No. Not that I'm aware of.
You can, however, change the default printer via the command line in a batch
file, for example. Perhaps create a bat file to toggle the default printer.
Just a thought. Here's the syntax you'd use at a command prompt (DOS
window).
RUNDLL32 PRINTUI.DLL,PrintUIEntry /y /n "HP Officejet Pro 8500"
Obviously replace the printer name in quotes with your printer name.
traceyb53070
Sent: Tuesday, June 04, 2013 9:32 AM
Subject: [Vantage] MES work station printers
Hello,
Our work stations default to our 4"x6" label printers. Our problem is when
we print preview other reports made for standard 8 1/2" x 11" paper needed
at those stations, they preview on a 4"x6" area losing most of the
information on that report page. We are hoping to go paperless with this and
not printing those reports and only previewing them on the screen.
Is there away to override the default printer for some reports to preview
the full report other than changing the default?
Thank you,
Tracey
window).
traceyb53070
Hello,
Thank you,
Tracey
