Modifying Production Calendars
I was merely missing the Update method call.
Thanks for the help Rob.
--- In vantage@yahoogroups.com, "bobschnable" <bschnable@...> wrote:
> Good idea, but unfortunately, still nothing.
> --- In vantage@yahoogroups.com, Rob Bucek <rbucek@> wrote:
> > 1 or 0 instead of True or false?
> > Rob Bucek
> > Production Control Manager
> > PH: (715) 284-5376 ext 311
> > Mobile: (715)896-0590
> > FAX: (715)284-4084
> > [Description: cid:1.234354861@]<http://www.dsmfg.com/>
> > (Click the logo to view our site)<http://www.dsmfg.com/>
> > From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of bobschnable
> > Sent: Monday, December 05, 2011 4:37 PM
> > Subject: [Vantage] Modifying Production Calendars
> > Hi Group,
> > I'm attempting to write a customization to modify the production calendars through an interface. I was able to access the data, and I can get the value of the appropriate hour on the calendar, but all of my attempts to modify said value have failed. The following is the current iteration of my code.
> > Thanks in advance.
> > Dim proCal As ProdCalAdapter = New ProdCalAdapter([ProdCalForm])
> > proCal.BOConnect()
> > Dim opts As SearchOptions = New SearchOptions(SearchMode.AutoSearch)
> > opts.NamedSearch.WhereClauses.Add("ProdCal", "CalendarID='0101'")
> > Dim morePages As Boolean
> > Dim proCalDataSet As DataSet = proCal.GetData("0101")
> > Dim row As DataRow = proCalDataSet.Tables("ProdCal").Rows(0)
> > Dim column As DataColumn = proCalDataSet.Tables("ProdCal").Columns("Hour001")
> > row.Item(column) = True
Hi Group,
Thanks in advance.
proCal.BOConnect()
Rob Bucek
FAX: (715)284-4084
[Description: cid:1.234354861@...]<http://www.dsmfg.com/>
Hi Group,
Thanks in advance.
proCal.BOConnect()
> Rob Bucek
> FAX: (715)284-4084
> Hi Group,
> Thanks in advance.
> proCal.BOConnect()
