More barcode questions - 6.1 V526
I will see what I can do, no promise.
Maybe I can bend the ear of someone at Epicor to plan a WebEx at some point
after the event to allow an opportunity to get a similar roundtable style
event to keep the ball rolling on the BAM. In the last 6 months to year the
BAM has generated some real interest. Maybe a little working together to
might get us and Epicor both a step forward. We will see.
I appreciate the interest, and as always you can expect I will not be quiet
on the subject. :)
Aaron
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf
Of Cliff Drumeller
Sent: Wednesday, October 12, 2005 5:34 PM
Subject: RE: [Vantage] More barcode questions - 6.1 V526
Aaron
Any chance you could record your 2PM presentation ? There are a lot
of us who wish we were going to Lost Wages but are very interested in
actually both of the sessions you spoke of.
Cliff
Of Aaron Hoyt
Sent: Wednesday, October 12, 2005 2:01 PM
The BAM is only that one time.
I will also be part of the Customization Roundtable on Wed. at 3:30.
If you find me wondering aimlessly around, feel free to pull me aside
for
discussion.
This will be my first visit to Vegas, so there might be a bit of
wondering.
Aaron
Of David Gartner
Sent: Wednesday, October 12, 2005 4:53 PM
Aaron,
Are you presenting at any other time as well?
Of Aaron Hoyt
Sent: Wednesday, October 12, 2005 3:25 PM
Sure Mike,
Sorry I have been in meetings for the past couple of days, so I have
been
slow at responding.
I will not go into to much detail, but...here is a little preview of the
BAM
Customer roundtable I will be presenting in at Perspectives Monday
2:00...
BAM = Business Activity Manager (introduced in V6.0, greatly improved in
6.1) under Executive Analysis.
BAM a customizable change log. You can choose what table and what field
to
record changes to.
It has an additional function of allowing the change of the field to
trigger
a .p procedure that you have written.
This .p is originally intended to allow you to customize the email alert
that can be sent by the BAM.
Turns out you can do a whole lot more with this feature.
In the case stated, I use the .p to check a bunch of fields in a bunch
of
tables and based on the results export a .csv (comma separated values)
file
to a given location, and then call a label program using a dos prompt
command line function to print a label based on the information just
exported in the .csv format.
As long a you can find a field that will change, triggering the BAM, you
can
have the .p you write do a multitude of tasks, short of writing to the
database. That is the major limitation. You can't use a BAM to write
to
the Vantage database, but you can export in a variety of formats.
Anyway, that should give a quick overview of how the process is done.
Any questions, I will be happy to answer as time permits before
Perspectives
and after.
Good luck,
Aaron Hoyt
Vantage Plastics
Of Mike McGee
Sent: Tuesday, October 11, 2005 5:01 PM
Aaron,
Being a novice with the nuts and bolts of the software, can
you
supply some details on how you go about using the BAM to perform the
label
printing operation?
Mike
Flexial Corporation
_____
Of
Mike McGee
Sent: Tuesday, October 11, 2005 3:22 PM
What is a BAM?
Mike McGee
Flexial Corporation
_____
Of
Aaron Hoyt
Sent: Tuesday, October 11, 2005 2:54 PM
Todd,
This can be done with a BAM. I have done similar and will be expanding
as
time goes on.
You will need to be on 6.1, and have a label program to work with, but
it
can be done on your own.
Aaron Hoyt
Vantage Plastics
Of Todd Hofert
Sent: Tuesday, October 11, 2005 11:58 AM
For that matter how about inventory transfers or partial issues to
manufacturing? We have custom programming to produce our labels but I am
tried of having to pay to upgrade it. Our programming prints a label
when material is received from a job into stock, when it is transferred
to a new location or when we issue a partial quantity of an item to a
job we get a new label with remaining quantity that stays in stock.
Wouldn't mind finding a way to achieve this without the expense of
custom programming.
Of Mike McGee
Sent: Tuesday, October 11, 2005 11:52 AM
Subject: [Vantage] More barcode questions - 6.1 V526
I found in Vantage where barcode labels can be generated at PO receipt
and production receipt. Does anyone know if there is a way to print
miscellaneous barcode for other transactions? Here's an example.
