Migration to E10
Yes it will. Then you shouldn’t be stopped by this error during the migration.
Scott Kaufman
[cid:image001.jpg@01CF7B59.36D68D10]<http://www.codabears.com/>
630-672-7688 x1233
[cid:image002.jpg@01CF7B59.36D68D10] <https://www.facebook.com/CodaBearsInc> [cid:image003.jpg@01CF7B59.36D68D10] <http://www.linkedin.com/company/codabears-inc> [cid:image004.jpg@01CF7B59.36D68D10] <https://twitter.com/CodaBearsInc> [cid:image005.png@01CF7B59.36D68D10] <http://google.com/+CodaBearsIncRoselle>
Sent: Thursday, May 29, 2014 1:26 PM
Subject: Re: [Vantage] Migration to E10
If I delete my extended UD table in the maintenance program in Epicor and run schema update, it deletes the table in the database?
From: "Scott Kaufman scott@...<mailto:scott@...> [vantage]" <vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>>
To: "vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>" <vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>>
Sent: Thursday, May 29, 2014 2:08 PM
Subject: RE: [Vantage] Migration to E10
We’ve seen this error when migrating Extended UD tables to Epicor 10.
From the some initial testing we’ve done it seems to fail on fields with names larger than 20 characters.
I would suggest:
· Export your _UD tables to Excel.
· Delete your Extended UD fields.
· Rerun the UD schema update in 9.05.
· Migrate your data to E10.
· Add your Extended UD fields in E10.
· Finally, reimport your data from the Excel export.
Scott Kaufman
[cid:image001.jpg@01CF7B3F.114D04D0<mailto:image001.jpg@01CF7B3F.114D04D0>]<http://www.codabears.com/>
630-672-7688 x1233
[cid:image002.jpg@01CF7B3F.114D04D0<mailto:image002.jpg@01CF7B3F.114D04D0>] <https://www.facebook.com/CodaBearsInc> [cid:image003.jpg@01CF7B3F.114D04D0<mailto:image003.jpg@01CF7B3F.114D04D0>] <http://www.linkedin.com/company/codabears-inc> [cid:image004.jpg@01CF7B3F.114D04D0<mailto:image004.jpg@01CF7B3F.114D04D0>] <https://twitter.com/CodaBearsInc> [cid:image005.png@01CF7B3F.114D04D0<mailto:image005.png@01CF7B3F.114D04D0>] <http://google.com/+CodaBearsIncRoselle>
From: vantage@yahoogroups.com<mailto:vantage@yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>]
Sent: Thursday, May 29, 2014 12:56 PM
To: vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>
I tried just running the step that errors but same errors.
In the migration guide it says not to skip a step if there is an error. When I look in SQL the two UD tables (Project_UD and ProdCal_UD) are not created.
From: "Anthony Gercar agercar@...<mailto:agercar@...><mailto:agercar@...<mailto:agercar@...>> [vantage]" <vantage@yahoogroups.com<mailto:vantage@yahoogroups.com><mailto:vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>>>
To: "vantage@yahoogroups.com<mailto:vantage@yahoogroups.com><mailto:vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>>" <vantage@yahoogroups.com<mailto:vantage@yahoogroups.com><mailto:vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>>>
Sent: Thursday, May 29, 2014 1:48 PM
Try re-running just that step. Does it error still? I was able to re-run operations when they had an error.
Uncheck the box that stops the migration on error (if you didn’t already)
From: vantage@yahoogroups.com<mailto:vantage@yahoogroups.com><mailto:vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>> [mailto:vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>]
Sent: Thursday, May 29, 2014 1:39 PM
To: vantage@yahoogroups.com<mailto:vantage@yahoogroups.com><mailto:vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>>
Progress
Sent: Thursday, May 29, 2014 1:33 PM
Are you progress or SQL?
After you right click on the database in the Epicor Administration Console and click Migrate Epicor Database.
From: "brenda mohr brenda@...<mailto:brenda@...><mailto:brenda@...<mailto:brenda@...>> [vantage]" <vantage@yahoogroups.com<mailto:vantage@yahoogroups.com><mailto:vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>>>
Sent: Thursday, May 29, 2014 1:17 PM
What “part” of the conversion are you in? The conversion workbench or some other step.
Brenda
Sent: Wednesday, May 28, 2014 3:47 PM
Subject: [Vantage] Migration to E10
Hi all,
I started doing a migration to E10 from 702a and have run into an issue I'm wondering if anyone else has experienced.
I get two errors on Task ID 600 UDFieldsMigration:
Error UDFieldsMigration Project Exception thrown while processing table Object reference not set to an instance of an object.
Error UDFieldsMigration ProdCal Exception thrown while processing table Object reference not set to an instance of an object.
It just so happens these are the two tables I have extended using Extended UD Table Maintenance.
Coincidence?
Posted by: Scott Kaufman <scott@…<mailto:scott@…>>
(1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/. <http://groups.yahoo.com/group/vantage/files/>
(3) To view links to Vendors that provide Vantage services goto: http://groups.yahoo.com/group/vantage/linksYahoo Groups Links
Hi all,
Coincidence?
Brenda
Hi all,
Coincidence?
