MFG-PLT Transactions (8.03.407C)
Michelle,
Did you ever get any additional information on this? We too have seen this same problem and we opened a call with the help desk over 7 months ago and were originally told that the system would not do this.
After fighting with the help desk for a couple months on the issue they created an SCR 56944 which is slated for 8.03.409, but we were originally told it would be fixed in 408 (we are now on 408 and it is not yet fixed).
Robert
--- In vantage@yahoogroups.com, Michelle de la Vega <mdelavega@...> wrote:
> I have an interesting issue that has just come up. We recently set up a new plant and now, every time we have an open transfer order for an item the new plant manufactures, the job receipt to inventory warehouse defaults to receive into the "requesting" plant (i.e. the plant that created the transfer order). This causes a MFG-PLT transaction, which means that a transfer order packing slip is automatically generated (and marked shipped) and the part stays in transit until we receive them in our plant.
> This only occurs when there are open transfer orders for the part. If there aren't any open transfer orders it will default to the manufacturing plant.
> Now, if the default job receipt to inventory location is wrong we can change it to the correct plant IF the person doing the data entry catches this problem.
> I have contacted Epicor and they want me to upgrade to 408B, but they don't actually know if it is fixed in 408B or if they just can't replicate the scenario at this time.
> Have any of you experienced this? If so, how do you handle it? Or did you upgrade and that fixed the problem.
> Thanks for any help you can give me.
> Michelle de la Vega
> Business Applications Manager
> Cold Jet, LLC
> 455 Wards Corner Road
> Loveland, Ohio 45140
> USA
> +1 513-716-6400 (office)
> +1 513-382-3281 (mobile)
> +1 513-831-1209 (fax)
> www.coldjet.com<http://www.coldjet.com>
> [cid:image001.jpg@...]
Michelle de la Vega
Cold Jet, LLC
USA
[cid:image001.jpg@01CA387B.2CDC7A20]
