More Dashboard Help
I figured I would cover both:).
Additionally...
The instructions I gave you was for Searching using a BAQ. However;
if you want to retrieve and display the results of a dashboard within
a sheet/form, then that is the other really cool functionality they
added to 8.03.403x . And it is called the URL/XSLT View. Again...if
you have the User Guide Tools book, it starts on page 359. If you
don't have the book...get it!!!
The XSLT View functionality is a little more complicated than the
quick search. So if you have questions on how to...either refer to
the book or call Epicor Tech Support (Option 3 then 4).
Patty Buechler
--- In vantage@yahoogroups.com, "Sean Toler" <seantoler@...> wrote:
> Hey! Didn't you just reply to this on the Epicor Forums? :)
> --- In vantage@yahoogroups.com, "bpbuechler" <pbuechler@> wrote:
> > When they came out with 8.03.403x, they added this really cool
> > functionality called Quick Search. Do you have the Tools User
> > Guide? If not, get it!!!! If you do, it's on Page 260.
> > So I too noticed in 8.03.403C, the Basic search does not work for
> > Where Description Contains...no biggie...here is how you can get
> > around the bug:
> > 1. Security...you must have security to do Quick Search Entry.
> Open
> > User Security and go to the Security tab. Grant access to
yourself
> > for 'Can Maintain Quick Search'. Logout and back in.
> > 2. Open Part Entry or Part Tracker.
> > 3. Right Click in the Description field and choose Quick Search
> > Entry.
> > 4. Give it an ID & Description
> > 5. Find your BAQ (it should be a simple query on the Part and
> Plant
> > tables displaying Part, Part Description, etc)
> > 6. Return Column = Part.PartDesciption
> > 7. Check the Shared and All Occurances checkboxes
> > 8. New Quick Search Criteria
> > 9. Click on the drop down and choose Part.PartDescription
> > 10. Caption = Description
> > 11. Condition = Matches
> > 12. Criteria Type = Prompt
> > 13. Save & Close.
> > 14. Now Right Click on the Description field...you should be
> > prompted with your Quick Search
> > *abc* will find anything in your DB that has a part description
> that
> > contains abc. *abc will find anything that ends with abc. And
> abc*
> > will find anything that starts with abc.
> > Hope this helps.
> > Thanks
> > Patty Buechler
> > --- In vantage@yahoogroups.com, "Sean Toler" <seantoler@> wrote:
> > > 8.03.403C
> > > > What version are you on?
wrote:
> > > > > Hello.
> > > > > I have recently created a dashboard for use throughout our
> > > company.
> > > > I
> > > > > am still very new to dashboards and I was wondering if
there
> is
> > a
> > > way
> > > > > to add the new dashboard to the "Open with" list that pops
> open
> > > when
> > > > > right-clicking on part numbers.
> > > > > Thanks.
Hello.
I have recently created a dashboard for use throughout our company. I
am still very new to dashboards and I was wondering if there is a way
to add the new dashboard to the "Open with" list that pops open when
Thanks.
> Hello.
I
> Thanks.
8.03.403C
> > Hello.
company.
> I
way
when
> > Thanks.
around the bug:
1. Security...you must have security to do Quick Search Entry. Open
User Security and go to the Security tab. Grant access to yourself
Entry.
5. Find your BAQ (it should be a simple query on the Part and Plant
13. Save & Close.
*abc* will find anything in your DB that has a part description that
contains abc. *abc will find anything that ends with abc. And abc*
Hope this helps.
Patty Buechler
> 8.03.403C
> > > Hello.
> company.
> > I
a
> way
> when
> > > Thanks.
> around the bug:
Open
> Entry.
Plant
> 13. Save & Close.
that
abc*
> Hope this helps.
> Thanks
> Patty Buechler
> > 8.03.403C
> > > > Hello.
> > company.
> > > I
is
> a
> > way
open
> > when
> > > > Thanks.