From: "brenda mohr brenda@... [vantage]" <vantage@yahoogroups.com>
To: "vantage@yahoogroups.com" <vantage@yahoogroups.com>
#ygrps-yiv-1761803132 #ygrps-yiv-1761803132yiv0300592484 #ygrps-yiv-1761803132yiv0300592484 --
#ygrps-yiv-1761803132yiv0300592484 .ygrps-yiv-1761803132yiv0300592484ygrp-photo-title{
clear:both;font-size:smaller;height:15px;overflow:hidden;text-align:center;width:75px;}
#ygrps-yiv-1761803132 #ygrps-yiv-1761803132yiv0300592484 div.ygrps-yiv-1761803132yiv0300592484ygrp-photo{
background-position:center;background-repeat:no-repeat;background-color:white;border:1px solid black;height:62px;width:62px;}
#ygrps-yiv-1761803132 #ygrps-yiv-1761803132yiv0300592484 div.ygrps-yiv-1761803132yiv0300592484photo-title
a,
#ygrps-yiv-1761803132 #ygrps-yiv-1761803132yiv0300592484 div.ygrps-yiv-1761803132yiv0300592484photo-title a:active,
#ygrps-yiv-1761803132 #ygrps-yiv-1761803132yiv0300592484 div.ygrps-yiv-1761803132yiv0300592484photo-title a:hover,
#ygrps-yiv-1761803132 #ygrps-yiv-1761803132yiv0300592484 div.ygrps-yiv-1761803132yiv0300592484photo-title a:visited {
text-decoration:none;}
#ygrps-yiv-1761803132 #ygrps-yiv-1761803132yiv0300592484 div.ygrps-yiv-1761803132yiv0300592484attach-table div.ygrps-yiv-1761803132yiv0300592484attach-row {
clear:both;}
#ygrps-yiv-1761803132 #ygrps-yiv-1761803132yiv0300592484 div.ygrps-yiv-1761803132yiv0300592484attach-table div.ygrps-yiv-1761803132yiv0300592484attach-row div {
float:left;}
#ygrps-yiv-1761803132 #ygrps-yiv-1761803132yiv0300592484 p {
clear:both;padding:15px 0 3px 0;overflow:hidden;}
#ygrps-yiv-1761803132 #ygrps-yiv-1761803132yiv0300592484 div.ygrps-yiv-1761803132yiv0300592484ygrp-file {
width:30px;}
#ygrps-yiv-1761803132 #ygrps-yiv-1761803132yiv0300592484 div.ygrps-yiv-1761803132yiv0300592484attach-table div.ygrps-yiv-1761803132yiv0300592484attach-row div div a {
#ygrps-yiv-1761803132 #ygrps-yiv-1761803132yiv0300592484 div.ygrps-yiv-1761803132yiv0300592484attach-table div.ygrps-yiv-1761803132yiv0300592484attach-row div div span {
font-weight:normal;}
#ygrps-yiv-1761803132 #ygrps-yiv-1761803132yiv0300592484 div.ygrps-yiv-1761803132yiv0300592484ygrp-file-title {
font-weight:bold;}
#ygrps-yiv-1761803132 #ygrps-yiv-1761803132 #ygrps-yiv-1761803132yiv0300592484 #ygrps-yiv-1761803132yiv0300592484
filtered #ygrps-yiv-1761803132yiv0300592484 {font-family:Wingdings;panose-1:5 0 0 0 0 0 0 0 0 0;}
#ygrps-yiv-1761803132 filtered #ygrps-yiv-1761803132yiv0300592484 {panose-1:2 4 5 3 5 4 6 3 2 4;}
#ygrps-yiv-1761803132 filtered #ygrps-yiv-1761803132yiv0300592484 {font-family:Calibri;panose-1:2 15 5 2 2 2 4 3 2 4;}
#ygrps-yiv-1761803132 filtered #ygrps-yiv-1761803132yiv0300592484 {font-family:Tahoma;panose-1:2 11 6 4 3 5 4 4 2 4;}
#ygrps-yiv-1761803132 filtered #ygrps-yiv-1761803132yiv0300592484 {font-family:Consolas;panose-1:2 11 6 9 2 2 4 3 2 4;}
#ygrps-yiv-1761803132 filtered #ygrps-yiv-1761803132yiv0300592484 {font-family:Verdana;panose-1:2 11 6 4 3 5 4 4 2 4;}
#ygrps-yiv-1761803132yiv0300592484 p.ygrps-yiv-1761803132yiv0300592484MsoNormal, #ygrps-yiv-1761803132 #ygrps-yiv-1761803132yiv0300592484 li.ygrps-yiv-1761803132yiv0300592484MsoNormal, #ygrps-yiv-1761803132 #ygrps-yiv-1761803132yiv0300592484 div.ygrps-yiv-1761803132yiv0300592484MsoNormal
{margin:0in;margin-bottom:.0001pt;font-size:12.0pt;}
#ygrps-yiv-1761803132 #ygrps-yiv-1761803132yiv0300592484 a:link, #ygrps-yiv-1761803132 #ygrps-yiv-1761803132yiv0300592484 span.ygrps-yiv-1761803132yiv0300592484MsoHyperlink
{color:blue;text-decoration:underline;}
#ygrps-yiv-1761803132 #ygrps-yiv-1761803132yiv0300592484 a:visited, #ygrps-yiv-1761803132 #ygrps-yiv-1761803132yiv0300592484 span.ygrps-yiv-1761803132yiv0300592484MsoHyperlinkFollowed
