Method directive "The specified field has been changed from any
Did you try using the condition of the specified field of the "added row" (instead of a field change) if you are adding a record?  We use a Method directive on DMRProcessing CustomUpdate, but the condition logic is built into custom source code because we need to write a value to a different table.
Hello
I was trying to use the method directive with condition "The specified field has been changed from any to any" but it doesn't seem to work. My setting was in a pre-processing condition "the ttDMRCorAct.ActionID has been changed from any to any". When the field value changes, no actions were taken. Is there any settings required for this method directive to work?
Thank you.
Regards,
Mandy Tong
Office Manager
[cid:image001.png@01CFF818.673BF580]
EL ES DE Engineering Pty Ltd
Building C, 283-291 Treasure Rd, Welshpool
Perth , Western Australia, 6106
Direct: +618 6336 9648
Ph: +618 6336 9640
Fax: WI +618 9258 5238
Mob: +614 0510 3397
Email: mandy.tong@...<mailto:mandy.tong@...>
Web: www.elesde.com<http://www.elesde.com/>
What method were you using? Sometimes a PreProc won't work if there is no data available IE in a GetNew Method.
Jose C Gomez
Software Engineer
T: 904.469.1524 mobile
On Mon, Nov 3, 2014 at 9:16 PM, Mandy Tong Mandy.Tong@... [vantage] <vantage@yahoogroups.com> wrote:
Â
<div>
  <p>Hello<br>
I was trying to use the method directive with condition “The specified field has been changed from any to any” but it doesn’t seem to work. My setting was in a pre-processing condition “the ttDMRCorAct.ActionID has been changed from any to any”. When the field value changes, no actions were taken. Is there any settings required for this method directive to work?
Thank you.
Regards,
Mandy Tong
Office Manager
Ph: +618 6336 9640
Mob: +614 0510 3397
Email: mandy.tong@…<mailto:mandy.tong@…>
</div>
<div style="color:#fff;min-height:0;"></div>
I was doing it in Corrective Action-> Update. Should work?
Thank you.
Regards,
Mandy Tong
Office Manager
[cid:image001.png@01CFF818.D3F3D670]
Ph: +618 6336 9640
Mob: +614 0510 3397
Sent: Tuesday, 4 November 2014 10:18 AM
To: Vantage
Subject: Re: [Vantage] Method directive "The specified field has been changed from any to any" does not work
Jose C Gomez
Software Engineer
E: jose@...<mailto:jose@...>
http://www.josecgomez.com
[http://www.josecgomez.com/images/linkedin.png%5d<http://www.linkedin.com/in/josecgomez> [http://www.josecgomez.com/images/facebook.png%5d <http://www.facebook.com/josegomez> [http://www.josecgomez.com/images/google.png%5d <http://www.google.com/profiles/jose.gomez> [http://www.josecgomez.com/images/twitter.png%5d <http://www.twitter.com/joc85> [http://www.josecgomez.com/images/wp.png%5d <http://www.josecgomez.com/professional-resume/> [http://www.josecgomez.com/images/rss.png%5d <http://www.josecgomez.com/feed/>
On Mon, Nov 3, 2014 at 9:16 PM, Mandy Tong Mandy.Tong@...<mailto:Mandy.Tong@...> [vantage] <vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>> wrote:
Hello
Thank you.
Regards,
Mandy Tong
Office Manager
Direct: +618 6336 9648<tel:%2B618%206336%209648>
Ph: +618 6336 9640<tel:%2B618%206336%209640>
Fax: WI +618 9258 5238<tel:%2B618%209258%205238>
Mob: +614 0510 3397
Email: mandy.tong@...<mailto:mandy.tong@...><mailto:mandy.tong@...<mailto:mandy.tong@...>>
Web: www.elesde.com<http://www.elesde.com><http://www.elesde.com/>
Hmm I don't know enough about DMR to know if there is data available then. But if its not firing then I'd say no? Try removing the condition and just popping up a Message Box and see if that fires. If it does then your condition is not working. If it doesn't the method may not be firing at all.
Jose C Gomez
Software Engineer
On Mon, Nov 3, 2014 at 9:19 PM, Mandy Tong Mandy.Tong@... [vantage] <vantage@yahoogroups.com> wrote:
Â
<div>
  <p>I was doing it in Corrective Action-&gt; Update. Should work?
Thank you.
Regards,
Mandy Tong
Office Manager
Ph: +618 6336 9640
Mob: +614 0510 3397
To: Vantage
Subject: Re: [Vantage] Method directive “The specified field has been changed from any to any” does not work
Jose C Gomez
Software Engineer
[http://www.josecgomez.com/images/linkedin.png]<http://www.linkedin.com/in/josecgomez> [http://www.josecgomez.com/images/facebook.png] <http://www.facebook.com/josegomez> [http://www.josecgomez.com/images/google.png] <http://www.google.com/profiles/jose.gomez> [http://www.josecgomez.com/images/twitter.png] <http://www.twitter.com/joc85> [http://www.josecgomez.com/images/wp.png] <http://www.josecgomez.com/professional-resume/> [http://www.josecgomez.com/images/rss.png] <http://www.josecgomez.com/feed/>
Hello
Thank you.
Regards,
Mandy Tong
Office Manager
Mob: +614 0510 3397
</div><span class="ygrps-yiv-965206015">
I’ve used other conditions and they are working fine except for this one, which is very strange…
Thank you.
Regards,
Mandy Tong
Office Manager
[cid:image001.png@01CFF819.77EAA150]
Ph: +618 6336 9640
Mob: +614 0510 3397
Sent: Tuesday, 4 November 2014 10:21 AM
To: Vantage
Jose C Gomez
Software Engineer
On Mon, Nov 3, 2014 at 9:19 PM, Mandy Tong Mandy.Tong@...<mailto:Mandy.Tong@...> [vantage] <vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>> wrote:
Thank you.
Regards,
Mandy Tong
Office Manager
Mob: +614 0510 3397
From: vantage@yahoogroups.com<mailto:vantage@yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>]
To: Vantage
Jose C Gomez
Software Engineer
T: 904.469.1524<tel:904.469.1524> mobile
E: jose@...<mailto:jose@...><mailto:jose@...<mailto:jose@...>>
On Mon, Nov 3, 2014 at 9:16 PM, Mandy Tong Mandy.Tong@...<mailto:Mandy.Tong@...><mailto:Mandy.Tong@...<mailto:Mandy.Tong@...>> [vantage] <vantage@yahoogroups.com<mailto:vantage@yahoogroups.com><mailto:vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>>> wrote:
Hello
Thank you.
Regards,
Mandy Tong
Office Manager
Direct: +618 6336 9648<tel:%2B618%206336%209648><tel:%2B618%206336%209648>
Ph: +618 6336 9640<tel:%2B618%206336%209640><tel:%2B618%206336%209640>
Fax: WI +618 9258 5238<tel:%2B618%209258%205238><tel:%2B618%209258%205238>
Mob: +614 0510 3397
Email: mandy.tong@...<mailto:mandy.tong@...><mailto:mandy.tong@...<mailto:mandy.tong@...>><mailto:mandy.tong@...<mailto:mandy.tong@...><mailto:mandy.tong@...<mailto:mandy.tong@...>>>
Web: www.elesde.com<http://www.elesde.com><http://www.elesde.com><http://www.elesde.com/>
