MfgSys.exe Command Line Options
I don't know of any command line argument that will do that. The only
way I know would be to use a Named Search.
Nigel.
--- In vantage@yahoogroups.com, "Robert A Rossow" <rrossow1@...>
wrote:
> Excellent! Thank you Nigel.
> One more question on the same topic, using your example, what
if I
> want it to load "Customer001"? Would I need to make a custom tracker
> or is there an argument that I could use like "/custNum cust001"?
> -Rob
> --- In vantage@yahoogroups.com, "Nigel Kerley" <nigel.kerley@>
wrote:
> > Hi Rob,
> > Try this:
> > C:\Epicor\mfgsys80
\client\MfgSys.exe /db /con=default.mfgsys /ski /d
> > CustomerDtlTracker
> > Nigel.
> > --- In vantage@yahoogroups.com, "Robert A Rossow" <rrossow1@>
wrote:
> > > Greetings,
> > > I've been looking at setting up an icon where you double
click on
> > > and it will load a Vantage 8 dashboard. I've read the command
line
> > > options for MfgSys.exe if you use '/db' it will launch a blank
> > > dashboard. Has anyone found a way to specify a particular
dashboard to
> > > open using that method? If I'm able to do this I might be able
to use
> > > Launchy to interact with Vantage 8.
> > > Thanks,
> > > Rob Rossow
Greetings,
I've been looking at setting up an icon where you double click on
and it will load a Vantage 8 dashboard. I've read the command line
dashboard. Has anyone found a way to specify a particular dashboard to
open using that method? If I'm able to do this I might be able to use
Rob Rossow
Hi Rob,
Try this:
C:\Epicor\mfgsys80\client\MfgSys.exe /db /con=default.mfgsys /ski /d
CustomerDtlTracker
Nigel.
--- In vantage@yahoogroups.com, "Robert A Rossow" <rrossow1@...> wrote:
> Greetings,
> Thanks,
> Rob Rossow
One more question on the same topic, using your example, what if I
-Rob
--- In vantage@yahoogroups.com, "Nigel Kerley" <nigel.kerley@...> wrote:
> Hi Rob,
> Try this:
> CustomerDtlTracker
> Nigel.
> --- In vantage@yahoogroups.com, "Robert A Rossow" <rrossow1@> wrote:
> > Greetings,
> > Thanks,
> > Rob Rossow
