
> > > > > > > > personnel. Then each of the shop personnel has their own
> > > > employee login's
> > > > > > > > to log into MES. Here is a typical scenario with its problems:
> > > > > > > > Step by Step issue that Mike sees:
> > > > > > > > 1. Mike logs into MES using Shop user
> > > > > > > > 2. Mike then logs in with his shop account
> > > > > > > > a. It takes a couple minutes to show up...it hangs and comes up
> > > > > > > > 3. Mike then starts a job
> > > > > > > > a. This again takes a couple minutes before coming up and shows
> > > > the app is
> > > > > > > > non responsive for that period of time.
> > > > > > > > 4. Mike then fills in the fields
> > > > > > > > a. This part seems to function normally
> > > > > > > > 5. Mike then Completes the job
> > > > > > > > a. This functions normally as well.
> > > > > > > > (**NOTE: He seems to see the lag, and like most users, at
> > > > logging in and
> > > > > > > > starting jobs...the other tasks seem to be normal.**)
> > > > > > > > Does anyone know what can be causing this problem.
> > > > > > > > Thanks, Jerry
> > > > > > > [Non-text portions of this message have been removed]
Hi Everyone,
We have a single login account that we use to Login to Epicor for shop personnel. Then each of the shop personnel has their own employee login's to log into MES. Here is a typical scenario with its problems:
a. It takes a couple minutes to show upÂ…it hangs and comes up
a. This again takes a couple minutes before coming up and shows the app is non responsive for that period of time.
(**NOTE: He seems to see the lag, and like most users, at logging in and starting jobsÂ…the other tasks seem to be normal.**)
Thanks, Jerry
It sounds like what you've got are performance issues rather than a bug.
Try the same thing on one of your best workstations, or even directly on
the server. If it runs fine there, you may just need to get a better
If this is a recent development, check for new BPMs, customizations, BAMs,
etc.
*John Driggers*
**:: 904.404.9233*
*:: waffqle@...*
*:: NO FAXES*
On Wed, Jun 13, 2012 at 1:55 PM, jerrydwein <jerry@...> wrote:
> Hi Everyone,
> a. It takes a couple minutes to show up�it hangs and comes up
> starting jobs�the other tasks seem to be normal.**)
> Thanks, Jerry
Id follow johns suggestion on running MES directly on the server itself. That can tell you a couple of things... performance related to vantage, and it also isolates your infrastructure, switches, cables, firewalls, etc... don't under estimate the impact those can have.
Rob Bucek
Production Control Manager
PH: (715) 284-5376 ext 311
Mobile: (715)896-0590
FAX: (715)284-4084
(Click the logo to view our site)
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of John Driggers
Sent: Wednesday, June 13, 2012 2:15 PM
Subject: Re: [Vantage] MES Performance Issue
Try the same thing on one of your best workstations, or even directly on the server. If it runs fine there, you may just need to get a better machine for your MES workstation.
If this is a recent development, check for new BPMs, customizations, BAMs, etc.
*John Driggers*
**:: 904.404.9233*
*:: waffqle@...*
*:: NO FAXES*
> Hi Everyone,
> and starting jobs...the other tasks seem to be normal.**)
> Thanks, Jerry
We're having this same issue on a select number of systems and haven't been
able to track it down. I can have two computers right next to eachother,
identical models, logged into MES as the same user, plugged into port right
next to each other on a gigabit switch. Computer A will fly through
everything in MES all the time, Computer B will have issues where when MES
has been sitting for sometime, it seems to stop responding for 10-15
seconds after everything you do. I've tested all sorts of network
possibilities and looked at whats running on both computers and can't find
the culprit...
--John Kreger
> Rob Bucek
> FAX: (715)284-4084
> Of John Driggers
> etc.
> *John Driggers*
> **:: 904.404.9233*
> *:: waffqle@...*
> *:: NO FAXES*
> > Hi Everyone,
> > Thanks, Jerry
Just out of curiosity, have any of you attempted to rename the Client803
folder and re-install a fresh client?
John Kreger
Sent: Wednesday, June 13, 2012 6:36 PM
has been sitting for sometime, it seems to stop responding for 10-15 seconds
after everything you do. I've tested all sorts of network possibilities and
looked at whats running on both computers and can't find the culprit...
--John Kreger
firewalls, etc...
> Rob Bucek
> FAX: (715)284-4084
> BAMs, etc.
> *John Driggers*
> **:: 904.404.9233*
> *:: waffqle@...*
> *:: NO FAXES*
> > Hi Everyone,
problems:
> > Thanks, Jerry
No virus found in this message.
