Inputs.edtPartDesc.Value = desc.ToString();
It’s currently running all of the “options” back to back, right behind the BodyType. I want the cmbBodyType (U7) to be on one line, and all of the Inputs.txt…QuoteDesc.Value data to be on separate lines, AFTER the “Options” Label.
In the following order:
Inputs.txtCompressorQuoteDesc.Value
Inputs.txtCranesQuoteDesc.Value
Inputs.txtFrontEndReplaceQuoteDesc.Value
Inputs.txtHRackQuoteDesc.Value
Inputs.txtGpsQuoteDesc.Value
Inputs.txtFireExtQuoteDesc.Value
Inputs.txtDrawerUnitsQuoteDesc.Value
I don’t hyave a problem with the inputs running back to back, but I want some type of seperation between the inputs. It’s very hard to read.
The inputs are:
Inputs.cmbCompressor.Value
Inputs.cmbCranes.Value
Inputs.cmbFrontEndReplace.Value
Inputs.cmbHRack.Value
Inputs.cmbGps.Value
Inputs.cmbFireExt.Value
Inputs.cmbDrawerUnits.Value
That’s not the issue with my code example anyway, the problem is the fancy quote marks, they should be the normal ones " not “
Environment.NewLine is just a string containing “\r\n” for non-Unix platforms, or a string containing “\n” for Unix platforms. Good practice for cross platform code but not needed in this case.
I have seen “type?” declarations now allowed in Epicor Functions. This is great news since I’ve always wanted to write a Catholic dating app (NotBeforeMarriage.com is available) but until now I’ve never been able to mark the marriage variable as nullable.