100 units of a part are received on a PO and placed into stock.
50 units need to be issued to a job.
How do you barcode the 50 units moving to the job and the 50 units
remaining in stock?
Mike McGee PH: 931-432-1853
Materials Manager Fax: 931-432-1889
Flexial Corporation mmcgee@...
1483 Gould Drive www.flexial.com
Cookeville TN, 38501
NOTICE: This e-mail, including any attached files, is the property of
Flexial Corporation and as such may be legally privileged and is solely
for the intended recipient(s). Any unauthorized use, dissemination,
disclosure, copying or printing of this e-mail, or any attached file,
without the permission of Flexial Corporation is strictly prohibited.
Yahoo! Groups Links
This e-mail and any attachments may contain confidential and privileged
information. If you are not the intended recipient, please notify the
sender immediately by return e-mail, delete this e-mail and destroy any
copies. Any dissemination or use of this information by a person other
than the intended recipient is unauthorized and may be illegal.
have
and
Yahoo! Groups Links
have
and
_____
YAHOO! GROUPS LINKS
* Visit your group "vantage <http://groups.yahoo.com/group/vantage>
on the web.
* Your use of Yahoo! Groups is subject to the Yahoo!
<http://docs.yahoo.com/info/terms/> Terms of Service.
_____
have
and
_____
YAHOO! GROUPS LINKS
on the web.
_____
have
and
Yahoo! Groups Links
have
and
Yahoo! Groups Links
have
and
Yahoo! Groups Links
SPONSORED LINKS
Manufacturing software
<http://groups.yahoo.com/gads?t=ms&k=Manufacturing+software&w1=Manufactu
ring+software&w2=Membership+database+software&w3=Database+mortgage+softw
are&w4=Pda+database+software&w5=Database+management+software&w6=Database
+marketing+software&c=6&s=188&.sig=OG5F3819UOUOg63i0bu6kA>
Membership database software
<http://groups.yahoo.com/gads?t=ms&k=Membership+database+software&w1=Man
ufacturing+software&w2=Membership+database+software&w3=Database+mortgage
+software&w4=Pda+database+software&w5=Database+management+software&w6=Da
tabase+marketing+software&c=6&s=188&.sig=N5BGdur84p-jyuOomcQdbQ>
Database mortgage software
<http://groups.yahoo.com/gads?t=ms&k=Database+mortgage+software&w1=Manuf
acturing+software&w2=Membership+database+software&w3=Database+mortgage+s
oftware&w4=Pda+database+software&w5=Database+management+software&w6=Data
base+marketing+software&c=6&s=188&.sig=8rvcSQnCqJhTCZu-0Si39A>
Pda database software
<http://groups.yahoo.com/gads?t=ms&k=Pda+database+software&w1=Manufactur
ing+software&w2=Membership+database+software&w3=Database+mortgage+softwa
re&w4=Pda+database+software&w5=Database+management+software&w6=Database+
marketing+software&c=6&s=188&.sig=u3KQrTRPAQfsWIT39aHDkg> Database
management software
<http://groups.yahoo.com/gads?t=ms&k=Database+management+software&w1=Man
tabase+marketing+software&c=6&s=188&.sig=R3CF3ODPY4gwjDZjykQYvw>
Database marketing software
<http://groups.yahoo.com/gads?t=ms&k=Database+marketing+software&w1=Manu
facturing+software&w2=Membership+database+software&w3=Database+mortgage+
software&w4=Pda+database+software&w5=Database+management+software&w6=Dat
abase+marketing+software&c=6&s=188&.sig=lmBkRUiBtvHI1u5dkymDcw>
YAHOO! GROUPS LINKS
<http://groups.yahoo.com/group/vantage> " on the web.
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service <http://docs.yahoo.com/info/terms/> .
Yahoo! Groups Links
remaining in stock?
custom programming.
Of Mike McGee
remaining in stock?
