That is correct. You open the dashboard for there tracker in developer mode
export dashboard and BAQ's.. You would then import it back in and change the
BAQ names to your own. I will have to look at the files, but there is a link
to person that needs to be removed.
Steve
Sent: October 07, 2008 3:30 PM
Subject: RE: [Vantage] MRP on 803.404
Steve,
Are you saying that you re-imported a copy of the interface into
customizations and then made the changes?
If so, might you be willing to share this customization so that I may begin
to use the workbench properly?
Carey
To: vantage@yahoogroups <mailto:vantage%40yahoogroups.comFrom> .comFrom:
vantage@rmgfelm. <mailto:vantage%40rmgfelm.comDate> comDate: Tue, 7 Oct 2008
12:25:08 -0500Subject: RE: [Vantage] MRP on 803.404
They changed the system to require a planner, however they did not allow
youto put on in as a default for the company. The only parts that will show
upin the workbench are the ones that have a part class with a planner
linked.I exported the Epicor planner workbench and re imported it the
modified thelink to remove the planner from the person link to get around
this problem.I was told by Epicor that it works as
designed.Steve-----Original Message-----From: Carey S
[mailto:rotary1@hotmail. <mailto:rotary1%40hotmail.com> com]Sent: October
07, 2008 11:46 AMTo: vantage@yahoogroups
<mailto:vantage%40yahoogroups.comSubject> .comSubject: [Vantage] MRP on
803.404I know that there have been many bugs listed for 404.I am using MRP
to generate job suggestions for manufactured parts, and I cancheck the so
line releases and see the links to MRP jobs.However, these jobs are not
showing up in the planners workbench.I do not have any production planners
set up for any part class, but I thinksomething else must be wrong.Does
anyone have an idea what I might be overlooking here or are therespecific
bugs with 404 and the planning
workbench??ThanksCarey______________________________________________________
____See how Windows Mobile brings your life together-at home, work, or on
thego.http:/
<thego.http://clk.atdmt.com/MRT/go/msnnkwxp1020093182mrt/direct/01/>
/clk.atdmt.com/MRT/go/msnnkwxp1020093182mrt/direct/01/[Non-text portions of
this message have been removed]------------------------------------Useful
links for the Yahoo!Groups Vantage Board are: ( Note: You must havealready
linked your email address to a yahoo id to enable access. )(1) To access the
Files Section of our Yahoo!Group for Report Builder andCrystal Reports and
other 'goodies', please goto:http://groups.
yahoo.com/group/vantage/files/.(2) To search through old msg's
goto:http://groups. <http://groups.yahoo.com/group/vantage/messages>
yahoo.com/group/vantage/messages(3) To view links to Vendors that provide
Vantage services goto:http://groups.
<http://groups.yahoo.com/group/vantage/linksYahoo>
yahoo.com/group/vantage/linksYahoo! Groups Links
__________________________________________________________
See how Windows connects the people, information, and fun that are part of
your life.
http://clk.atdmt.
<http://clk.atdmt.com/MRT/go/msnnkwxp1020093175mrt/direct/01/>
Steve
Steve,
Carey
thego.http:/
your life.
http://clk.atdmt.
