Todd:
If you open RB, go into Options, Preferences and click Prompt Always on
Database Connections on Report Open, you will always be prompted to verify
your database when opening a report-and your test database would have
appeared on the first line of that screen. It takes only a second to look
at it, then click ok, so I'm in the habit of leaving it on. It also is a
big help when sharing reports as we do here on the list, because the first
thing you have to do with a report from someone else is change the database
path.
Lydia
Canyon Engineering Products, Inc.
Lessons:
1. If data is missing check the database connection (after filters and
joins)
2. Don't assume new reports will connect to the Default Database if not
first thing after starting RB
3. Never connect to test databases from reports in a production Progress
report library (.PRL file) keep them in a separate "test" .PRL.
Also, the only way I have figured out to change a database connection on a
report is to copy it to another .PRL library and change connection in the
copy process then copy it back to the original library. If there is an
easier way I would love to hear it.
Probably old news to the RB old-timers but easy to miss issues for new
users.
Thanks to those who pondered this issue or responded,
-Todd Caughey
Harvey Vogel Mfg. Co.
path.
Lydia
Lessons:
joins)
users.
-Todd Caughey
