MRP failing - any ideas?
Have you run a more detailed log message to see exactly which part your
MRP process is failing on?
Rob Bucek
Manufacturing Engineer
PH: (715) 284-5376 ext 311
Mobile: (715)896-0590
FAX: (715)284-4084
<http://www.dsmfg.com/>
(Click the logo to view our site) <http://www.dsmfg.com/>
Of Stephen Edginton
Sent: Tuesday, June 29, 2010 7:43 PM
Subject: RE: [Vantage] MRP failing - any ideas?
This looks like some custom code is being called it looks like something
is supposed to be performing an issue but for whatever reason not
entering a quantity.
Check for any custom code around the MRP process
Regards,
Stephen
Behalf
Of jortega4087
Sent: 30 June 2010 01:31
Subject: [Vantage] MRP failing - any ideas?
Anybody out there run into this issue before or know where I can start
looking for the problem?? We are on 408a and for the past couple days
mrp has been failing to complete with the following message.
Type: 3
Program: bo/issuereturn.r
Method: ValidatetranQty
Table:IssueReturn
Field: TranQty
Message: A valid quantity is required.
Anybody out there run into this issue before or know where I can start looking for the problem?? We are on 408a and for the past couple days mrp has been failing to complete with the following message.
Type: 3
Table:IssueReturn
Field: TranQty
Regards,
Stephen
Of jortega4087
Type: 3
Table:IssueReturn
Field: TranQty
This happened to us at one point. It ended up being related to having
un-approved revisions on parts.
Sharon Pulsifer
Fibrebond Corporation
http://www.fibrebond.com <http://www.fibrebond.com/>
318-371-6347
