Mirrored Servers
It has been discussed before, and Epicor has put their blessings on it.
You can perform this type of function via Progress's Fathom Replication
Server software. This appliation will in effect mirror your Primary
Progress server. In fact, Epicor has some customers who are doing this
already.
Of PLAMAN DICK
Sent: Thursday, May 11, 2006 9:56 AM
Subject: RE: [Vantage] Mirrored Servers
I think Epicor would have a problem with putting the db on two servers.
When we purchased
Vantage, they made a point of stating that the license allowed to place
the db on one server only.
>Subject: [Vantage] Mirrored Servers
>We are running Vantage 8.06 and continue to have performance (speed)
issues. Part of the problem "appears" to be that >running certain
reports loads the server up. These are custom reports that essentially
are what if MRP analysis. One idea we have is to buy a second server and
mirror it to the primary live server. Use the second server for reports
and simulation analysis. Anyone out there doing this? Opinions or
thoughts on the concept?
SPONSORED LINKS
Manufacturing software
<http://groups.yahoo.com/gads?t=ms&k=Manufacturing+software&w1=Manufactu
ring+software&w2=Membership+database+software&w3=Database+mortgage+softw
are&w4=Pda+database+software&w5=Database+management+software&w6=Database
+marketing+software&c=6&s=188&.sig=OG5F3819UOUOg63i0bu6kA>
Membership database software
<http://groups.yahoo.com/gads?t=ms&k=Membership+database+software&w1=Man
ufacturing+software&w2=Membership+database+software&w3=Database+mortgage
+software&w4=Pda+database+software&w5=Database+management+software&w6=Da
tabase+marketing+software&c=6&s=188&.sig=N5BGdur84p-jyuOomcQdbQ>
Database mortgage software
<http://groups.yahoo.com/gads?t=ms&k=Database+mortgage+software&w1=Manuf
acturing+software&w2=Membership+database+software&w3=Database+mortgage+s
oftware&w4=Pda+database+software&w5=Database+management+software&w6=Data
base+marketing+software&c=6&s=188&.sig=8rvcSQnCqJhTCZu-0Si39A>
Pda database software
<http://groups.yahoo.com/gads?t=ms&k=Pda+database+software&w1=Manufactur
ing+software&w2=Membership+database+software&w3=Database+mortgage+softwa
re&w4=Pda+database+software&w5=Database+management+software&w6=Database+
marketing+software&c=6&s=188&.sig=u3KQrTRPAQfsWIT39aHDkg> Database
management software
<http://groups.yahoo.com/gads?t=ms&k=Database+management+software&w1=Man
tabase+marketing+software&c=6&s=188&.sig=R3CF3ODPY4gwjDZjykQYvw>
Database marketing software
<http://groups.yahoo.com/gads?t=ms&k=Database+marketing+software&w1=Manu
facturing+software&w2=Membership+database+software&w3=Database+mortgage+
software&w4=Pda+database+software&w5=Database+management+software&w6=Dat
abase+marketing+software&c=6&s=188&.sig=lmBkRUiBtvHI1u5dkymDcw>
YAHOO! GROUPS LINKS
* Visit your group "vantage
<http://groups.yahoo.com/group/vantage> " on the web.
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service <http://docs.yahoo.com/info/terms/> .
issues. Part of the problem "appears" to be that running certain
essentially are what if MRP analysis. One idea we have is to buy a
second server and mirror it to the primary live server. Use the
second server for reports and simulation analysis. Anyone out there
doing this? Opinions or thoughts on the concept?
When we purchased
If you are going to use the second server for reporting purposes, are
you considering CorVu? Epicor told us if we were to use CorVu, it would
have to be on a second server because our huge db (over 22 GB now)
wouldn't be too happy with another application on it.
What CorVu is supposed to do is replicate the db to its server and run
reports from there, allowing good performance on the Vantage server.
M. Manasa Reddy
ERP Systems Specialist
Crestview Aerospace Corporation
Email: mmreddy@...
Phone: (850) 682-2746 x 272
Cell: (850) 305-0931
Radio: 186*111*3414
Of jrlabore
Sent: Thursday, May 11, 2006 9:34 AM
SPONSORED LINKS
management software
YAHOO! GROUPS LINKS
> One idea we have is to buy a second server and mirror it to the
> primary live server. Use the second server for reports and
Epicor told me there is a Progress product that can be used for failover
purposes, but they don't support anything that could be used for load
balancing.
If you want more processing power, you are probably better off to upgrade
your existing server. Alternatively, you might be able to do something like
this: We used to use a second server with a copy of the Vantage database
made from the previous day's backup. We used this for running historical
analysis and reporting.
Brian
CorVu doesn't exactly replicate the DB it instead builds a dynamart of specific data that has been extracted for the provided reports. If you want other data you must write your own queries. We found too that the Vantage dynamart was larger than our Vantage DB. It is still a nice solution for reporting but when we tried to run it on another server it had all sorts of "rights" issues and failed to login properly to run the nightly update. We are now adding disk to the Vantage server to try to run it there. Our DB is only 1.6GB.
-Todd C.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf Of Manasa Reddy
Sent: Thursday, May 11, 2006 10:27 AM
M. Manasa Reddy
Email: mmreddy@...
