MRP not showing demand / Creating jobs for sub-assemblies
Rob,
We went that exact way, but still not showing demand. The issue has been escalated to the developer level at Epicor. I was hoping that it happened before to someone, and bypass the probing time...
Thanks!
Paul
--- In vantage@yahoogroups.com, robertb_versa@... wrote:
> Have you played around with your fab subassy part levels in regard to all possible combos of non-stock & phantom?
> (Yes - pull & view as assy set up in multilevel MOM SHOULD over-ride these part & partplant settings - but Vantage MRP & job scheduling is weak (and that's being kind) so it's worth a shot.)
> Also (for testing) use a MasterOp/ResourceGroup/Resource model that is ULTRA simple (& infinite capacity). Use same resource for each OP when testing. I'd also use VERY short LT for each part level (1-10 days max) to make sure you aren't exceeding MRP & Scheduler window/fence you may have unwittingly imposed.
> Finally - Make sure all parts you are testing w/ have a clean harmless part class (to insure no over-riding to part/partplant is occuring).
> Oh yeah: make your resource group/resource fully set up w/ valid In, Out, Bacflush whse bins & set for automove.
> Question: You DO have AMM (right?) If not, I don't believe multileg jobs will function.
> Rob
> --- Original Message ---
> From:"PaulS" <psiebers@...>
> Sent:Tue 4/6/10 11:06 am
> To:vantage@yahoogroups.com
> Subj:[Vantage] Re: MRP not showing demand / Creating jobs for sub-assemblies
> -We have ran any possible combination of settings on the pull as and view as check boxes followed by an MRP run each time, just so we could get a grip on what exactly MRP is doing with these flags set.
> According to 5446MPS "having View checked and Pull cleared is a valuable way to view the depth of materials for any given BOM, but still make sure that the job records demands against inventory for any given part on the job."
> I have created a part for testing purposes. The main assembly consists out of a purchased part and Sub Assembly 1. Sub 1 consists out of another purchased part and Sub Assembly 2. Sub 2 consists out of a single purchased part.
> Running MRP with View checked only creates the following demands (D) only:
> TOP(D) - PP0(D)
> - SUB1(D)
> -PP1
> -SUB2
> -PP2
> Vantage seems to ignore everything beyond the SUB1 level, including the purchased part required to build SUB1. All the required MRP flags are set at the part level, as are lead times long enough to require immediate demand after running MRP.
> I can create a job for the suggestion for the TOP level part, and then after running MRP, demand trickles down to the next level. After creating another job for that level the demand finally arrives at the bottom. We can't rely on manually pushing down demand, and we would like to have demand show for all of the involved parts irregardless of the subassembly level they are in.
> In the meanwhile Epicor has been working it as an issue over the last week or so. No results so far, I am just wondering if anyone has come across this type of behavior....
> Paul
> --- In vantage@yahoogroups.com, "Nancy" <nhoyt111@> wrote:
> > Hi Paul,
> > We are in the midst of an Epicor 9 implementation and trying to get a handle on how best to upload our parts and methods data.
> > Have you dealt with a "Pull as assembly" checkbox at all? I'm not sure if you have it in vantage, but in Epicor 9 Help file states:
> > "Pull As Assembly
> > Select this check box to indicate that this material requirement should be manufactured as it is needed. Clear the check box to indicate that this material requirement should be pulled from stock.
> > If the check box is cleared, the material will be pulled into the job/quote as a material, with no related manufacturing details. If the check box is selected, the material will create an assembly record on the job/quote, and all material and operation manufacturing details will be pulled over."
> > I think that this means that subassemblies that are not planned to be kept in stock should be checked for "pull as assembly" to see the job for them made in association with a top level job.
> > Please keep us up to date on what your findings are.
> > Thanks,
> > Nancy Hoyt
> > --- In vantage@yahoogroups.com, "PaulS" <psiebers@> wrote:
> > > This is getting interesting and scary at the same time:
> > > As far as I can see all involved parts are set up correctly. Running MRP generates deman
All,
This seemed to be easier in 6, but in Vantage 8, how do I get demand to show for all purchased parts involved in the scheme below, and how do I create individual jobs for the child-assemblies?:
Parent
Child 1
Child 2
Scenario:
A sales order is placed for the parent part. The parent part is built with two child assemblies (that we build based on demand, but not stock in advance). The child assemblies are mixes of purchased parts and manufactured parts.
We have been playing with Pull as Assembly and View as Assembly and we are not getting anywhere close to the result we would like to see. What flags need to be set in order for us to see demand for all parts involved? What is making this extra challenging is that we have to create individual jobs for each child, and we would like MRP to create unfirm jobs for each part when a sales order is placed for the parent part.
