I’m probably missing something obvious here, but I have created a pretty extensive UD client customization with near 100 fields and I would like to mimic the “closed” function of other standard Epicor screens like SO, jobs, etc. I have a state machine running behind the scenes so I have a state reserved for “closed”, but I have not been able to find an easy way to render all of the fields as read only. I know I can set each field individually, but is there a “global” way to make the entire form read only? As another option, I know how to Show and Close panels, not sure if there is a way to make a panel Read Only.
I would like to know that as well. I’m looking for something for SO Entry but couldn’t find anything except setting each field read-only. I ended up with a BPM on the Update method that will prevent any changes. Maybe you can look at that too, rather than making 100 fields read-only one by one.
Certainly, a BPM could prevent updates based on the value of a field. What I’m not sure how to do the read-only on the client side like approved Quotes or Purchase Orders.
And with Kinetic screens, how much time would I put into the Classic screens?