{color:purple;text-decoration:underline;}
{margin-right:0in;margin-left:0in;font-size:12.0pt;}
#ygrps-yiv-1761803132 #ygrps-yiv-1761803132yiv0300592484 code
#ygrps-yiv-1761803132 #ygrps-yiv-1761803132yiv0300592484 pre
{margin:0in;margin-bottom:.0001pt;font-size:10.0pt;}
#ygrps-yiv-1761803132 #ygrps-yiv-1761803132yiv0300592484 tt
#ygrps-yiv-1761803132 #ygrps-yiv-1761803132yiv0300592484 span.ygrps-yiv-1761803132yiv0300592484HTMLPreformattedChar
{font-family:Consolas;}
#ygrps-yiv-1761803132 #ygrps-yiv-1761803132yiv0300592484 p.ygrps-yiv-1761803132yiv0300592484attach, #ygrps-yiv-1761803132 #ygrps-yiv-1761803132yiv0300592484 li.ygrps-yiv-1761803132yiv0300592484attach, #ygrps-yiv-1761803132 #ygrps-yiv-1761803132yiv0300592484 div.ygrps-yiv-1761803132yiv0300592484attach
{margin-right:0in;margin-left:0in;font-size:9.0pt;}
#ygrps-yiv-1761803132 #ygrps-yiv-1761803132yiv0300592484 p.ygrps-yiv-1761803132yiv0300592484bold, #ygrps-yiv-1761803132 #ygrps-yiv-1761803132yiv0300592484 li.ygrps-yiv-1761803132yiv0300592484bold, #ygrps-yiv-1761803132 #ygrps-yiv-1761803132yiv0300592484 div.ygrps-yiv-1761803132yiv0300592484bold
{margin-right:0in;margin-left:0in;font-size:10.0pt;font-weight:bold;}
#ygrps-yiv-1761803132 #ygrps-yiv-1761803132yiv0300592484 p.ygrps-yiv-1761803132yiv0300592484green, #ygrps-yiv-1761803132 #ygrps-yiv-1761803132yiv0300592484 li.ygrps-yiv-1761803132yiv0300592484green, #ygrps-yiv-1761803132 #ygrps-yiv-1761803132yiv0300592484 div.ygrps-yiv-1761803132yiv0300592484green
{margin-right:0in;margin-left:0in;font-size:12.0pt;color:#628C2A;}
#ygrps-yiv-1761803132 #ygrps-yiv-1761803132yiv0300592484 p.ygrps-yiv-1761803132yiv0300592484replbq, #ygrps-yiv-1761803132 #ygrps-yiv-1761803132yiv0300592484 li.ygrps-yiv-1761803132yiv0300592484replbq, #ygrps-yiv-1761803132 #ygrps-yiv-1761803132yiv0300592484 div.ygrps-yiv-1761803132yiv0300592484replbq
{margin:3.0pt;font-size:12.0pt;}
#ygrps-yiv-1761803132 #ygrps-yiv-1761803132yiv0300592484 p.ygrps-yiv-1761803132yiv0300592484ad, #ygrps-yiv-1761803132 #ygrps-yiv-1761803132yiv0300592484 li.ygrps-yiv-1761803132yiv0300592484ad, #ygrps-yiv-1761803132 #ygrps-yiv-1761803132yiv0300592484 div.ygrps-yiv-1761803132yiv0300592484ad
#ygrps-yiv-1761803132 #ygrps-yiv-1761803132yiv0300592484 p.ygrps-yiv-1761803132yiv0300592484underline, #ygrps-yiv-1761803132 #ygrps-yiv-1761803132yiv0300592484 li.ygrps-yiv-1761803132yiv0300592484underline, #ygrps-yiv-1761803132 #ygrps-yiv-1761803132yiv0300592484 div.ygrps-yiv-1761803132yiv0300592484underline
#ygrps-yiv-1761803132 #ygrps-yiv-1761803132yiv0300592484 span.ygrps-yiv-1761803132yiv0300592484yshortcuts
#ygrps-yiv-1761803132 #ygrps-yiv-1761803132yiv0300592484 p.ygrps-yiv-1761803132yiv0300592484ad1, #ygrps-yiv-1761803132 #ygrps-yiv-1761803132yiv0300592484 li.ygrps-yiv-1761803132yiv0300592484ad1, #ygrps-yiv-1761803132 #ygrps-yiv-1761803132yiv0300592484 div.ygrps-yiv-1761803132yiv0300592484ad1
#ygrps-yiv-1761803132 #ygrps-yiv-1761803132yiv0300592484 p.ygrps-yiv-1761803132yiv0300592484ad2, #ygrps-yiv-1761803132 #ygrps-yiv-1761803132yiv0300592484 li.ygrps-yiv-1761803132yiv0300592484ad2, #ygrps-yiv-1761803132 #ygrps-yiv-1761803132yiv0300592484 div.ygrps-yiv-1761803132yiv0300592484ad2
{margin-right:0in;margin-bottom:7.5pt;margin-left:0in;font-size:12.0pt;}
#ygrps-yiv-1761803132 #ygrps-yiv-1761803132yiv0300592484 p.ygrps-yiv-1761803132yiv0300592484underline1, #ygrps-yiv-1761803132 #ygrps-yiv-1761803132yiv0300592484 li.ygrps-yiv-1761803132yiv0300592484underline1, #ygrps-yiv-1761803132 #ygrps-yiv-1761803132yiv0300592484 div.ygrps-yiv-1761803132yiv0300592484underline1
