I just did exactly that a few weeks ago. We replaced our old 32 bit server with a new 64 bit server.
I did a complete new installation of Open Edge and Vantage on the new server. I did all of the setup for the database and App servers manually on the new machine from within progress explorer. I then restored the database from the existing server to the new one. We spent a week or so testing on the new server just to ensure there were not issues. Yes, I did have to copy over the customer report folders, pcrules, etc, but that was a fairly simple process.
I actually made the change to the new server one evening after work. I did an offline backup of the database on the old server. I then renamed it and shut it down. I renamed the new server to the same name as our old one. I then modified the necessary configuration files on the server to indicate the new name. I restored the data I just backup up off the old server. I then started the database and all the appservers and we were up and going. This required approximately 30 minutes to perform. The users never knew the difference.
Since we used the same name as the old one I did not have to update any of the configuration files on the client machines.
I do hope you went with a 64bit machine with plenty of memory for you new server. I put 32GB of memory in our new server. What a difference it made in certain areas, e.g. a full Regen of MRP went from 8 hours to 2 hours (400% improvement).
vantage@yahoogroups.com [mailto:
vantage@yahoogroups.com] On Behalf Of Calvin Krusen
Sent: Tuesday, July 15, 2008 10:57 AM
To:
Subject: [Vantage] Moving DB to new server - [V8.03.403D / OE 10.1B]
Has anyone moved their installation of Vantage/Vista from one server
to another? And not just to a new box with the same server name.
Our existing installation is on \\FS1 and we have a new server \\APP1
just for Vantage.
So far the install of Progress and Vantage, plus a restore of our
live DB to the new server has gone smooth. But we've only tested
running vantage from the server itself, not from any clients.
Would it be better to restore \\FS1\epicor\MfgSys803\{all files &
subs} to \\APP1 (using our daily fileserver backup), or to just
retore the db (using Progress prorest.exe) and then manually copy all
the 'user files' (meaning our company as a Epicor user, not the
individual users).
So far I found that I'll need to copy:
1. Reports {\mfgSys803\Server\reports}
2. Attachments {\mfgSys803\Server\docmt}
3. BPM Code {\mfgSys803\bpm\bo}
4. Configurator Rules {\mfgSys803\Server\pcrules}
5. Alerts Code{\mfgSys803\Server\ud\alerts}
4. Configurator files {\mfgSys803\Server\ud\ProdCfg}
Anything else?
Calvin
DISCLAIMER:
This e-mail, including attachments, may include confidential and/or proprietary information, and may be used only by the person or entity to which it is addressed. If the reader of this e-mail is not the intended recipient or his or her authorized agent, the reader is hereby notified that any dissemination, distribution or copying of this e-mail is prohibited. If you have received this e-mail in error, please notify the sender by replying to this message and delete this e-mail immediately.
