Method Tracker - Field help
I am trying to modify the Methods Master SSRS report and trying to figure out where this field sit. I looked at the ECOOpr as well as PartOpr, but cannot find a similar field name. See screenshot with highlighted in “Final Operation”.
Try running a trace when you check that box and see if you get a hint there.
Think it is in partrev or partassm.
There is a field which holds the op seq for the final op.
Graeme
Thank you. Found it in PartRev. Will use trace next time.
