Method and Data Directives - conversion from E9 to E10
The old directives probably won’t be of much help anyway except, possibly, for a reminder of what they were doing on execution.  With the depreciation of ABL and the schema changes most of them would be non-functional in 10.
Michael
Michael Barry
Aspacia Systems Inc
866.566.9600
312.803.0730 fax
http://www.aspacia.com/
On Feb 6, 2015, at 8:56 AM, cjblake@... [vantage] <vantage@yahoogroups.com> wrote:
<div id="ygrps-yiv-419572404ygrp-text" class="ygrps-yiv-419572404"><div class="ygrps-yiv-419572404"><br class="ygrps-yiv-419572404webkit-block-placeholder"></div><div class="ygrps-yiv-419572404"><span class="ygrps-yiv-419572404"></span><br class="ygrps-yiv-419572404webkit-block-placeholder"></div><p class="ygrps-yiv-419572404MsoNormal"><span style="color:#5F497A;" class="ygrps-yiv-419572404">When
converting from E9 to E10, does it just not bring over Method and Data
Directives or should I be seeing something in there?  We have setup a test
server with the converted database and I notice that there are no Method or
Data Directives.  I’m not sure if something didn't process correctly of if
that’s just the way it works and you need to start from scratch with
directives.
Christine
</div>
When converting from E9 to E10, does it just not bring over Method and Data Directives or should I be seeing something in there?  We have setup a test server with the converted database and I notice that there are no Method or Data Directives.  I’m not sure if something didn't process correctly of if that’s just the way it works and you need to start from scratch with directives.
Christine
They should come over but mostly blank with old commented out for conversion.
Jose C Gomez
Software Engineer
T: 904.469.1524 mobile
On Fri, Feb 6, 2015 at 11:56 AM, cjblake@... [vantage] <vantage@yahoogroups.com> wrote:
Â
<div>
  <p></p><p><span></span></p><p class="ygrps-yiv-1196782332MsoNormal"><span style="color:#5f497a;">When
directives.
Thanks,Â
Christine
</div>
<div style="color:#fff;min-height:0;"></div>
OK.  Thanks.  Guess something went wrong during conversion then.
