In E10, I can use this object to modify the visible columns in an E10 search:
EpiSearchBase adapterSearchForm = oTrans_adapter.SearchForm;
However in E9, the Property “SearchForm” does not exist. Is there another option?
This is for Inspection Processing so a QuickSearch will not be easy (possible?).
hkeric.wci
(Haso Keric)
December 16, 2020, 10:37pm
2
I see the prop SearchForm in my E9 702A… what is your oTrans_adapter
hkeric.wci
(Haso Keric)
December 16, 2020, 10:48pm
3
I see in E9 the EpiBaseAdapter does not have it… but if you cast it, then it should be avail.
Try something like:
EpiSearchBase adapterSearchForm = ((Epicor.Mfg.UI.Adapters.InspProcessingAdapter)oTrans_adapter).SearchForm;
Another way that could work is
EpiSearchBase adapterSearchForm = ((Epicor.Mfg.UI.Adapters.InspProcessingAdapter)this.oTrans.PrimaryAdapter).SearchForm;
I had to add the Assembly Reference, but this line worked:
EpiSearchBase adapterSearchForm = ((Epicor.Mfg.UI.Adapters.InspProcessingAdapter)oTrans_inspAdapter).SearchForm;