{margin-right:0in;margin-left:0in;font-size:12.0pt;text-decoration:underline;}
#ygrps-yiv-1761803132 #ygrps-yiv-1761803132yiv0300592484 span.ygrps-yiv-1761803132yiv0300592484yshortcuts1
{font-weight:bold;}
#ygrps-yiv-1761803132 #ygrps-yiv-1761803132yiv0300592484 span.ygrps-yiv-1761803132yiv0300592484yshortcuts2
{font-weight:normal;}
#ygrps-yiv-1761803132 #ygrps-yiv-1761803132yiv0300592484 span.ygrps-yiv-1761803132yiv0300592484EmailStyle34
{color:#1F497D;}
#ygrps-yiv-1761803132 #ygrps-yiv-1761803132yiv0300592484 .ygrps-yiv-1761803132yiv0300592484MsoChpDefault
{font-size:10.0pt;}
#ygrps-yiv-1761803132 filtered #ygrps-yiv-1761803132yiv0300592484 {margin:1.0in 1.0in 1.0in 1.0in;}
#ygrps-yiv-1761803132 #ygrps-yiv-1761803132yiv0300592484 div.ygrps-yiv-1761803132yiv0300592484WordSection1
filtered #ygrps-yiv-1761803132yiv0300592484 {}
#ygrps-yiv-1761803132 filtered #ygrps-yiv-1761803132yiv0300592484 {font-family:Symbol;}
#ygrps-yiv-1761803132 filtered #ygrps-yiv-1761803132yiv0300592484 {}
#ygrps-yiv-1761803132 filtered #ygrps-yiv-1761803132yiv0300592484 {font-family:Wingdings;}
#ygrps-yiv-1761803132 #ygrps-yiv-1761803132yiv0300592484 ol
{margin-bottom:0in;}
#ygrps-yiv-1761803132 #ygrps-yiv-1761803132yiv0300592484 ul
Brenda
Hi all,
Coincidence?
Brenda
Hi all,
Coincidence?
Progress
From: "Anthony Gercar agercar@... [vantage]" <vantage@yahoogroups.com>
Brenda
Hi all,
Coincidence?
Progress
Brenda
Hi all,
Coincidence?
#ygrps-yiv-114214485 #ygrps-yiv-114214485yiv8493072758 #ygrps-yiv-114214485yiv8493072758 --
#ygrps-yiv-114214485yiv8493072758 .ygrps-yiv-114214485yiv8493072758ygrp-photo-title{
#ygrps-yiv-114214485 #ygrps-yiv-114214485yiv8493072758 div.ygrps-yiv-114214485yiv8493072758ygrp-photo{
#ygrps-yiv-114214485 #ygrps-yiv-114214485yiv8493072758 div.ygrps-yiv-114214485yiv8493072758photo-title
a,
#ygrps-yiv-114214485 #ygrps-yiv-114214485yiv8493072758 div.ygrps-yiv-114214485yiv8493072758photo-title a:active,
#ygrps-yiv-114214485 #ygrps-yiv-114214485yiv8493072758 div.ygrps-yiv-114214485yiv8493072758photo-title a:hover,
#ygrps-yiv-114214485 #ygrps-yiv-114214485yiv8493072758 div.ygrps-yiv-114214485yiv8493072758photo-title a:visited {
#ygrps-yiv-114214485 #ygrps-yiv-114214485yiv8493072758 div.ygrps-yiv-114214485yiv8493072758attach-table div.ygrps-yiv-114214485yiv8493072758attach-row {
clear:both;}
#ygrps-yiv-114214485 #ygrps-yiv-114214485yiv8493072758 div.ygrps-yiv-114214485yiv8493072758attach-table div.ygrps-yiv-114214485yiv8493072758attach-row div {
float:left;}
#ygrps-yiv-114214485 #ygrps-yiv-114214485yiv8493072758 p {
#ygrps-yiv-114214485 #ygrps-yiv-114214485yiv8493072758 div.ygrps-yiv-114214485yiv8493072758ygrp-file {
width:30px;}
#ygrps-yiv-114214485 #ygrps-yiv-114214485yiv8493072758 div.ygrps-yiv-114214485yiv8493072758attach-table div.ygrps-yiv-114214485yiv8493072758attach-row div div a {
#ygrps-yiv-114214485 #ygrps-yiv-114214485yiv8493072758 div.ygrps-yiv-114214485yiv8493072758attach-table div.ygrps-yiv-114214485yiv8493072758attach-row div div span {
#ygrps-yiv-114214485 #ygrps-yiv-114214485yiv8493072758 div.ygrps-yiv-114214485yiv8493072758ygrp-file-title {
font-weight:bold;}
#ygrps-yiv-114214485 #ygrps-yiv-114214485 #ygrps-yiv-114214485yiv8493072758 #ygrps-yiv-114214485yiv8493072758
filtered #ygrps-yiv-114214485yiv8493072758 {font-family:Helvetica;panose-1:2 11 6 4 2 2 2 2 2 4;}
#ygrps-yiv-114214485 filtered #ygrps-yiv-114214485yiv8493072758 {font-family:Wingdings;panose-1:5 0 0 0 0 0 0 0 0 0;}
#ygrps-yiv-114214485 filtered #ygrps-yiv-114214485yiv8493072758 {panose-1:2 4 5 3 5 4 6 3 2 4;}
