Hello,
Previously I have been able to generate emails from BPMs and attach a mfgsys file to the specific record to help users open up the correct information. I am now attempting to do this for a UD table the default XML is:
The records in the table are unique on Key1 and Key2. If I just populate Key1 it returns all records for the record mentioned in the Tags.
I have used the BL tester and a simple Where clause on the GetList works, but I am not sure it is actually using the same approach to load the form.
I have tried several different concatenations of the KeyFields item to get it to work. I have searched all known locations for information on building the correct string with no luck.
So before I go cap in hand to Epicor for some information,has anyone run into this issue and if so how did you get around it. I’d rather not have to alter my forms and BPMs to accommodate this if I can help it.
For UD fields (or any tables which use multiple keys) you have to use the SysRowID. There is no way to push in the individual Keys without a customization and reading in the values from the LFO
LaunchFormOptions (that’s the object that is passed in to all the forms when they are invoked)
it usually contains a ValueIn property with the primary key (keys) of the form for auto loading.
