Where input Inputs.P01_Dec_ActiveLength.Value is a decimal.
Edit:
The expression I end up with is JobMtl.QtyPer = System.Convert.ToDecimal ((System.Math.Round(((System.Convert.ToDouble(Inputs.P01_Dec_ActiveLength.Value) + 9.9) / 20) ,0) + 1) * 0.06 / 51);
Not an expert, but I think you’re doing the right thing by explicitly converting your decimal to double before adding the 9.9. Any literal in C# with a decimal point is inferred as a double unless a suffix is added, so while 9.9 looks like a decimal to us, it’s actually a double.
Remember that Math.Round returns a double and consumes a double.
Unless precision if your goal, double should be fine.
Is the precision of a ‘decimal’ universal? (I mean like how IEEE standards exist for float and doubles). If so, to how many places?
Or is it dynamic based on the system setup? If I have the company configured to use 4 decimals places, does that mean that 0.0001 is the smallest resolution for a value of type decimal?
What dothe following statements return?
System.Convert.ToDecimal(0.00005)
0 or 0.0001?
System.Convert.ToDecimal(0.00009)
0 or 0.0001?
Not sure if that helps with your question but you could play around with it to see at least what the compiler is doing.
Also, decimal in C# can represent 29-29 significant figures, whereas a double can represent 15-16. Either is probably more than enough, especially with non=scientific calculations like you’re doing.