Checked by AVG - www.avg.com
Version: 2012.0.2180 / Virus Database: 2433/5068 - Release Date: 06/13/12
Sure it doesn't hurt anything./
*Jose C Gomez*
*Software Engineer*
*checkout my new blog <http://www.usdoingstuff.com> *
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
On Thu, Jun 14, 2012 at 8:52 AM, Vic Drecchio
> Of
> John Kreger
> seconds
> Thanks,
> --John Kreger
> firewalls, etc...
> > Rob Bucek
> > FAX: (715)284-4084
> > BAMs, etc.
> > *John Driggers*
> > **:: 904.404.9233*
> > *:: waffqle@...*
> > *:: NO FAXES*
> > > Hi Everyone,
> problems:
> > > Thanks, Jerry
Try swapping Ethernet cables and see if the slowdown changes workstations...
Chris Wineinger
ERP Specialist
Interior Systems Inc
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > Of
> > John Kreger
> > seconds
> > Thanks,
> > --John Kreger
> > firewalls, etc...
> > > Rob Bucek
> > > FAX: (715)284-4084
> > > BAMs, etc.
> > > *John Driggers*
> > > **:: 904.404.9233*
> > > *:: waffqle@...*
> > > *:: NO FAXES*
> > > > Hi Everyone,
> > problems:
> > > > Thanks, Jerry
I beleive we found an issue with MES that it was trying to go to the internet, but we have the internet access turned off for these stations. Once we stopped it from trying to go to the internet it stopped hanging up and proceeded right away.
Do your stations have internet access?
Brad Boes
Metalworks
> Chris Wineinger
> ERP Specialist
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@
> > > Of
> > > John Kreger
> > > seconds
> > > Thanks,
> > > --John Kreger
> > > firewalls, etc...
> > > > Rob Bucek
> > > > FAX: (715)284-4084
> > > > BAMs, etc.
> > > > *John Driggers*
> > > > **:: 904.404.9233*
> > > > *:: waffqle@*
> > > > *:: NO FAXES*
> > > > > Hi Everyone,
> > > problems:
> > > > > Thanks, Jerry
I recall a thread about this being a .Net thing. I am pretty sure there is a registry hack to prevent the internet call and wait for time-out....
> Brad Boes
> Metalworks
> > Chris Wineinger
> > ERP Specialist
> > > *Jose C Gomez*
> > > *Software Engineer*
> > > E: jose@
> > > > Of
> > > > John Kreger
> > > > seconds
> > > > Thanks,
> > > > --John Kreger
> > > > firewalls, etc...
> > > > > Rob Bucek
> > > > > FAX: (715)284-4084
> > > > > BAMs, etc.
> > > > > *John Driggers*
> > > > > **:: 904.404.9233*
> > > > > *:: waffqle@*
> > > > > *:: NO FAXES*
> > > > > > Hi Everyone,
> > > > problems:
> > > > > > Thanks, Jerry
This sounds like EXACTLY the issue we're having. When I took the internet
away from a few of our MES workstations it made MES crawl... Does anyone
know what to do to fix this?
--John
> > Brad Boes
> > Metalworks
> workstations...
> > > Chris Wineinger
> > > ERP Specialist
> > > > *Jose C Gomez*
> > > > *Software Engineer*
> > > > E: jose@
> Client803
> Behalf
> > > > > Of
> > > > > John Kreger
> haven't been
> eachother,
> port right
> when MES
> 10-15
> > > > > seconds
> possibilities and
> culprit...
> > > > > Thanks,
> > > > > --John Kreger
> itself.
> cables,
> > > > > firewalls, etc...
> > > > > > Rob Bucek
> > > > > > FAX: (715)284-4084
> On
> than a bug.
> directly
> customizations,
> > > > > > BAMs, etc.
> > > > > > *John Driggers*
> > > > > > **:: 904.404.9233*
> > > > > > *:: waffqle@*
> > > > > > *:: NO FAXES*
> > > > > > > Hi Everyone,
> for
> with its
> > > > > problems:
> shows the
> logging in
> > > > > > > Thanks, Jerry
> must
> access.
> Builder
> must have
> Builder and
> 06/13/12
> 06/13/12
I can have our IT person contact you on Monday with the specifics. She is on vacation today.
Brad Boes
Metalworks
> Thanks,
> --John
> > > Brad Boes
> > > Metalworks
> > workstations...
> > > > Chris Wineinger
> > > > ERP Specialist
> > > > > *Jose C Gomez*
> > > > > *Software Engineer*
> > > > > E: jose@
> > Client803
> > Behalf
> > > > > > Of
> > > > > > John Kreger
> > haven't been
> > eachother,
> > port right
> > when MES
> > 10-15
> > > > > > seconds
> > possibilities and
> > culprit...
