Moving from 8.03.305 to 9.05
Talk to your CAM for the media.
What you need is as follows
Vantage Media - should already have it
Vantage license files/keys
Epicor 9.04 Media
Epicor 9.04 License file
Epicor 9.05 Media
Epicor 9.05 license file
"Zac" Jason Woodward
Network Administrator
Intermountain Electronics, Inc.
O: 877-544-2291
M: 435-820-6515
F: 435-637-9601
www.ie-corp.com
Creating customer confidence through extraordinary service and experienced industry experts.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Mark
Sent: Wednesday, August 31, 2011 10:40 AM
Subject: [Vantage] Re: Moving from 8.03.305 to 9.05
I am setting up the temporary servers but I only have the Epicor media for 8.03 and 9.05. Is there somewhere I can download the install or ISO files for 8.03.400 and 9.04? The only thing I see on EpicWeb is the patches and service packs. I believe I can install 8.03 and upgrade it to 8.03.400 but the install instructions say to install OpenEdge 10.1B which isn't on the media I have.
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Zac Jason Woodward <zac@...> wrote:
> Red Hat Enterprise Virtualization... performs great, however, due to a bug with it and windows I can no longer recommend it. I am in the process of getting ready to test with Citrix Xen.
> O: 877-544-2291
> M: 435-820-6515
> F: 435-637-9601
> www.ie-corp.com
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of rlsand50
> Sent: Tuesday, August 30, 2011 1:40 PM
> Are we talking VMware or Hyper-V VMs?
> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>, Waffqle <waffqle@> wrote:
> > I can vouch for that. We've also found that running conversions/schema
> > changes from a separate machine drastically increases the required time.
> > On Tue, Aug 30, 2011 at 1:07 PM, Zac Jason Woodward <zac@> wrote:
> > > Reason for the x32 stage is that I found it is significantly faster to do
> > > the upgrade there then move it to x64. When I did my testing before we went
> > > live it shaved 4 -6 hours off of the Schema changes/ Conversions.
> > > O: 877-544-2291
> > > M: 435-820-6515
> > > F: 435-637-9601
> > > www.ie-corp.com
> > > industry experts.
> > > From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On Behalf
> > > Of Mark
> > > Sent: Tuesday, August 30, 2011 10:37 AM
> > > To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
> > > Thanks for the detailed information. I hadn't even thought about the x32 to
> > > x64 change. Thank goodness for virtual servers or I would have a heck of a
> > > time.
> > > --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>, Zac
> > > > (progress only. Not sure about MSSQL paths)
> > > > 803 - Current server
> > > > 803.xxx - Temp VM, Latest patch. Restore current DB here. Run updates,
> > > run UOM prep and take time with it, backup DB
> > > > 9.04 - Temp VM, Restore DB, Run Schema change, reboot, install 904
> > > license, reboot, run conversions, backup DB
> > > > 9.05 x32 - temp VM if upgrading to x64 server, restore db, run schema
> > > change, reboot, install 905 license, reboot, run conversion, backup DB
> > > > 9.05 x64 - final live server, restore db, should be good.
> > > > O: 877-544-2291
> > > > M: 435-820-6515
> > > > F: 435-637-9601
> > > > www.ie-corp.com
> > > > From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> [mailto:
> > > vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On Behalf Of
> > > cooner_55421
> > > > Sent: Tuesday, August 30, 2011 10:03 AM
> > > > To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
> > > > I believe you must upgrade to 8.03.409C before moving to E9.
> > > > If you have performed patch upgrades before, you will find it is not very
> > > involved.
> > > > However, the patch/upgrade instructions leave something to be desired, so
> > > I would run all the upgrade(s) on a test server first... kust to verify you
> > > have all the steps down.
> > > > --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:
> > > vantage%40yahoogroups.com>, "Mark" <mtellefson@> wrote:
> > > > > We have been running 8.03.305 on a server that for a long time limitted
> > > our ability to upgrade. It is also the domain controller and print/file
> > > server and had limitted available space so I didn't even dare try to move to
> > > 8.03.4xx.