------------------------ Yahoo! Groups Sponsor --------------------~-->
Most low income households are not online. Help bridge the digital
divide today!
http://us.click.yahoo.com/cd_AJB/QnQLAA/TtwFAA/PhFolB/TM
Yahoo! Groups Links
Todd,
This can be done with a BAM. I have done similar and will be expanding as
time goes on.
You will need to be on 6.1, and have a label program to work with, but it
Aaron Hoyt
Vantage Plastics
Of Todd Hofert
custom programming.
Of Mike McGee
remaining in stock?
Yahoo! Groups Links
Yahoo! Groups Links
What is a BAM?
Mike McGee
Flexial Corporation
_____
Aaron Hoyt
Todd,
time goes on.
Aaron Hoyt
Vantage Plastics
Of Todd Hofert
custom programming.
Of Mike McGee
remaining in stock?
Yahoo! Groups Links
Yahoo! Groups Links
_____
YAHOO! GROUPS LINKS
* Visit your group "vantage <http://groups.yahoo.com/group/vantage> "
on the web.
_____
Its what Emeril lagasse says when he throws some spices into the dish!! :)
sorry couldn't help my self
Bam- Business Activity Manager
Business events can trigger change logs, email, other scripts etcetera
Frank Zeigafuse
Innovative Office Products
General Manager
Direct Phone: 610-559-6369
Email: fzeigafuse@...
Visit www.one.org to see how the world can be changed one person at a time.
Sent: Tuesday, October 11, 2005 4:22 PM
What is a BAM?
Mike McGee
Flexial Corporation
_____
Aaron Hoyt
Todd,
time goes on. You will need to be on 6.1, and have a label program to work
with, but it can be done on your own. Aaron Hoyt Vantage Plastics
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf Of
Todd Hofert
tried of having to pay to upgrade it. Our programming prints a label when
material is received from a job into stock, when it is transferred to a new
location or when we issue a partial quantity of an item to a job we get a
new label with remaining quantity that stays in stock. Wouldn't mind finding
a way to achieve this without the expense of custom programming.
Mike McGee
I found in Vantage where barcode labels can be generated at PO receipt and
How do you barcode the 50 units moving to the job and the 50 units remaining
in stock?
Flexial Corporation and as such may be legally privileged and is solely for
the intended recipient(s). Any unauthorized use, dissemination, disclosure,
copying or printing of this e-mail, or any attached file, without the
Yahoo! Groups Links
information. If you are not the intended recipient, please notify the sender
immediately by return e-mail, delete this e-mail and destroy any copies. Any
dissemination or use of this information by a person other than the intended
Yahoo! Groups Links
_____
YAHOO! GROUPS LINKS
on the web.
_____
Yahoo! Groups Links
Mike
_____
Frank Zeigafuse
Sent: Tuesday, October 11, 2005 3:52 PM
Frank Zeigafuse
General Manager
What is a BAM?
Mike McGee
Flexial Corporation
_____
Aaron Hoyt
Todd,
Todd Hofert
Mike McGee
in stock?
Yahoo! Groups Links
Yahoo! Groups Links
_____
YAHOO! GROUPS LINKS
on the web.
_____
Yahoo! Groups Links
SPONSORED LINKS
Manufacturing
<http://groups.yahoo.com/gads?t=ms&k=Manufacturing+software&w1=Manufacturing
+software&w2=Membership+database+software&w3=Database+mortgage+software&w4=P
da+database+software&w5=Database+management+software&w6=Database+marketing+s
oftware&c=6&s=188&.sig=OG5F3819UOUOg63i0bu6kA> software
Membership
<http://groups.yahoo.com/gads?t=ms&k=Membership+database+software&w1=Manufac
turing+software&w2=Membership+database+software&w3=Database+mortgage+softwar
e&w4=Pda+database+software&w5=Database+management+software&w6=Database+marke
ting+software&c=6&s=188&.sig=N5BGdur84p-jyuOomcQdbQ> database software
Database
<http://groups.yahoo.com/gads?t=ms&k=Database+mortgage+software&w1=Manufactu
ring+software&w2=Membership+database+software&w3=Database+mortgage+software&
w4=Pda+database+software&w5=Database+management+software&w6=Database+marketi
ng+software&c=6&s=188&.sig=8rvcSQnCqJhTCZu-0Si39A> mortgage software
Pda
<http://groups.yahoo.com/gads?t=ms&k=Pda+database+software&w1=Manufacturing+
software&w2=Membership+database+software&w3=Database+mortgage+software&w4=Pd
a+database+software&w5=Database+management+software&w6=Database+marketing+so
ftware&c=6&s=188&.sig=u3KQrTRPAQfsWIT39aHDkg> database software
Database
<http://groups.yahoo.com/gads?t=ms&k=Database+management+software&w1=Manufac
ting+software&c=6&s=188&.sig=R3CF3ODPY4gwjDZjykQYvw> management software
Database
<http://groups.yahoo.com/gads?t=ms&k=Database+marketing+software&w1=Manufact
uring+software&w2=Membership+database+software&w3=Database+mortgage+software
&w4=Pda+database+software&w5=Database+management+software&w6=Database+market
ing+software&c=6&s=188&.sig=lmBkRUiBtvHI1u5dkymDcw> marketing software
_____
YAHOO! GROUPS LINKS
on the web.