Thanks in advance...
Paul
Probably a dumb question, but.... Do you have your "Make Direct" and/or "Purchase Direct" flags checked...
Regards.
Roel Martinez
ERP Analyst
SABRE TUBULAR STRUCTURES (tm)
www.sabretubularstructures.com<http://www.sabretubularstructures.com/>
8653 E. Hwy 67 | Alvarado, TX 76009
Phone: 817-852-1700 ext. 11858 | Direct Line: 817-852-1858 |Fax: 817-852-1705
[cid:image002.jpg@01CACCED.322F3330]
Sabre Industries, Inc. ("Sabre") E-MAIL NOTICE - This transmission and any attachments may be confidential or subject to a legally recognized privilege and is intended only to be received and read by the proper party having a reason to send communications to or from Sabre. If you do not believe that you are the proper recipient of this message because of its address, contents and/or otherwise believe that this message was sent to you in error, you should not disclose, print, copy or disseminate the information contained in this message. If you have received this in error, please reply and notify the sender (only) and delete the message. Unauthorized interception of this e-mail is a violation of federal criminal law and state laws.
The text in this communication does not reflect an intention by Sabre to conduct a transaction or make any agreement by electronic means. Only a document which bears a handwritten signature of an authorized signatory of Sabre shall be binding upon Sabre and such documents may be attached indicating a desire to conduct a transaction or make any agreement. Nothing contained in the text of this message shall satisfy the requirements for a writing, and nothing contained herein shall constitute a contract or electronic signature under the Electronic Signatures in Global and National Commerce Act, any version of the Uniform Electronic Transactions Act or any other statute governing electronic transactions or any statutory adoptions or equivalents of the aforementioned acts and convention, and any other laws or regulations of any state or country related to electronic contracts, electronic signatures, or electronic records shall not apply to Sabre or the recipient.
Make sure process MRP is checked in the part entry under the plant tab
as well. For nonstock parts (piece parts) make direct is what you want
to do there.
Rob Bucek
Manufacturing Engineer
PH: (715) 284-5376 ext 3111
FAX: (715)284-4084
<http://www.dsmfg.com/>
(Click the logo to view our site) <http://www.dsmfg.com/>
Of PaulS
Sent: Friday, March 26, 2010 1:28 PM
Subject: [Vantage] MRP not showing demand / Creating jobs for
sub-assemblies
All,
Parent
Child 1
Child 2
Scenario:
manufactured parts.
part.
Paul
As far as I can see all involved parts are set up correctly. Running MRP generates demand for the top level part only. If there are purchased parts connected to the top level part they will show demand.
From the top level down MRP fails to generate demand. No demand for the sub-assemblies or their component parts.
We have only recently ventured into an engineering model that requires us to create BOM's with levels. Previously a MOM only had a top level and materials. So it is hard to say when this issue with MRP started. Being that we can generate demand at the top level without a problem has "hid" the issue possibly for years.
Epicor tech support has been looking at the problem a little bit over a week now. I am just hoping to hear from someone who has seen this behavior before and know how to fix it...
Thanks!
Paul
> to do there.
> Rob Bucek
> FAX: (715)284-4084
> Of PaulS
> sub-assemblies
> All,
> Parent
> Child 1
> Child 2
> Scenario:
> manufactured parts.
> part.
> Paul
Hi Paul,
"Pull As Assembly
Nancy Hoyt
> Thanks!
> Paul
> > to do there.
> > Rob Bucek
> > FAX: (715)284-4084
> > Of PaulS
> > sub-assemblies
> > All,
> > Parent
> > Child 1
> > Child 2
> > Scenario:
> > manufactured parts.
> > part.
> > Paul
TOP(D) - PP0(D)
- SUB1(D)
-PP1
-SUB2
-PP2
Paul
--- In vantage@yahoogroups.com, "Nancy" <nhoyt111@...> wrote:
> Hi Paul,
> "Pull As Assembly
> Thanks,
> Nancy Hoyt
> > Thanks!
> > Paul
> > > to do there.
> > > Rob Bucek
> > > FAX: (715)284-4084
> > > Of PaulS
> > > sub-assemblies
> > > All,
> > > Parent
> > > Child 1
> > > Child 2
> > > Scenario:
> > > manufactured parts.
> > > part.
> > > Paul
Rob
TOP(D) - PP0(D)
- SUB1(D)
-PP1
-SUB2
-PP2
Paul
> Hi Paul,
> "Pull As Assembly
> Thanks,
> Nancy Hoyt