> > > > > We now replacing our old physical servers with virtual servers. I have
> > > setup a 9.05 virtual server following Epicor's recommendations. In order to
> > > convert all our existing data to the new server will I also need to create
> > > temporary 8.03.4xx and 9.04 servers? The instructions refer to running the
> > > 8.03.40x to 9.04 conversions first but I am unsure about the 8.03.305 to
> > > 8.03.40x.
> > > > > Any other recommendations would be greatly appreciated as well.
> > > > > Mark
> > > > [Non-text portions of this message have been removed]
> > *Waffqle Driggers*
> > *High End Dev, System Design, Profit Drinking
> > *:: 904.962.2887*
> > *:: waffqle@*
> > *:: NO FAXES*
We have been running 8.03.305 on a server that for a long time limitted our ability to upgrade. It is also the domain controller and print/file server and had limitted available space so I didn't even dare try to move to 8.03.4xx.
We now replacing our old physical servers with virtual servers. I have setup a 9.05 virtual server following Epicor's recommendations. In order to convert all our existing data to the new server will I also need to create temporary 8.03.4xx and 9.04 servers? The instructions refer to running the 8.03.40x to 9.04 conversions first but I am unsure about the 8.03.305 to 8.03.40x.
Mark
If you have performed patch upgrades before, you will find it is not very involved.
However, the patch/upgrade instructions leave something to be desired, so I would run all the upgrade(s) on a test server first... kust to verify you have all the steps down.
> Mark
803.xxx - Temp VM, Latest patch. Restore current DB here. Run updates, run UOM prep and take time with it, backup DB
9.04 - Temp VM, Restore DB, Run Schema change, reboot, install 904 license, reboot, run conversions, backup DB
9.05 x32 - temp VM if upgrading to x64 server, restore db, run schema change, reboot, install 905 license, reboot, run conversion, backup DB
O: 877-544-2291
M: 435-820-6515
F: 435-637-9601
www.ie-corp.com
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of cooner_55421
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, "Mark" <mtellefson@...> wrote:
> Mark
Thanks for the detailed information. I hadn't even thought about the x32 to x64 change. Thank goodness for virtual servers or I would have a heck of a time.
> O: 877-544-2291
> M: 435-820-6515
> F: 435-637-9601
> www.ie-corp.com
> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, "Mark" <mtellefson@> wrote:
> > Mark
Reason for the x32 stage is that I found it is significantly faster to do the upgrade there then move it to x64. When I did my testing before we went live it shaved 4 -6 hours off of the Schema changes/ Conversions.
O: 877-544-2291
M: 435-820-6515
F: 435-637-9601
www.ie-corp.com
> O: 877-544-2291
> M: 435-820-6515
> F: 435-637-9601
> www.ie-corp.com
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of cooner_55421
> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>, "Mark" <mtellefson@> wrote:
> > Mark
> O: 877-544-2291
> M: 435-820-6515
> F: 435-637-9601
> www.ie-corp.com
> industry experts.
> Of Mark
> time.
> > O: 877-544-2291
> > M: 435-820-6515
> > F: 435-637-9601
> > www.ie-corp.com
> cooner_55421
> involved.
> 8.03.4xx.
> 8.03.40x.
> > > Mark
*Waffqle Driggers*
*:: 904.962.2887*
*:: waffqle@...*
*:: NO FAXES*
Also, as long as you have the drive space, you can put 8.03.409C, 9.04 and
the x32 bit version of 9.05 all on the same server, there is no need to have
a different server for each one. As long as you are not running more than
one at the same time you don't need to concern yourself with the registry
edit to be able to run them.
I usually add a folder in the Epicor folder called Update. I use this for my
DB location during the updating process and make sure I change the location
of the DB in the PET for each DB in each version of OpenEdge, as well as
updating the .pf file for each version as well.
