Modifying Vantage Generated Crystal Reports
John:
If the data/info you need is not contained within the .dbf file
generated by Vantage AND you want to work within Crystal, you must
create a Subreport within your Purchase Order document. Subreports
require you to setup ODBC first. The Epicor Customer Support website
has a tutorial on creating Subreports. I've done the tutorial but
have not tried Subreports as yet.
Peter Dunbar
Halm Industries
--- In vantage@yahoogroups.com, "johndeligdisch"
<johndeligdisch@y...> wrote:
> Has anyone got experience with modifying the Vantage generated
> Crystal Reports? I are trying to add "Promised Date" to our
Purchase
> Order report. It appears that Vantage generates several temporary
> database tables and uses them to drive the Crystal Reports. How do
I
> modify the tables to add additional fields? Otherwise, do I have
to
> use Access to create my own tables and generate the reports from
> Access? I currently do this with timephase. Any information would
> be greatly appreciated.
> Thanks, John Deligdisch
> Axiomatic Technologies Corp.
Crystal Reports? I are trying to add "Promised Date" to our Purchase
database tables and uses them to drive the Crystal Reports. How do I
modify the tables to add additional fields? Otherwise, do I have to
