# Missing PO Suggestions **Category:** [Epicor ERP 9](https://www.epiusers.help/c/e9/7) **Created:** 2017-02-07 18:32 UTC **Views:** 1783 **Replies:** 8 **URL:** https://www.epiusers.help/t/missing-po-suggestions/37182 --- ## Post #1 by @Kimberley I have a part for some reason stopped generating PO Suggestions. MRP runs and create MRP jobs but it is throwing the part into NEG. It is not generating PO Suggestions. I have check everything and I can't figure out why. PO Suggestions is checked; Part is Pur an part and Plant level. I don't have MPR check but didn't think it was needed. --- ## Post #2 by @BoostERP Just confirm that Quantity bearing is on also. Brad --- ## Post #3 by @Kimberley yes it is checked --- ## Post #4 by @Cathy Check Process MRP and see if you get a suggestion. --- ## Post #5 by @Kimberley Ok does that have to be checked? --- ## Post #6 by @BoostERP Some thing to verify... if you have generate PO suggestions run separately as a scheduled process you may not need MRP checked on...If you count on MRP running to generate the suggestions, which it will, then you may need MRP checked on as well. Brad --- ## Post #7 by @Kimberley Brad, I was wondering if I needed MRP checked for that part. I did it in TEST and it generated suggestions. Thanks Kim --- ## Post #8 by @Kimberley So if we are running MRP and expect PO Suggestion to run as a part of MRP...we need to have Process MRP checked on all Purchased parts for it to pick up. We currently don't have this checked on any Purchased Parts. --- ## Post #9 by @Beth Kim, That is correct. Have you tried running Generate PO Suggestions separately? If not, try it to see if it gives you suggestions. It should but I would test it in your test database to verify it. If it does, then you would just kick off Generate PO Suggestions after running MRP. That would save you from having to check the MRP flag on all purchased parts. --- **Canonical:** https://www.epiusers.help/t/missing-po-suggestions/37182 **Original content:** https://www.epiusers.help/t/missing-po-suggestions/37182
