Hi all
Just putting it out there as a generic question to see if anyone else has had issues with the AR Form specifically moving across different versions.
In our experience, we are trying to move the AR Form we have set up in Epicor 10 over to the new Kinetic environment and running into a whole host of issues. We’ve even tried moving the Standard SSRS AR Form and dataset from Epicor 10 to Kinetic and even that fails with the below errors. We are more thinking this could be a version issue but wondered if anyone else has run into this issue at all? To note, other SSRS reports from Epicor 10 have worked without issue i.e. Order Ack / POForm etc
Thanks all!!
Program Ice.Services.Lib.RunTask when executing task 371 raised an unexpected exception with the following message: RunTask:
Ice.Core.SsrsReporting.SsrsCaller.SsrsException: The SSRS server returned the status code 500 (InternalServerError) with the following error text:
An error has occurred during report processing. —> Microsoft.ReportingServices.ReportProcessing.ProcessingAbortedException: An error has occurred during report processing. —> Microsoft.ReportingServices.ReportProcessing.ReportProcessingException: Query execution failed for dataset ‘ARForm’. —> System.Data.SqlClient.SqlException: Invalid column name ‘Calc_MtExtPrice’.
Invalid column name ‘ProbReasonCode’.
at Ice.Core.SsrsReporting.SsrsCaller.SoapCaller.Call[TContent,TResponse,TSoapHeader](String actionName, TContent content, TSoapHeader soapHeader) in C:_releases\ICE\ICE4.3.100.11\Source\Server\Internal\Lib\TaskLib\SsrsReporting\SsrsCaller\SoapCaller.cs:line 47
at Ice.Core.SsrsReporting.SsrsCaller.ReportExecutionService.Render(String format, String deviceInfo, String& extension, String& mimeType, String& encoding, Warning& warnings, String& streamIds) in C:_releases\ICE\ICE4.3.100.11\Source\Server\Internal\Lib\TaskLib\SsrsReporting\SsrsCaller\ReportExecutionService.cs:line 75
at Ice.Core.SsrsReporting.SsrsRendererBase.Render(SsrsRenderInformationBase renderInformation) in C:_releases\ICE\ICE4.3.100.11\Source\Server\Internal\Lib\TaskLib\SsrsReporting\SsrsRendererBase.cs:line 143
at Ice.Core.SsrsReporting.SsrsSingleDocumentRenderer.<>c__DisplayClass1_0.b__0() in C:_releases\ICE\ICE4.3.100.11\Source\Server\Internal\Lib\TaskLib\SsrsReporting\SsrsSingleDocumentRenderer.cs:line 49
at Ice.Core.SsrsReporting.SsrsRendererBase.TraceReportRendered(String printProgram, String ssrsRenderFormat, Func`1 timedAction) in C:_releases\ICE\ICE4.3.100.11\Source\Server\Internal\Lib\TaskLib\SsrsReporting\SsrsRendererBase.cs:line 81