> > > > > > Thanks,
> > > > > > --John Kreger
> > itself.
> > cables,
> > > > > > firewalls, etc...
> > > > > > > Rob Bucek
> > > > > > > FAX: (715)284-4084
> > On
> > than a bug.
> > directly
> > customizations,
> > > > > > > BAMs, etc.
> > > > > > > *John Driggers*
> > > > > > > **:: 904.404.9233*
> > > > > > > *:: waffqle@*
> > > > > > > *:: NO FAXES*
> > > > > > > > Hi Everyone,
> > for
> > with its
> > > > > > problems:
> > shows the
> > logging in
> > > > > > > > Thanks, Jerry
> > must
> > access.
> > Builder
> > must have
> > Builder and
> > 06/13/12
> > 06/13/12
Here is what you do to the client mfgsys.exe.config file on each workstation that does not have internet access:
1. Navigate to "c:\Program files\Epicor Software\Epicor905\client\mfgsys.exe.config".
2. Edit this file by opening it in notepad.
3. Insert the line below between the two runtimes:
<generatePublisherEvidence enabled="false"/>
4. Save the file.
Any questions please let me know. This is something simple we did that made a big difference on our shop floor machines.
Jill Schoedel
Metalworks
> Brad Boes
> Metalworks
> > Thanks,
> > --John
> > > > Brad Boes
> > > > Metalworks
> > > workstations...
> > > > > Chris Wineinger
> > > > > ERP Specialist
> > > > > > *Jose C Gomez*
> > > > > > *Software Engineer*
> > > > > > E: jose@
> > > Client803
> > > Behalf
> > > > > > > Of
> > > > > > > John Kreger
> > > haven't been
> > > eachother,
> > > port right
> > > when MES
> > > 10-15
> > > > > > > seconds
> > > possibilities and
> > > culprit...
> > > > > > > Thanks,
> > > > > > > --John Kreger
> > > itself.
> > > cables,
> > > > > > > firewalls, etc...
> > > > > > > > Rob Bucek
> > > > > > > > FAX: (715)284-4084
> > > On
> > > than a bug.
> > > directly
> > > customizations,
> > > > > > > > BAMs, etc.
> > > > > > > > *John Driggers*
> > > > > > > > **:: 904.404.9233*
> > > > > > > > *:: waffqle@*
> > > > > > > > *:: NO FAXES*
> > > > > > > > > Hi Everyone,
> > > for
> > > with its
> > > > > > > problems:
> > > shows the
> > > logging in
> > > > > > > > > Thanks, Jerry
> > > must
> > > access.
> > > Builder
> > > must have
> > > Builder and
> > > 06/13/12
> > > 06/13/12
All systems using MES originally didn't have performance issues. As users started bar code scanning more and more, the shop user accounts started slowing down.
We have several shop user accounts that do not have any performance issues at all. But, we have a significant number that do, even on the same machine.
There appears to be some cache that is not being cleared or something related.
Thanks, Jerry
> etc.
> *John Driggers*
> **:: 904.404.9233*
> *:: waffqle@...*
> *:: NO FAXES*
> > Hi Everyone,
> > Thanks, Jerry
I have additional information, we are on Epicor 904.507a. We used Process Monitor and Wireshark to find out that the server is sending the client a serious amount of data, for some users this is about 5.4M of data. It appears the heavier the MES user is, the more data that is accumulated and resent to the client from the server. Once a threshold is hit, the client hickups on the packets and it takes it a couple of minutes to recover. It then retreieves the remaining data.
In looking at the data that is being sent to the MES client, it appears to be all of the jobs that user has ever touched. What in the world is Epicor doing sending all of this data to the MES client when it isn't used for anything that I can see?
My question is, how can we stop the transfer of this data? is there something we can do to flush the system so it no longer sends it to the client? In our Options Menu we do not have a way of flushing the Client Cache, is there another way of doing this?
Any help we be greatly appreciated, we have users who are now experiencing 3 minute logins and 2-3 minutes to load the job screen.
Thanks, Jerry
> Thanks, Jerry
> > etc.
> > *John Driggers*
> > **:: 904.404.9233*
> > *:: waffqle@*
> > *:: NO FAXES*
> > > Hi Everyone,
> > > Thanks, Jerry
Sounds normal to me. Your key phrase is this - As users started bar code scanning more and more, the shop user accounts started slowing down.
