Modified base events should be reverted back to base. - What?
After the upgrade to 2024.1, one of my customizations has a warning on it that says “Modified base events should be reverted back to base.”!
I’m really confused by this as you cannot modify the system events. Has anyone else come across this?
Just curious… Were you testing your customization and it failed? Or were you just randomly opening and verifying customized layers on a form?
Doing some edits to it. It appears in the Problems area at the bottom.
I think I know why it is happening, but I opened a ticket to see what they say. I have an event that I created that is After_AfterGetNew.
I had to pack up the layer in a cab and send it to support, we’ll see what happens.
Interestingly though, support said you used to be able to change base events in early Kinetic. :scream:
Any answer on this issue? We are seeing the same thing on several dashboards. Not sure when they showed up, but we did recently update from 2023.2.13 to 2023.2.25.
Development said they have seen it but cannot recreate it. They said that it does not cause any issues and can be ignored.