#ygrps-yiv-114214485 filtered #ygrps-yiv-114214485yiv8493072758 {font-family:Calibri;panose-1:2 15 5 2 2 2 4 3 2 4;}
#ygrps-yiv-114214485 filtered #ygrps-yiv-114214485yiv8493072758 {font-family:Verdana;panose-1:2 11 6 4 3 5 4 4 2 4;}
#ygrps-yiv-114214485 filtered #ygrps-yiv-114214485yiv8493072758 {font-family:Consolas;panose-1:2 11 6 9 2 2 4 3 2 4;}
#ygrps-yiv-114214485yiv8493072758 p.ygrps-yiv-114214485yiv8493072758MsoNormal, #ygrps-yiv-114214485 #ygrps-yiv-114214485yiv8493072758 li.ygrps-yiv-114214485yiv8493072758MsoNormal, #ygrps-yiv-114214485 #ygrps-yiv-114214485yiv8493072758 div.ygrps-yiv-114214485yiv8493072758MsoNormal
#ygrps-yiv-114214485 #ygrps-yiv-114214485yiv8493072758 a:link, #ygrps-yiv-114214485 #ygrps-yiv-114214485yiv8493072758 span.ygrps-yiv-114214485yiv8493072758MsoHyperlink
#ygrps-yiv-114214485 #ygrps-yiv-114214485yiv8493072758 a:visited, #ygrps-yiv-114214485 #ygrps-yiv-114214485yiv8493072758 span.ygrps-yiv-114214485yiv8493072758MsoHyperlinkFollowed
#ygrps-yiv-114214485 #ygrps-yiv-114214485yiv8493072758 code
#ygrps-yiv-114214485 #ygrps-yiv-114214485yiv8493072758 pre
#ygrps-yiv-114214485 #ygrps-yiv-114214485yiv8493072758 tt
#ygrps-yiv-114214485 #ygrps-yiv-114214485yiv8493072758 span.ygrps-yiv-114214485yiv8493072758HTMLPreformattedChar
#ygrps-yiv-114214485 #ygrps-yiv-114214485yiv8493072758 p.ygrps-yiv-114214485yiv8493072758attach, #ygrps-yiv-114214485 #ygrps-yiv-114214485yiv8493072758 li.ygrps-yiv-114214485yiv8493072758attach, #ygrps-yiv-114214485 #ygrps-yiv-114214485yiv8493072758 div.ygrps-yiv-114214485yiv8493072758attach
#ygrps-yiv-114214485 #ygrps-yiv-114214485yiv8493072758 p.ygrps-yiv-114214485yiv8493072758bold, #ygrps-yiv-114214485 #ygrps-yiv-114214485yiv8493072758 li.ygrps-yiv-114214485yiv8493072758bold, #ygrps-yiv-114214485 #ygrps-yiv-114214485yiv8493072758 div.ygrps-yiv-114214485yiv8493072758bold
#ygrps-yiv-114214485 #ygrps-yiv-114214485yiv8493072758 p.ygrps-yiv-114214485yiv8493072758green, #ygrps-yiv-114214485 #ygrps-yiv-114214485yiv8493072758 li.ygrps-yiv-114214485yiv8493072758green, #ygrps-yiv-114214485 #ygrps-yiv-114214485yiv8493072758 div.ygrps-yiv-114214485yiv8493072758green
#ygrps-yiv-114214485 #ygrps-yiv-114214485yiv8493072758 p.ygrps-yiv-114214485yiv8493072758replbq, #ygrps-yiv-114214485 #ygrps-yiv-114214485yiv8493072758 li.ygrps-yiv-114214485yiv8493072758replbq, #ygrps-yiv-114214485 #ygrps-yiv-114214485yiv8493072758 div.ygrps-yiv-114214485yiv8493072758replbq
#ygrps-yiv-114214485 #ygrps-yiv-114214485yiv8493072758 p.ygrps-yiv-114214485yiv8493072758ad, #ygrps-yiv-114214485 #ygrps-yiv-114214485yiv8493072758 li.ygrps-yiv-114214485yiv8493072758ad, #ygrps-yiv-114214485 #ygrps-yiv-114214485yiv8493072758 div.ygrps-yiv-114214485yiv8493072758ad
#ygrps-yiv-114214485 #ygrps-yiv-114214485yiv8493072758 p.ygrps-yiv-114214485yiv8493072758underline, #ygrps-yiv-114214485 #ygrps-yiv-114214485yiv8493072758 li.ygrps-yiv-114214485yiv8493072758underline, #ygrps-yiv-114214485 #ygrps-yiv-114214485yiv8493072758 div.ygrps-yiv-114214485yiv8493072758underline
#ygrps-yiv-114214485 #ygrps-yiv-114214485yiv8493072758 span.ygrps-yiv-114214485yiv8493072758yshortcuts
#ygrps-yiv-114214485 #ygrps-yiv-114214485yiv8493072758 p.ygrps-yiv-114214485yiv8493072758ad1, #ygrps-yiv-114214485 #ygrps-yiv-114214485yiv8493072758 li.ygrps-yiv-114214485yiv8493072758ad1, #ygrps-yiv-114214485 #ygrps-yiv-114214485yiv8493072758 div.ygrps-yiv-114214485yiv8493072758ad1
#ygrps-yiv-114214485 #ygrps-yiv-114214485yiv8493072758 p.ygrps-yiv-114214485yiv8493072758ad2, #ygrps-yiv-114214485 #ygrps-yiv-114214485yiv8493072758 li.ygrps-yiv-114214485yiv8493072758ad2, #ygrps-yiv-114214485 #ygrps-yiv-114214485yiv8493072758 div.ygrps-yiv-114214485yiv8493072758ad2
