More BAM
Ok, give a shot with this. I have reversed the logic.
My thought process is that it may be that the ActBurCost field may not
contain a 0 until after the job is started. It may have no value at all
until the time something is specifically written to it. If that is the
case, the logic will fail and not enter the else phase, thereby not running
the Assign or the Cancel.
The Code is included below.
Let me know the results.
There may be some other tricks, like string...trim the job number that may
apply.
Good luck,
Aaron Hoyt
Vantage Plastics
{ud/GlbAlert.i &TableName = "JobOper"}
IF JobOper.Company <> "TAM" AND JobOper.JobNum <> "058013" AND
JobOper.AssemblySeq <> 0 AND JobOper.OprSeq <> 20 AND
OLDJobOper.ActBurCost <> 0 THEN DO:
RETURN "Cancel Send":U.
END.
ELSE DO:
ASSIGN Email-Subject = "McNally order"
Email-From = "allen.larsen@..."
Email-To = "allen.larsen@..."
Email-Text = "The McNally order has started machining
(JOB 058013). ~n"
+ "Prepare an invoice. McNally is COD.".
END.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf
Of al2trace
Sent: Friday, August 26, 2005 9:11 AM
Subject: [Vantage] More BAM
This is my second customized BAM. Things are going pretty well but
this one has a minor flaw in it somewhere. Most of the time, it
should just not send anything. My goal is that it will only send a
message when this operation is started. When I first installed it,
all of the "Cancel Sends" were going to my "Global Alert Message
Error Log" saying that there was no e-mail address. When I put in
an e-mail address on the BAM maintenance screen, the "Cancel Sends"
were sent to that e-mail. Any thoughts on how to make the "Cancel
Sends" not do anything at all.
code follows
IF JobOper.Company = "TAM" AND JobOper.JobNum = "058013" AND
JobOper.AssemblySeq = 0 AND JobOper.OprSeq = 20 AND
OLDJobOper.ActBurCost = 0 THEN DO:
(JOB 058013). ~n"
END.
ELSE DO:
END.
Yahoo! Groups Links
code follows
(JOB 058013). ~n"
END.
ELSE DO:
END.
Aaron Hoyt had an interesting technique at the User-4-User conference. All his examples had an extra Cancel Send at the very bottom of every routine. Just incase. Might be worth trying.
-Todd C.
Sent: Friday, August 26, 2005 8:11 AM
code follows
(JOB 058013). ~n"
END.
ELSE DO:
END.
SPONSORED LINKS
Technical <http://groups.yahoo.com/gads?t=ms&k=Technical+support&w1=Technical+support&w2=Vantage&w3=Database&w4=Database+management+software&w5=Membership+database+software&w6=Church+database+software&c=6&s=148&.sig=D_JdAFeHAoeH6OugOKk1Yg> support Vantage <http://groups.yahoo.com/gads?t=ms&k=Vantage&w1=Technical+support&w2=Vantage&w3=Database&w4=Database+management+software&w5=Membership+database+software&w6=Church+database+software&c=6&s=148&.sig=8zJYQk3edGWFMUVgup9jKw> Database <http://groups.yahoo.com/gads?t=ms&k=Database&w1=Technical+support&w2=Vantage&w3=Database&w4=Database+management+software&w5=Membership+database+software&w6=Church+database+software&c=6&s=148&.sig=PnI9nhHllVsjEbHxRXs1IQ>
Database <http://groups.yahoo.com/gads?t=ms&k=Database+management+software&w1=Technical+support&w2=Vantage&w3=Database&w4=Database+management+software&w5=Membership+database+software&w6=Church+database+software&c=6&s=148&.sig=fKR9gtx-Yh-u9MWSh0_-hA> management software Membership <http://groups.yahoo.com/gads?t=ms&k=Membership+database+software&w1=Technical+support&w2=Vantage&w3=Database&w4=Database+management+software&w5=Membership+database+software&w6=Church+database+software&c=6&s=148&.sig=Nu4StMQZ8LT26M5TzRGQlg> database software Church <http://groups.yahoo.com/gads?t=ms&k=Church+database+software&w1=Technical+support&w2=Vantage&w3=Database&w4=Database+management+software&w5=Membership+database+software&w6=Church+database+software&c=6&s=148&.sig=UAiQi3Ftbp7Qnq6ys_yZxg> database software
_____
YAHOO! GROUPS LINKS
* Visit your group " vantage <http://groups.yahoo.com/group/vantage> " on the web.
vantage-unsubscribe@yahoogroups.com <mailto:vantage-unsubscribe@yahoogroups.com?subject=Unsubscribe>
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> .
_____
Not sure if it matters, but I always use all caps for the cancel send.
It sounds like either the .p is not being called or the cancel send is being
missed.
Did you restart the vantage client between versions of the code?
Just a couple thoughts...
Aaron Hoyt
Vantage Plastics
Of al2trace
code follows
(JOB 058013). ~n"
END.
ELSE DO:
END.
Yahoo! Groups Links
Interesting point Todd,
Though in this case she actually does want an email in some cases...The ones
that I use the final Cancel Send with are ones that I want an export but
never an email to be sent. I still do get an error in the error log if
there is some problem completing processing the code. I wonder if that
might not be the problem. I will look closer at the code included.
Aaron Hoyt
Vantage Plastics
Of Todd Caughey
Sent: Friday, August 26, 2005 9:23 AM
Subject: RE: [Vantage] More BAM
-Todd C.
code follows
(JOB 058013). ~n"
END.
ELSE DO:
END.
SPONSORED LINKS
Technical
> support Vantage
Database
Database
_____
YAHOO! GROUPS LINKS
the web.
_____
Yahoo! Groups Links
Thanks for the clarification on the export angle. When I get there I would have missed that.
-Todd C.
Sent: Friday, August 26, 2005 8:30 AM
Aaron Hoyt
Vantage Plastics
Of Todd Caughey
-Todd C.
code follows
(JOB 058013). ~n"
END.
ELSE DO:
END.
SPONSORED LINKS
Technical
< http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Technical+support&w1=Technical+support&> &k=Technical+support&w1=Technical+support&
> support Vantage
< http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Vantage&w1=Technical+support&w2=Vantage> &k=Vantage&w1=Technical+support&w2=Vantage
Database
< http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Database&w1=Technical+support&w2=Vantag> &k=Database&w1=Technical+support&w2=Vantag
Database
< http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Database+management+software&w1=Technic> &k=Database+management+software&w1=Technic
< http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Membership+database+software&w1=Technic> &k=Membership+database+software&w1=Technic
< http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Church+database+software&w1=Technical+s> &k=Church+database+software&w1=Technical+s
_____
YAHOO! GROUPS LINKS
* Visit your group " vantage < http://groups.yahoo.com/group/vantage> " on
the web.
< http://docs.yahoo.com/info/terms/> .
_____
Yahoo! Groups Links
SPONSORED LINKS
_____
YAHOO! GROUPS LINKS
_____
