Moving Jobs Out
Hi Toby,
Our customers dictate when a job is due also and we are constantly moving dates in and out, which makes planning and scheduling very difficult. I am currently modifying our Shipl(the Project Planners bible) report to look at this data and tell us if the job as moved in or out of a certain date range. I will hopefully be done by the end of the week. I can share the report with you if you like.
Regards,
Jill Pleau
Mid-State Machine Products
--- In vantage@yahoogroups.com, Jonathan Lang <lsbestinc@...> wrote:
> Toby,
> Â
> Â
> Actually no, Purchasing did do their job and it shows. If the Scheduler moves the job up then she gets a warning that inventory cannot be met and that the job cannot start at that date. If the Scheduler forces the issue, besides the need to fire this individual, you need to setup a BAM to warn you of this event and to e-mail the Purchaser.
> Â
> The bottom line is that you cannot produce what you don't have. I am sure your company is trying to be as lean as possible. If the scheduler and the Purchaser are having issues on availability of product or the Scheduler does not understand Purchasing job then perhaps a meeting is well over due. Communication helps prevent mistakes and catastrophes.
> Â
> Jonathan LangÂ
> Oil Rite Corporation
> Sr. Network Administrator
> Ph: (920) 682-6173 Ext: 126
> Fax: (920) 682-7699
> --- On Wed, 3/4/09, Toby Boogerd <tboogerd@...> wrote:
> From: Toby Boogerd <tboogerd@...>
> Subject: [Vantage] Moving Jobs Out
> To: vantage@yahoogroups.com
> Date: Wednesday, March 4, 2009, 9:59 AM
> Often times our purchasing department will order material to create a
> part based on the job and it's start date. So if a job is scheduled to
> start 3/20/09 and it takes a week for the raw material to arrive, a
> purchaser will then make sure to order the raw material by 3/12/09. Now
> lets say the material arrives into inventory and scheduling moved the
> jobs date out to 5/20/09. It now appears that purchasing didn't do their
> job right because they ordered material too early and we sit with it in
> inventory for an extra 2 months, when in fact that isn't true because
> scheduling moved the job out. Oh this happens a lot.
> I am in the process of creating a report to see all jobs that get moved
> out. I am using the JobHead and ChgLog table. I am planning on using the
> LogText field which contains the info on someone who moved a scheduled
> start date of the job out. The issue is I have to iterate through that
> field and look for the text. I currently am using mid() function which
> will find me the words sched. Due but if it isn't the first record I
> need to iterate until I find that wording.
> Does anyone know how to do this in crystal, or have a better method of
> capturing when a job date is moved out so that you can pull that job
> number and gets its cost to show how much inventory we are carrying due
> to the fact of jobs getting moved out?
> Toby Boogerd
> Information Systems
> 712.324.4854 | tboogerd@rosenboom. com <mailto:tboogerd@rosenboom. com>
> NOTICE: This email may contain confidential and proprietary information
> of Rosenboom Machine & Tool, Inc. By opening any enclosed files, the
> recipient agrees not to use, reproduce, disclose, or manufacture its
> contents, in whole or in part, without prior written consent of
> Please consider the environment before printing this email.
Toby Boogerd
Information Systems
712.324.4854 | tboogerd@... <mailto:tboogerd@...>
Toby,
Â
Â
Â
Â
Jonathan LangÂ
Fax: (920) 682-7699
Toby Boogerd
Information Systems