_____
Aaron,
Being a novice with the nuts and bolts of the software, can you
supply some details on how you go about using the BAM to perform the label
printing operation?
Mike
Flexial Corporation
_____
Mike McGee
What is a BAM?
Mike McGee
Flexial Corporation
_____
Aaron Hoyt
Todd,
time goes on.
Aaron Hoyt
Vantage Plastics
Of Todd Hofert
custom programming.
Of Mike McGee
remaining in stock?
Yahoo! Groups Links
Yahoo! Groups Links
_____
YAHOO! GROUPS LINKS
on the web.
_____
_____
YAHOO! GROUPS LINKS
on the web.
_____
Sure Mike,
Sorry I have been in meetings for the past couple of days, so I have been
slow at responding.
I will not go into to much detail, but...here is a little preview of the BAM
Customer roundtable I will be presenting in at Perspectives Monday 2:00...
BAM a customizable change log. You can choose what table and what field to
record changes to.
It has an additional function of allowing the change of the field to trigger
In the case stated, I use the .p to check a bunch of fields in a bunch of
tables and based on the results export a .csv (comma separated values) file
As long a you can find a field that will change, triggering the BAM, you can
database. That is the major limitation. You can't use a BAM to write to
Any questions, I will be happy to answer as time permits before Perspectives
and after.
Good luck,
Aaron Hoyt
Vantage Plastics
Of Mike McGee
Aaron,
printing operation?
Mike
Flexial Corporation
_____
Mike McGee
What is a BAM?
Mike McGee
Flexial Corporation
_____
Aaron Hoyt
Todd,
time goes on.
Aaron Hoyt
Vantage Plastics
Of Todd Hofert
custom programming.
Of Mike McGee
remaining in stock?
Yahoo! Groups Links
Yahoo! Groups Links
_____
YAHOO! GROUPS LINKS
on the web.
_____
_____
YAHOO! GROUPS LINKS
on the web.
_____
Yahoo! Groups Links
Aaron,
Of Aaron Hoyt
Sure Mike,
slow at responding.
record changes to.
and after.
Good luck,
Aaron Hoyt
Vantage Plastics
Of Mike McGee
Aaron,
printing operation?
Mike
Flexial Corporation
_____
Mike McGee
What is a BAM?
Mike McGee
Flexial Corporation
_____
Aaron Hoyt
Todd,
time goes on.
Aaron Hoyt
Vantage Plastics
Of Todd Hofert
custom programming.
Of Mike McGee
remaining in stock?
Yahoo! Groups Links
Yahoo! Groups Links
_____
YAHOO! GROUPS LINKS
on the web.
_____
_____
YAHOO! GROUPS LINKS
on the web.
_____
Yahoo! Groups Links
Yahoo! Groups Links
If you find me wondering aimlessly around, feel free to pull me aside for
discussion.
This will be my first visit to Vegas, so there might be a bit of wondering.
Aaron
Of David Gartner
Aaron,
Of Aaron Hoyt
Sure Mike,
slow at responding.
record changes to.
and after.
