Hello,
My company requires a customized column in the Work Queue’s Active Work table. I have code working that, in the EpiViewNotification, loops through the rows and updates the custom column with the appropriate value. Issue is, the code causes a slowdown in the Work Queue form. I’ve tried to use Async/Await but I get errors popup like “bindingsource cannot be its own datasource”.
How I was trying to accomplish it was by building a method to pull the data for the custom column:
public void ProcessCustomCol(EpiDataView view)
foreach (DataRow dr in view.dataView.Table.Rows)
// Run method to pull data for custom column and update custom column
Then I created an Async method to run this function:
public async void ProcessCustomColAsync(EpiDataView view)
await Task.Run(() => ProcessCustomCol(view));
The behavior of the form works better, especially when clicking the Select checkboxes in the active work column, but I get those binding errors. I read online that the grids are not thread safe.
I appreciate any thoughts you may have, thank you!