#ygrps-yiv-114214485 #ygrps-yiv-114214485yiv8493072758 p.ygrps-yiv-114214485yiv8493072758underline1, #ygrps-yiv-114214485 #ygrps-yiv-114214485yiv8493072758 li.ygrps-yiv-114214485yiv8493072758underline1, #ygrps-yiv-114214485 #ygrps-yiv-114214485yiv8493072758 div.ygrps-yiv-114214485yiv8493072758underline1
#ygrps-yiv-114214485 #ygrps-yiv-114214485yiv8493072758 span.ygrps-yiv-114214485yiv8493072758yshortcuts1
{font-weight:bold;}
#ygrps-yiv-114214485 #ygrps-yiv-114214485yiv8493072758 span.ygrps-yiv-114214485yiv8493072758yshortcuts2
#ygrps-yiv-114214485 #ygrps-yiv-114214485yiv8493072758 span.ygrps-yiv-114214485yiv8493072758EmailStyle34
{color:#1F497D;}
#ygrps-yiv-114214485 #ygrps-yiv-114214485yiv8493072758 .ygrps-yiv-114214485yiv8493072758MsoChpDefault
{font-size:10.0pt;}
#ygrps-yiv-114214485 filtered #ygrps-yiv-114214485yiv8493072758 {margin:1.0in 1.0in 1.0in 1.0in;}
#ygrps-yiv-114214485 #ygrps-yiv-114214485yiv8493072758 div.ygrps-yiv-114214485yiv8493072758WordSection1
filtered #ygrps-yiv-114214485yiv8493072758 {}
#ygrps-yiv-114214485 filtered #ygrps-yiv-114214485yiv8493072758 {font-family:Symbol;}
#ygrps-yiv-114214485 filtered #ygrps-yiv-114214485yiv8493072758 {}
#ygrps-yiv-114214485 filtered #ygrps-yiv-114214485yiv8493072758 {font-family:Wingdings;}
#ygrps-yiv-114214485 #ygrps-yiv-114214485yiv8493072758 ol
#ygrps-yiv-114214485 #ygrps-yiv-114214485yiv8493072758 ul
Progress
Brenda
Hi all,
Coincidence?
Have you given support a call? If there is an issue, they have been really helpful.
877-459-4020
Option 1 for technical
                Then
Option 1 for Install\Upgrade
Sent: Thursday, May 29, 2014 1:56 PM
Progress
Brenda
Hi all,
Coincidence?
I have a call open with them, but as soon as they asked me to send my database I decided I would post something here.
Sent: Thursday, May 29, 2014 1:59 PM
#ygrps-yiv-339759712 #ygrps-yiv-339759712yiv0153177454 #ygrps-yiv-339759712yiv0153177454 --
#ygrps-yiv-339759712yiv0153177454 .ygrps-yiv-339759712yiv0153177454ygrp-photo-title{
#ygrps-yiv-339759712 #ygrps-yiv-339759712yiv0153177454 div.ygrps-yiv-339759712yiv0153177454ygrp-photo{
#ygrps-yiv-339759712 #ygrps-yiv-339759712yiv0153177454 div.ygrps-yiv-339759712yiv0153177454photo-title
a,
#ygrps-yiv-339759712 #ygrps-yiv-339759712yiv0153177454 div.ygrps-yiv-339759712yiv0153177454photo-title a:active,
#ygrps-yiv-339759712 #ygrps-yiv-339759712yiv0153177454 div.ygrps-yiv-339759712yiv0153177454photo-title a:hover,
#ygrps-yiv-339759712 #ygrps-yiv-339759712yiv0153177454 div.ygrps-yiv-339759712yiv0153177454photo-title a:visited {
#ygrps-yiv-339759712 #ygrps-yiv-339759712yiv0153177454 div.ygrps-yiv-339759712yiv0153177454attach-table div.ygrps-yiv-339759712yiv0153177454attach-row {
clear:both;}
#ygrps-yiv-339759712 #ygrps-yiv-339759712yiv0153177454 div.ygrps-yiv-339759712yiv0153177454attach-table div.ygrps-yiv-339759712yiv0153177454attach-row div {
float:left;}
#ygrps-yiv-339759712 #ygrps-yiv-339759712yiv0153177454 p {
#ygrps-yiv-339759712 #ygrps-yiv-339759712yiv0153177454 div.ygrps-yiv-339759712yiv0153177454ygrp-file {
width:30px;}
#ygrps-yiv-339759712 #ygrps-yiv-339759712yiv0153177454 div.ygrps-yiv-339759712yiv0153177454attach-table div.ygrps-yiv-339759712yiv0153177454attach-row div div a {
#ygrps-yiv-339759712 #ygrps-yiv-339759712yiv0153177454 div.ygrps-yiv-339759712yiv0153177454attach-table div.ygrps-yiv-339759712yiv0153177454attach-row div div span {
#ygrps-yiv-339759712 #ygrps-yiv-339759712yiv0153177454 div.ygrps-yiv-339759712yiv0153177454ygrp-file-title {
font-weight:bold;}
#ygrps-yiv-339759712 #ygrps-yiv-339759712 #ygrps-yiv-339759712yiv0153177454 #ygrps-yiv-339759712yiv0153177454