Good luck,
Aaron Hoyt
Vantage Plastics
Of Mike McGee
Aaron,
printing operation?
Mike
Flexial Corporation
_____
Mike McGee
What is a BAM?
Mike McGee
Flexial Corporation
_____
Aaron Hoyt
Todd,
time goes on.
Aaron Hoyt
Vantage Plastics
Of Todd Hofert
custom programming.
Of Mike McGee
remaining in stock?
Yahoo! Groups Links
Yahoo! Groups Links
_____
YAHOO! GROUPS LINKS
on the web.
_____
_____
YAHOO! GROUPS LINKS
on the web.
_____
Yahoo! Groups Links
Yahoo! Groups Links
Yahoo! Groups Links
Aaron
Cliff
Of Aaron Hoyt
for
discussion.
wondering.
Aaron
Of David Gartner
Aaron,
Of Aaron Hoyt
Sure Mike,
been
slow at responding.
BAM
2:00...
to
record changes to.
trigger
of
file
can
to
Perspectives
and after.
Good luck,
Aaron Hoyt
Vantage Plastics
Of Mike McGee
Aaron,
you
label
printing operation?
Mike
Flexial Corporation
_____
Of
Mike McGee
What is a BAM?
Mike McGee
Flexial Corporation
_____
Of
Aaron Hoyt
Todd,
as
time goes on.
it
Aaron Hoyt
Vantage Plastics
Of Todd Hofert
custom programming.
Of Mike McGee
remaining in stock?
Yahoo! Groups Links
have
and
Yahoo! Groups Links
have
and
_____
YAHOO! GROUPS LINKS
on the web.
_____
have
and
_____
YAHOO! GROUPS LINKS
on the web.
_____
have
and
Yahoo! Groups Links
have
and
Yahoo! Groups Links
have
and
Yahoo! Groups Links
SPONSORED LINKS
management software
YAHOO! GROUPS LINKS
I second that!
Ann
--- In vantage@yahoogroups.com, "Cliff Drumeller" <cliff@m...> wrote:
> Aaron
a lot
in
> Cliff
Behalf
> Of Aaron Hoyt
3:30.
aside
> for
> discussion.
> wondering.
> Aaron
Behalf
> Of David Gartner
> Aaron,
Behalf
> Of Aaron Hoyt
> Sure Mike,
have
> been
> slow at responding.
of the
> BAM
> 2:00...
improved in
field
> to
> record changes to.
to
> trigger
alert
bunch
> of
values)
> file
prompt
just
BAM, you
> can
the
write
> to
done.
> Perspectives
> and after.
> Good luck,
> Aaron Hoyt
> Vantage Plastics
Behalf
> Of Mike McGee
> Aaron,
software, can
> you
the
> label
> printing operation?
> Thanks,
> Mike
> Flexial Corporation
> _____
Behalf
> Of
> Mike McGee
> What is a BAM?
> Mike McGee
> Flexial Corporation
> _____
Behalf
> Of
> Aaron Hoyt
> Todd,
expanding
> as
> time goes on.
but
> it
> Aaron Hoyt
> Vantage Plastics
Behalf
> Of Todd Hofert
but I am
label
transferred
to a
> custom programming.
Behalf
> Of Mike McGee
receipt
print
> remaining in stock?
> Thanks
> Flexial Corporation mmcgee@f...
of
solely
file,
prohibited.
must
access. )
Builder
> Yahoo! Groups Links
privileged
the
destroy any
other
must
> have
Builder
> and
> Yahoo! Groups Links
must
> have
Builder
> and
> _____
> YAHOO! GROUPS LINKS
> on the web.
> _____
must
> have
Builder
> and
> _____
> YAHOO! GROUPS LINKS
> on the web.
> _____
must
> have
Builder
> and
> Yahoo! Groups Links
must
> have
Builder
> and
> Yahoo! Groups Links
must
> have
Builder
> and
> Yahoo! Groups Links
must
access. )
Builder
> SPONSORED LINKS
ftw
ase
age
=Da
e+s
ata
twa
se+
Database
> management software
age
=Da
ge+
Dat
> YAHOO! GROUPS LINKS