Then, when you are going through the process you only need to do a backup in
between each version instead of a backup and restore. I also tend to leave
the backups right in that folder as well so I end up with a whole set of
backups from each step. Also means you can just stop one version of openedge
and start up the next version and not have to worry about moving any files
around.
original.bkup - backup from 8.03.50x
schema.803 - backup after 8.03.50x schema change
conversions.803 - backup after 8.03.40x conversions
schema.904 - backup after 9.04.50x schema change
conversions.904 - backup after 9.04.50x conversions
schema.905 - backup after 9.05.60x schema change
conversions.905 - backup after 9.05.60x conversions
I would also suggest renaming the Proenv and Progress explorer tool to tag
the version number on the end of it when you have multiple versions on the
same machine, especially since Win 2008 adds icons to the shortcut are of
the start menu and it's annoying to click on one and end up finding it to be
the wrong version that you need.
> O: 877-544-2291
> M: 435-820-6515
> F: 435-637-9601
> www.ie-corp.com
> industry experts.
> Of Mark
> time.
> > O: 877-544-2291
> > M: 435-820-6515
> > F: 435-637-9601
> > www.ie-corp.com
> cooner_55421
> involved.
> 8.03.4xx.
> 8.03.40x.
> > > Mark
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
> http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
> > O: 877-544-2291
> > M: 435-820-6515
> > F: 435-637-9601
> > www.ie-corp.com
> > industry experts.
> > Of Mark
> > time.
> > > O: 877-544-2291
> > > M: 435-820-6515
> > > F: 435-637-9601
> > > www.ie-corp.com
> > cooner_55421
> > involved.
> > 8.03.4xx.
> > 8.03.40x.
> > > > Mark
> *Waffqle Driggers*
> *:: 904.962.2887*
> *:: waffqle@...*
> *:: NO FAXES*
Mark where did you get Epicors recommendations? Can I get a copy?
> Mark
O: 877-544-2291
M: 435-820-6515
F: 435-637-9601
www.ie-corp.com
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of rlsand50
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Waffqle <waffqle@...> wrote:
> > O: 877-544-2291
> > M: 435-820-6515
> > F: 435-637-9601
> > www.ie-corp.com
> > industry experts.
> > Of Mark
> > time.
> > --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>, Zac
> > > O: 877-544-2291
> > > M: 435-820-6515
> > > F: 435-637-9601
> > > www.ie-corp.com
> > vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On Behalf Of
> > cooner_55421
> > involved.
> > 8.03.4xx.
> > 8.03.40x.
> > > > Mark
> *Waffqle Driggers*
> *:: 904.962.2887*
> *:: waffqle@...*
> *:: NO FAXES*
It was a combination of the Install Guide and a VMware document:
http://www.vmware.com/files/pdf/techpaper/VMware_and_Epicor_Deployment_Guide.pdf
> > Mark
Thanks Mark I am sure this will be very helpful as we move forward
> > > Mark
OK thanks!
> O: 877-544-2291
> M: 435-820-6515
> F: 435-637-9601
> www.ie-corp.com
> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Waffqle <waffqle@> wrote:
> > > O: 877-544-2291
> > > M: 435-820-6515
> > > F: 435-637-9601
> > > www.ie-corp.com
> > > industry experts.
> > > Of Mark
> > > time.
> > > > O: 877-544-2291
> > > > M: 435-820-6515
> > > > F: 435-637-9601
> > > > www.ie-corp.com
> > > cooner_55421
> > > involved.
> > > 8.03.4xx.
> > > 8.03.40x.
> > > > > Mark
> > *Waffqle Driggers*
> > *:: 904.962.2887*
> > *:: waffqle@*
> > *:: NO FAXES*
> O: 877-544-2291
> M: 435-820-6515
> F: 435-637-9601
> www.ie-corp.com
> > > O: 877-544-2291
> > > M: 435-820-6515
> > > F: 435-637-9601
> > > www.ie-corp.com
> > > industry experts.
> > > Of Mark
> > > time.
> > > > O: 877-544-2291
> > > > M: 435-820-6515
> > > > F: 435-637-9601
> > > > www.ie-corp.com
> > > cooner_55421
> > > involved.
> > > 8.03.4xx.
> > > 8.03.40x.
> > > > > Mark
> > *Waffqle Driggers*
> > *:: 904.962.2887*
> > *:: waffqle@*
> > *:: NO FAXES*
