Method Tracker customisation Vantage 803
Does anyone know if this has been resolved?
--- In vantage@yahoogroups.com, "cpsadp" <cpsadp@...> wrote:
> They told me a few weeks ago (when I discovered this issue, too),
> that it's supposed to come out in the 811 patch....
> --- In vantage@yahoogroups.com, "Paul V. Blais" <pblais@> wrote:
> > SCR 32753 has been created for this. I don't know what patch it
is
> > supposed to be released on.
> > Paul
> > From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On
> Behalf
> > Of Michael McWilliams
> > Sent: Thursday, February 08, 2007 12:48 PM
> > Subject: [Vantage] Re: Method Tracker customisation Vantage 803
> > --- In vantage@yahoogroups.com <mailto:vantage%
40yahoogroups.com> ,
> > "jonnyfatman666"
> > <jonathan.waines@> wrote:
> > Go under Utilities--->>> SubProcess Maint. Right click in the
> > textbox for the PROCESS ID and do a search. Choose the Method
> > Tracker and then Apply the Customization.
> > > Is there no-one who wants to do this, or am I just missing
> > something
> > > major?
> > > Sorry for bumping the thread, but no-one can tell me if it's
> > possible
> > > or or not.
> > > Cheers,
> > > Jonny
> > "jonnyfatman666" <jonathan.waines@>
> > > wrote:
> > > > Hi All,
> > > > I can customize the method tracker to my heart's content, but
> am
> > at a
> > > > loss on how to make it permanent. I'd normally go thru menu
> > > maintenance
> > > > and set the default customization in there, but as the method
> > tracker
> > > > doesn't appear by itself in any menus I can't set this up.
> > > > Any ideas?
> > > > Cheers,
> > > > Jonathan
Hi All,
I can customize the method tracker to my heart's content, but am at a
loss on how to make it permanent. I'd normally go thru menu maintenance
and set the default customization in there, but as the method tracker
Any ideas?
Cheers,
Jonathan
Is there no-one who wants to do this, or am I just missing something
major?
Sorry for bumping the thread, but no-one can tell me if it's possible
or or not.
Cheers,
Jonny
--- In vantage@yahoogroups.com, "jonnyfatman666" <jonathan.waines@...>
wrote:
> Hi All,
maintenance
> Any ideas?
> Cheers,
> Jonathan
In Vantage 8.03 the Method Tracker is Menu ID BMGO3040 on the
Engineering - General Operations menu tree. However it is coded to
not display, even in menu maintenance. You can retrieve a listing of
menu items using ODBC and view it in Excel or Access. You can use
Access to set the OptionType from N to I and then it will display in
menu maintenance where you can then peg your customization to it.
After that is done reset the OptionType back to N.
CAUTION the menu tree is one of the first things loaded when
launching Vantage. If the menu table gets screwed up by poking data
into it, Vantage will not launch. Back up your database before doing
anything that could potentially render the system useless.
We are using a customized method tracker - so I know it can be done.
bw
something
> major?
possible
> or or not.
> Cheers,
> Jonny
> --- In vantage@yahoogroups.com, "jonnyfatman666" <jonathan.waines@>
> wrote:
> > Hi All,
at a
> maintenance
tracker
> > Any ideas?
> > Cheers,
> > Jonathan
No ideas here - it looks like the Method Tracker is a 'back door'
hidden application extension of the Engineering Workbench (it
actually looks like a customization of the workbench). Somehow the
application passes the PN and Revision selected to the workbench and
displays the 'Method of Manufacturing' tab only, while not checking
out the part to engineering. Good luck and if you find anything,
please pass it on to the group. I am also curious about trying the
same thing with the 'Job Status Dashboard' which I believe is only
accessible by right-clicking from the job number in job tracker.
Rich J
something
> major?
possible
> or or not.
> Cheers,
> Jonny
<jonathan.waines@>
> wrote:
> > Hi All,
at a
> maintenance
tracker
> > Any ideas?
> > Cheers,
> > Jonathan
SCR 32753 has been created for this. I don't know what patch it is
Paul
"jonnyfatman666"
something
> major?
possible
> or or not.
> Cheers,
> Jonny
> wrote:
> > Hi All,
at a
> maintenance
tracker
> > Any ideas?
> > Cheers,
> > Jonathan
> Paul
Behalf
> "jonnyfatman666"
> something
> > major?
> possible
> > or or not.
> > Cheers,
> > Jonny
> > wrote:
> > > Hi All,
am
> at a
> > maintenance
> tracker
> > > Any ideas?
> > > Cheers,
> > > Jonathan
