MES screen - hiding the shift popup screen
I've done this. You'll have to change the GUIDs on the
GetNativeControlReference statements below.
See below:
'// Custom VB.NET code for ShiftSelect
'// Created: 3/27/2007 2:10:30 PM
Imports System
Imports System.Data
Imports System.Diagnostics
Imports System.Windows.Forms
Imports System.ComponentModel
Imports Microsoft.VisualBasic
Imports Epicor.Mfg.UI
Imports Epicor.Mfg.UI.FrameWork
Imports Epicor.Mfg.UI.ExtendedProps
Imports Epicor.Mfg.UI.FormFunctions
Imports Epicor.Mfg.UI.Customization
Imports Epicor.Mfg.UI.Adapters
Imports Epicor.Mfg.UI.Searches
Imports Epicor.Mfg.BO
Module Script
'// ** Wizard Insert Location - Do Not Remove 'Begin/End Wizard
Added Module Level Variables' Comments! **
'// Begin Wizard Added Module Level Variables **
Private WithEvents txtShift As EpiTextBox
Private WithEvents btnOK As EpiButton
'// End Wizard Added Module Level Variables **
'// Add Custom Module Level Variables Here **
Sub InitializeCustomCode()
'// ** Wizard Insert Location - Do not delete 'Begin/End Wizard
Added Variable Intialization' lines **
'// Begin Wizard Added Variable Intialization
'// End Wizard Added Variable Intialization
'// Begin Custom Method Calls
'// End Custom Method Calls
End Sub
Sub DestroyCustomCode()
Added Object Disposal' lines **
'// Begin Wizard Added Object Disposal
'// End Wizard Added Object Disposal
'// Begin Custom Code Disposal
'// End Custom Code Disposal
End Sub
Private Sub ShiftSelect_Load(ByVal sender As object, ByVal args As
EventArgs) Handles ShiftSelect.Load
'// Add Event Handler Code
txtShift =
CType(csm.GetNativeControlReference("521b37e5-fc02-4fec-b1f2-39989c016e4
5"), EpiTextBox)
btnOK =
CType(csm.GetNativeControlReference("ba471f56-bb12-4c65-a829-0777546ca44
e"), EpiButton)
For Each ctl As Control In ShiftSelect.Controls
If (ctl.Name = "btnOK") Then
btnOK = ctl
ElseIf (ctl.Name = "txtShift") Then
txtShift = ctl
End If
Next
End Sub
Private Sub txtShift_Enter(ByVal sender As Object, ByVal args As
EventArgs) Handles txtShift.Enter
btnOK.Focus()
btnOK.PerformClick()
End Sub
End Module
How can I hide the shift popup screen when someone logs into MES?
The shifts do not change and this is an extra step I need eliminate.
Vantage 803.404a running a Progress database.
There might be a no customization option. If the employee signs in
within the grace period for the shift assigned in the Shop Employee
record, the shift select screen doesn't show.
So check each employee's shift setup in Shop Employee Maintenance or
Employee Maintenance under Payroll. Then if possible, setup a 15
minute grace period for the shift start (we have 15 minutes). This
will round actual clock in time to the shift start time.
Company Configuration -> Modules -> Production -> Data Collection
