Mfg Operation using bar stock to yield fixed multiple-quantiti
Michael- will look into trying that-thanks very much for your input.
tku
RSN
ami_miker <mrandolph@...> wrote:
RSN,
Dimensional inventory won't help a lot for your situation. If you
are using MRP to generate job suggestions, have you considered
setting the manufactured part to have a Lot Multiple of 2. The
material requirement will still be 6" per piece, but since you are
always producing in multiples of 2, your material requirement will
always be in multiples of 12".
Michael Randolph
Infinity Business Consulting
mrandolph@...
Office: 865-329-3000
--- In vantage@yahoogroups.com, RSN <rsnsfi@...> wrote:
> We use Vantage 8.00.809 and we have a specific mfgrng operation
setup issue that we would like some feedback on if others in the
injection mould industry or similar situations use Vantage to set up
the part and similar Operation. We are trying to set up a Machining
operation step on a sub-assembly (a valve body) that requires a
single raw material component part issued to it (steel bar stock).
This operation is a sub-contract operation. We issue the bar stock
that is 10" in diameter and 12" in length to a sub-contract
Machining operation that slices the bar LENGTHWISE that then is
machined into 2 valve bodies. (This implies that therefore 6" of
this stock will not make one valve body since it is not cut
crosswise and therefore every 12" piece will always result in 2
valve bodies). How do you set up this operation so that when we
issue quantity 2 it doesn't say Net required Qty 24". Vantage does
not store shape information on a Part and we haven't used the
dimensions on a
> part yet. Any ideas or suggestions are appreciated.
> Thank you
> rsn
> Do you Yahoo!?
> Get on board. You're invited to try the new Yahoo! Mail.
Get your email and more, right on the new Yahoo.com
We use Vantage 8.00.809 and we have a specific mfgrng operation setup issue that we would like some feedback on if others in the injection mould industry or similar situations use Vantage to set up the part and similar Operation. We are trying to set up a Machining operation step on a sub-assembly (a valve body) that requires a single raw material component part issued to it (steel bar stock). This operation is a sub-contract operation. We issue the bar stock that is 10" in diameter and 12" in length to a sub-contract Machining operation that slices the bar LENGTHWISE that then is machined into 2 valve bodies. (This implies that therefore 6" of this stock will not make one valve body since it is not cut crosswise and therefore every 12" piece will always result in 2 valve bodies). How do you set up this operation so that when we issue quantity 2 it doesn't say Net required Qty 24". Vantage does not store shape information on a Part and we haven't used the dimensions on a
Thank you
rsn
Do you Yahoo!?
RSN,
Michael Randolph
mrandolph@...
dimensions on a
> Thank you
> rsn
> Do you Yahoo!?