.NET is designed to have disconnected datasets, depending on how the client was programmed, it could be pulling over the entire table/query set but only using a small fraction of it and only updating what it needs to, then the garbage collector cleans it up (when it works). Interesting to see if your RAM usage on your MES clients start climbing as soon as the users is logging into the shop account and it stops responding. If it is, it's doing exactly the way it was designed, datasets are stored in memory as they're consumed. I'm thinking your only option is to get beefier machines and more bandwidth or go for a higher end terminal server to handle the load. You can bring up the issue with Epicor but you won't get anywhere quickly if ever. Why are you concerned about 5.4M of data going to an end unit? Are you running 8088 systems and token ring or something?
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of jerrydwein
Sent: Tuesday, June 19, 2012 2:40 PM
Thanks, Jerry
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, "jerrydwein" <jerry@...<mailto:jerry@...>> wrote:
> Thanks, Jerry
> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, John Driggers <waffqle@> wrote:
> > etc.
> > *John Driggers*
> > **:: 904.404.9233*
> > *:: waffqle@*
> > *:: NO FAXES*
> > > Hi Everyone,
> > > Thanks, Jerry
Technical information contained in this e-mail may be controlled by the United States Government, Department of State, International Traffic and Arms Regulations (ITAR) (22 CFR 120-130) which requires an export license prior to sharing with foreign persons. Lacking such license, ITAR technical data is limited to U.S. persons only. It is the responsibility of the organization and the individual in control of this data to abide by U.S. Export Laws. If you are not a U.S. person take no further action with this e-mail and contact sender immediately.
I have no experience with this personally, but I recall seeing similar threads in this group. AFAIK MES login sends job data that the user is Active in. I seem to remember if they are clocking out of jobs properly then the amount data reduces.
> Thanks, Jerry
> > Thanks, Jerry
> > > etc.
> > > *John Driggers*
> > > **:: 904.404.9233*
> > > *:: waffqle@*
> > > *:: NO FAXES*
> > > > Hi Everyone,
> > > > Thanks, Jerry
In our case, the users queue is empty but epicor is still sending the data. If I can kill this large data dump from the server it would resolve my packet loss problem.
Thanks, Jerry
> > Thanks, Jerry
> > > Thanks, Jerry
> > > > etc.
> > > > *John Driggers*
> > > > **:: 904.404.9233*
> > > > *:: waffqle@*
> > > > *:: NO FAXES*
> > > > > Hi Everyone,
> > > > > Thanks, Jerry
When looking at the packets, the MES client always starts dropping packets about half way through the data transfer from the server. I brought up the 5.4MB issue to give a perspective on how much data was being moved. There is no reason the client should be having issues with such as small amount of data.
We are using a dual 2.8GHz processor with 4GB of Memory, if the MES Client can't operate within that hardware configuration then it is pretty much a worthless application. I wouldn't even consider getting bigger machines for the entire organization, I would consider dumping Epicor first.
Yes, the memory for the client jumps up during the login process then holds during the lockup time, peaks during the final data transfer. After the login is complete memory may drop as much as 50% for low usage users to just 10% for high usage users. When they log off, memory usage goes down significantly.
There are a lot of jobs in the data being sent to the MES client. Since their production queue is empty, and the user is done with all of these jobs and the operations have been completed, it makes no sense to me why the MES client would even need this information. I also don't understand why the MES Client would be choking on this data. Since I have no control on how the MES Client was written, I was hoping someone would have some idea on how to get the server to quit sending this data to the MES Client. I don't want to flush the labor data from the database since we need it for historical purposes.
Any help on understanding how to solve this would be greatly appreciated.
Thanks, Jerry
> Thanks, Jerry
> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, "jerrydwein" <jerry@<mailto:jerry@>> wrote:
> > Thanks, Jerry
> > > etc.
> > > *John Driggers*
> > > **:: 904.404.9233*
> > > *:: waffqle@*
> > > *:: NO FAXES*
> > > > Hi Everyone,
> > > > Thanks, Jerry
I just ran the MES Client on the Server using a users account that has the problem we've been working on. It is has dual quad processors running at 2.8GHz and 16GB of RAM. While running Process Explorer I can see that there is plenty of CPU and RAM remaining. We are running a 1GB Network and duing all of our tests, the network has not been an issue. The delay we are having with this user is the same as running it on the workstation. It takes about 1 minute and 50 seconds to login.
Thanks, Jerry
> Thanks, Jerry
> > Thanks, Jerry
> > > Thanks, Jerry
> > > > etc.
> > > > *John Driggers*
> > > > **:: 904.404.9233*
> > > > *:: waffqle@*
> > > > *:: NO FAXES*
> > > > > Hi Everyone,
> > > > > Thanks, Jerry