filtered #ygrps-yiv-339759712yiv0153177454 {font-family:Helvetica;panose-1:2 11 6 4 2 2 2 2 2 4;}
#ygrps-yiv-339759712 filtered #ygrps-yiv-339759712yiv0153177454 {font-family:Wingdings;panose-1:5 0 0 0 0 0 0 0 0 0;}
#ygrps-yiv-339759712 filtered #ygrps-yiv-339759712yiv0153177454 {panose-1:2 4 5 3 5 4 6 3 2 4;}
#ygrps-yiv-339759712 filtered #ygrps-yiv-339759712yiv0153177454 {font-family:Calibri;panose-1:2 15 5 2 2 2 4 3 2 4;}
#ygrps-yiv-339759712 filtered #ygrps-yiv-339759712yiv0153177454 {font-family:Verdana;panose-1:2 11 6 4 3 5 4 4 2 4;}
#ygrps-yiv-339759712 filtered #ygrps-yiv-339759712yiv0153177454 {font-family:Consolas;panose-1:2 11 6 9 2 2 4 3 2 4;}
#ygrps-yiv-339759712yiv0153177454 p.ygrps-yiv-339759712yiv0153177454MsoNormal, #ygrps-yiv-339759712 #ygrps-yiv-339759712yiv0153177454 li.ygrps-yiv-339759712yiv0153177454MsoNormal, #ygrps-yiv-339759712 #ygrps-yiv-339759712yiv0153177454 div.ygrps-yiv-339759712yiv0153177454MsoNormal
#ygrps-yiv-339759712 #ygrps-yiv-339759712yiv0153177454 a:link, #ygrps-yiv-339759712 #ygrps-yiv-339759712yiv0153177454 span.ygrps-yiv-339759712yiv0153177454MsoHyperlink
#ygrps-yiv-339759712 #ygrps-yiv-339759712yiv0153177454 a:visited, #ygrps-yiv-339759712 #ygrps-yiv-339759712yiv0153177454 span.ygrps-yiv-339759712yiv0153177454MsoHyperlinkFollowed
#ygrps-yiv-339759712 #ygrps-yiv-339759712yiv0153177454 code
#ygrps-yiv-339759712 #ygrps-yiv-339759712yiv0153177454 pre
#ygrps-yiv-339759712 #ygrps-yiv-339759712yiv0153177454 tt
#ygrps-yiv-339759712 #ygrps-yiv-339759712yiv0153177454 span.ygrps-yiv-339759712yiv0153177454msohyperlink
#ygrps-yiv-339759712 #ygrps-yiv-339759712yiv0153177454 span.ygrps-yiv-339759712yiv0153177454HTMLPreformattedChar
#ygrps-yiv-339759712 #ygrps-yiv-339759712yiv0153177454 p.ygrps-yiv-339759712yiv0153177454attach, #ygrps-yiv-339759712 #ygrps-yiv-339759712yiv0153177454 li.ygrps-yiv-339759712yiv0153177454attach, #ygrps-yiv-339759712 #ygrps-yiv-339759712yiv0153177454 div.ygrps-yiv-339759712yiv0153177454attach
#ygrps-yiv-339759712 #ygrps-yiv-339759712yiv0153177454 p.ygrps-yiv-339759712yiv0153177454bold, #ygrps-yiv-339759712 #ygrps-yiv-339759712yiv0153177454 li.ygrps-yiv-339759712yiv0153177454bold, #ygrps-yiv-339759712 #ygrps-yiv-339759712yiv0153177454 div.ygrps-yiv-339759712yiv0153177454bold
#ygrps-yiv-339759712 #ygrps-yiv-339759712yiv0153177454 p.ygrps-yiv-339759712yiv0153177454green, #ygrps-yiv-339759712 #ygrps-yiv-339759712yiv0153177454 li.ygrps-yiv-339759712yiv0153177454green, #ygrps-yiv-339759712 #ygrps-yiv-339759712yiv0153177454 div.ygrps-yiv-339759712yiv0153177454green
#ygrps-yiv-339759712 #ygrps-yiv-339759712yiv0153177454 p.ygrps-yiv-339759712yiv0153177454replbq, #ygrps-yiv-339759712 #ygrps-yiv-339759712yiv0153177454 li.ygrps-yiv-339759712yiv0153177454replbq, #ygrps-yiv-339759712 #ygrps-yiv-339759712yiv0153177454 div.ygrps-yiv-339759712yiv0153177454replbq
#ygrps-yiv-339759712 #ygrps-yiv-339759712yiv0153177454 p.ygrps-yiv-339759712yiv0153177454ad, #ygrps-yiv-339759712 #ygrps-yiv-339759712yiv0153177454 li.ygrps-yiv-339759712yiv0153177454ad, #ygrps-yiv-339759712 #ygrps-yiv-339759712yiv0153177454 div.ygrps-yiv-339759712yiv0153177454ad
#ygrps-yiv-339759712 #ygrps-yiv-339759712yiv0153177454 p.ygrps-yiv-339759712yiv0153177454underline, #ygrps-yiv-339759712 #ygrps-yiv-339759712yiv0153177454 li.ygrps-yiv-339759712yiv0153177454underline, #ygrps-yiv-339759712 #ygrps-yiv-339759712yiv0153177454 div.ygrps-yiv-339759712yiv0153177454underline
#ygrps-yiv-339759712 #ygrps-yiv-339759712yiv0153177454 span.ygrps-yiv-339759712yiv0153177454yshortcuts
