Method Directive with Execute Custom Code to look at SQL View
Hi!
Our team needs to implement a Pre-processing Method Directive on Erp.BO.ReceiptsFromMfg.GetSelectSerialNumbersParams that look at an sql data view from another sql data base to verify information.
We have been able to confirm that when executing the code, it is reaching the view when we hard code the JobNum and SerialNum, but not select the job num serial num we are transacting on.
How to we fix this code, to do that?
callContextBpmData.Checkbox01 = false;
callContextBpmData.ShortChar01 = "SQL found: ";
string server = "string.server.com";
/*string database = "database"; */
string username = "username";
string password = "password";
string timeout = "30";
var JobNum = "NDW141263";
var SerialNum = "P9-22332";
    string select = string.
Format
("select Test_Status from ERPKineticPilot.dbo.vw_NDI_HUGO_ProductionOperations where Work_Order_ID = '{0}' and Serial_Nbr = '{1}' and Test_ID = '0000000' and Test_Status = 1 ;",
JobNum,
SerialNum
    System.Data.SqlClient.SqlConnection SQLCon = new System.Data.SqlClient.
SqlConnection
    try
      string connectionString = "Persist Security Info=false;Integrated Security=false; " +
                               /* "database=" + database + ";" + */
                                "User ID=" + username + ";" +
                                "password=" + password + ";" +
                                "server=" + server + ";" +
                                "Connect Timeout=" + timeout;
      SQLCon.ConnectionString = connectionString;
      SQLCon.
Open
      System.Data.SqlClient.SqlCommand command = new System.Data.SqlClient.
SqlCommand
(select, SQLCon);
      command.CommandTimeout = 90;
      System.Data.SqlClient.SqlDataReader reader = command.
ExecuteReader
if
( reader.HasRows )
while
(reader.
Read
callContextBpmData
.Checkbox01 =
true
callContextBpmData
.ShortChar01 += "Tests Available";
else
callContextBpmData
.Checkbox01 =
false
callContextBpmData
.ShortChar01 += "No Tests";
    }catch (Exception ex)
callContextBpmData
.Checkbox01 =
false
callContextBpmData
.ShortChar01 += "Nothing Returned";
      throw new Ice.
BLException
("Unable to connect to SQL or execute query\tserver: " + server +
                                      /*" database: " + database +
                                      " username: " + username +
                                      "\tQuery: " + select + ex.Message);
    finally
if
( SQLCon !=
null
        SQLCon.
Close
        SQLCon =
null
Any help is appreciated.
For the SQL query string there:
"select Test_Status from ERPKineticPilot.dbo.vw_NDI_HUGO_ProductionOperations where Work_Order_ID = '" + JobNum + "' and Serial_Nbr = '" + SerialNum + "' and Test_ID = '0000000' and Test_Status = 1"
Out of curiosity - did you try an External BAQ ?
This would be my recommendation. It’s much easier to have the BPM call a function, and create an Epicor function to call an external BAQ. Easier to maintain, and no need to code in long query strings or credentials that might change.
What does your BPM look like?
