I could believe that. I think I read that somewhere else as well but
the person didn't seem too convincing.
Unfortunately I doubt that we'll be needing the SDK for anything, (I
don't *think* I'll be needing to calculate fields). I take it there
is no way for anyone to at least let me know how that particular field
(Calc_NexResGrp in the ScheduledResources table), is comprised?
Thanks a lot for your help Adam!
--Mike
--Mike
--- In vantage@yahoogroups.com, "adam.whipp" <adam.whipp@...> wrote:
> Mike,
> If I am not mistaken, you need the software development kit to be
> able to see/modify those calculated fields. Without it, you cannot
> see the existing calculations, and you cannot make new calculated
> fields in RDDs. If you try to make a new calculated field without
> the SDK, all you can do is name it and give it a data type, but it
> will just be a blank field that you cannot populate with any date.
> Hope this helps.
> Adam Whipp
> --- In vantage@yahoogroups.com, "S. Michael Reeves" <mreeves@>
> wrote:
> > Specs...
> > Epicor Vantage 8.03.405a
> > Crystal Reports Developer Release XI
> > Hello,
> > I am currently trying to modify the priority dispatch report. This
> > will be the first production report I have attempted to modify, but
> > everything we want to modify is relatively simple. One thing I'm
> > trying to do, however, is figure out where the "Next Res. Group"
> field
> > is coming from. I see it is coming from a calculated field from the
> > magical table called "ScheduledResources" but I realized I have no
> > idea where Report Calculated Fields come from or what not. I
> looked at
> > the RDD to see what was going on and found where it's basically
> just a
> > spot where you create the label name and the format type...
> > So I guess my main question would be is, how can I learn more about
> > these Report Calculated Fields? And most specifically, how can I
> > determine where exactly the one mentioned above is coming from?
> > Thank you all for your time and help!
> > --Mike