#ygrps-yiv-339759712 #ygrps-yiv-339759712yiv0153177454 p.ygrps-yiv-339759712yiv0153177454ad1, #ygrps-yiv-339759712 #ygrps-yiv-339759712yiv0153177454 li.ygrps-yiv-339759712yiv0153177454ad1, #ygrps-yiv-339759712 #ygrps-yiv-339759712yiv0153177454 div.ygrps-yiv-339759712yiv0153177454ad1
#ygrps-yiv-339759712 #ygrps-yiv-339759712yiv0153177454 p.ygrps-yiv-339759712yiv0153177454ad2, #ygrps-yiv-339759712 #ygrps-yiv-339759712yiv0153177454 li.ygrps-yiv-339759712yiv0153177454ad2, #ygrps-yiv-339759712 #ygrps-yiv-339759712yiv0153177454 div.ygrps-yiv-339759712yiv0153177454ad2
#ygrps-yiv-339759712 #ygrps-yiv-339759712yiv0153177454 p.ygrps-yiv-339759712yiv0153177454underline1, #ygrps-yiv-339759712 #ygrps-yiv-339759712yiv0153177454 li.ygrps-yiv-339759712yiv0153177454underline1, #ygrps-yiv-339759712 #ygrps-yiv-339759712yiv0153177454 div.ygrps-yiv-339759712yiv0153177454underline1
#ygrps-yiv-339759712 #ygrps-yiv-339759712yiv0153177454 span.ygrps-yiv-339759712yiv0153177454yshortcuts1
{font-weight:bold;}
#ygrps-yiv-339759712 #ygrps-yiv-339759712yiv0153177454 span.ygrps-yiv-339759712yiv0153177454yshortcuts2
#ygrps-yiv-339759712 #ygrps-yiv-339759712yiv0153177454 span.ygrps-yiv-339759712yiv0153177454EmailStyle35
{color:#1F497D;}
#ygrps-yiv-339759712 #ygrps-yiv-339759712yiv0153177454 .ygrps-yiv-339759712yiv0153177454MsoChpDefault
{font-size:10.0pt;}
#ygrps-yiv-339759712 filtered #ygrps-yiv-339759712yiv0153177454 {margin:1.0in 1.0in 1.0in 1.0in;}
#ygrps-yiv-339759712 #ygrps-yiv-339759712yiv0153177454 div.ygrps-yiv-339759712yiv0153177454WordSection1
filtered #ygrps-yiv-339759712yiv0153177454 {}
#ygrps-yiv-339759712 filtered #ygrps-yiv-339759712yiv0153177454 {font-family:Symbol;}
#ygrps-yiv-339759712 filtered #ygrps-yiv-339759712yiv0153177454 {}
#ygrps-yiv-339759712 filtered #ygrps-yiv-339759712yiv0153177454 {font-family:Wingdings;}
#ygrps-yiv-339759712 #ygrps-yiv-339759712yiv0153177454 ol
#ygrps-yiv-339759712 #ygrps-yiv-339759712yiv0153177454 ul
877-459-4020
                Then
Progress
Brenda
Hi all,
Coincidence?
I would send your DB. You might need to clean up some things.
Sent: Thursday, May 29, 2014 2:01 PM
877-459-4020
                Then
Progress
Brenda
Hi all,
Coincidence?
I would suggest:
Scott Kaufman
[cid:image001.jpg@01CF7B3F.114D04D0]<http://www.codabears.com/>
630-672-7688 x1233
[cid:image002.jpg@01CF7B3F.114D04D0] <https://www.facebook.com/CodaBearsInc> [cid:image003.jpg@01CF7B3F.114D04D0] <http://www.linkedin.com/company/codabears-inc> [cid:image004.jpg@01CF7B3F.114D04D0] <https://twitter.com/CodaBearsInc> [cid:image005.png@01CF7B3F.114D04D0] <http://google.com/+CodaBearsIncRoselle>
From: "Anthony Gercar agercar@...<mailto:agercar@...> [vantage]" <vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>>
From: vantage@yahoogroups.com<mailto:vantage@yahoogroups.com> [mailto:vantage@yahoogroups.com]
Progress
From: "brenda mohr brenda@...<mailto:brenda@...> [vantage]" <vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>>
Brenda
Hi all,
Coincidence?
From: "Scott Kaufman scott@... [vantage]" <vantage@yahoogroups.com>
I would suggest:
Scott Kaufman
      630-672-7688 x1233
Progress
Brenda
Hi all,
Coincidence?
Posted by: Scott Kaufman <scott@...>
<*> To visit your group on the web, go to:
<*> Your email settings:
    Individual Email | Traditional
<*> To change settings online go to:
    http://groups.yahoo.com/group/vantage/join
    (Yahoo! ID required)
<*> To change settings via email:
    vantage-digest@yahoogroups.com
    vantage-fullfeatured@yahoogroups.com
<*> To unsubscribe from this group, send an email to:
<*> Your use of Yahoo Groups is subject to:
    https://info.yahoo.com/legal/us/yahoo/utos/terms/