Radio: 186*111*3414
Of jrlabore
SPONSORED LINKS
< http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Manufacturing+software&w1=Manufactu> &k=Manufacturing+software&w1=Manufactu
< http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Membership+database+software&w1=Man> &k=Membership+database+software&w1=Man
< http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Database+mortgage+software&w1=Manuf> &k=Database+mortgage+software&w1=Manuf
< http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Pda+database+software&w1=Manufactur> &k=Pda+database+software&w1=Manufactur
management software
< http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Database+management+software&w1=Man> &k=Database+management+software&w1=Man
< http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Database+marketing+software&w1=Manu> &k=Database+marketing+software&w1=Manu
YAHOO! GROUPS LINKS
< http://groups.yahoo.com/group/vantage> " on the web.
Service < http://docs.yahoo.com/info/terms/> .
SPONSORED LINKS
Manufacturing <http://groups.yahoo.com/gads?t=ms&k=Manufacturing+software&w1=Manufacturing+software&w2=Membership+database+software&w3=Database+mortgage+software&w4=Pda+database+software&w5=Database+management+software&w6=Database+marketing+software&c=6&s=188&.sig=OG5F3819UOUOg63i0bu6kA> software Membership <http://groups.yahoo.com/gads?t=ms&k=Membership+database+software&w1=Manufacturing+software&w2=Membership+database+software&w3=Database+mortgage+software&w4=Pda+database+software&w5=Database+management+software&w6=Database+marketing+software&c=6&s=188&.sig=N5BGdur84p-jyuOomcQdbQ> database software Database <http://groups.yahoo.com/gads?t=ms&k=Database+mortgage+software&w1=Manufacturing+software&w2=Membership+database+software&w3=Database+mortgage+software&w4=Pda+database+software&w5=Database+management+software&w6=Database+marketing+software&c=6&s=188&.sig=8rvcSQnCqJhTCZu-0Si39A> mortgage software
Pda <http://groups.yahoo.com/gads?t=ms&k=Pda+database+software&w1=Manufacturing+software&w2=Membership+database+software&w3=Database+mortgage+software&w4=Pda+database+software&w5=Database+management+software&w6=Database+marketing+software&c=6&s=188&.sig=u3KQrTRPAQfsWIT39aHDkg> database software Database <http://groups.yahoo.com/gads?t=ms&k=Database+management+software&w1=Manufacturing+software&w2=Membership+database+software&w3=Database+mortgage+software&w4=Pda+database+software&w5=Database+management+software&w6=Database+marketing+software&c=6&s=188&.sig=R3CF3ODPY4gwjDZjykQYvw> management software Database <http://groups.yahoo.com/gads?t=ms&k=Database+marketing+software&w1=Manufacturing+software&w2=Membership+database+software&w3=Database+mortgage+software&w4=Pda+database+software&w5=Database+management+software&w6=Database+marketing+software&c=6&s=188&.sig=lmBkRUiBtvHI1u5dkymDcw> marketing software
_____
YAHOO! GROUPS LINKS
* Visit your group " vantage <http://groups.yahoo.com/group/vantage> " on the web.
vantage-unsubscribe@yahoogroups.com <mailto:vantage-unsubscribe@yahoogroups.com?subject=Unsubscribe>
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> .
_____
I just received a recommendation from Epicor for a Veritas product that creates a "Hot Standby" server that can be used specifically for that purpose.
From: vantage@yahoogroups.com on behalf of PLAMAN DICK
Sent: Thu 5/11/2006 10:56 AM
When we purchased
SPONSORED LINKS
Manufacturing software <http://groups.yahoo.com/gads?t=ms&k=Manufacturing+software&w1=Manufacturing+software&w2=Membership+database+software&w3=Database+mortgage+software&w4=Pda+database+software&w5=Database+management+software&w6=Database+marketing+software&c=6&s=188&.sig=OG5F3819UOUOg63i0bu6kA> Membership database software <http://groups.yahoo.com/gads?t=ms&k=Membership+database+software&w1=Manufacturing+software&w2=Membership+database+software&w3=Database+mortgage+software&w4=Pda+database+software&w5=Database+management+software&w6=Database+marketing+software&c=6&s=188&.sig=N5BGdur84p-jyuOomcQdbQ> Database mortgage software <http://groups.yahoo.com/gads?t=ms&k=Database+mortgage+software&w1=Manufacturing+software&w2=Membership+database+software&w3=Database+mortgage+software&w4=Pda+database+software&w5=Database+management+software&w6=Database+marketing+software&c=6&s=188&.sig=8rvcSQnCqJhTCZu-0Si39A>
Pda database software <http://groups.yahoo.com/gads?t=ms&k=Pda+database+software&w1=Manufacturing+software&w2=Membership+database+software&w3=Database+mortgage+software&w4=Pda+database+software&w5=Database+management+software&w6=Database+marketing+software&c=6&s=188&.sig=u3KQrTRPAQfsWIT39aHDkg> Database management software <http://groups.yahoo.com/gads?t=ms&k=Database+management+software&w1=Manufacturing+software&w2=Membership+database+software&w3=Database+mortgage+software&w4=Pda+database+software&w5=Database+management+software&w6=Database+marketing+software&c=6&s=188&.sig=R3CF3ODPY4gwjDZjykQYvw> Database marketing software <http://groups.yahoo.com/gads?t=ms&k=Database+marketing+software&w1=Manufacturing+software&w2=Membership+database+software&w3=Database+mortgage+software&w4=Pda+database+software&w5=Database+management+software&w6=Database+marketing+software&c=6&s=188&.sig=lmBkRUiBtvHI1u5dkymDcw>
YAHOO! GROUPS LINKS
* Visit your group "vantage <http://groups.yahoo.com/group/vantage> " on the web.
