Hy guys, I just develope a dashboard and made it mobile, where I can find the URL or the link to that dashboard so I can access through my cellphone?
Do you own the module?
Yes, I just create the new dashboard.
It allows you to make the mobile dashboard even if you don’t own the module. So just because you did that in dashboard maintenance, doesn’t mean you own the module.
Oh ok, so, if I don´t own the module, I can´t access via Internet?
correct. I don’t know how they are accessed. I think it might be from an app that you download. I looked into them at one point, but the functionality was so limited, I didn’t bother moving forward with it.
The Dashboard Website is deployed just like Epicor Web Access via the Admin Console under Extensions. You won’t be able to access any Dashboards unless your own the License. Once you own the License then when you create a mobile dashboard, you can add it to the Mobile Menu Section via Menu Maintenance.
