MRP / Time Phase Question
I think my initial response to the question left the impression you can't customize Time Phase (as in adding FKVs) if you are running Progress.
You can (and we have) to provide additional Part/Plant info in the header section. An experimental customization (which I don't expect to release) also overwrites some unimportant column (to our process) info listed in the grid with pertinent info (to our process) from FKV tables when a row in the grid is selected via the mouse. However, it is not a permanent write over of the temp table data & a refresh clears it.
I suspect the behavior of time phase could be changed significantly via BPM - as BPM, unlike VB code customization, is able to manipulate temp tables that Vantage apps use 'behind the scenes' prior to making full commit writes to the db.
Rob Brown
--- On Fri, 6/20/08, Vic Drecchio <vic.drecchio@...> wrote:
Subject: RE: [Vantage] MRP / Time Phase Question
Date: Friday, June 20, 2008, 3:37 PM
If you're s SQL customer (sorry, didn't see it mentioned anywhere in the
message thread) you have more flexibility and may circumvent Progress.
Create some views and/or queries in SQL and report from that. I know
Epicor doesn't approve this method, but it would work.
____________ _________ _________ __
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf
Of Robert Brown
Sent: Friday, June 20, 2008 3:01 PM
To: vantage@yahoogroups .com
Subject: Re: [Vantage] MRP / Time Phase Question
Time Phase is a pure Progress report/app written in 4GL and using only
temporary tables.
You would need the full blown Progress development environment (and
source code) to copy from & then modify the copy to suit your needs.
Unfortunately, although BAQs are written in Progress language, BAQs only
suport a small subset of the language and not what is required to build
your own time phase from a BAQ. The biggest obstacle is no BAQ
calculated field support for calculating the row # of each record (so
the displayed order of supply demand after initial on-hand is correct).
The time phase o/h calc from row to row also exceeds BAQ calc field
language support.
Rob Brown
--- On Fri, 6/20/08, bdmang_83 <bdmang_83@yahoo. com
<mailto:bdmang_ 83%40yahoo. com> > wrote:
From: bdmang_83 <bdmang_83@yahoo. com <mailto:bdmang_ 83%40yahoo. com> >
Subject: [Vantage] MRP / Time Phase Question
To: vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com>
Date: Friday, June 20, 2008, 12:49 PM
Our planning department would like us to be able to display the child
part number for a unfirm job that is suggested by MRP when they do a
Time Phased inquiry on a Part.
Right now what they use Open With and go to job tracker to get that
information.
Any suggestions on how to do this would be great. I have called Epicor
and short of Custom Programming have not had any luck. If we could find
where the Time Phas Query is maybe we could edit it to return this
information.
Thanks in advance for any help,
Brian
information.
information.
Brian
What version?
I have a customization that does that for V8.00.811a and it also
works on newer versions
child
a
that
> information.
Epicor
find
> information.
> Brian
--- In vantage@yahoogroups.com, "bw2868bond" <bwalker@...> wrote:
> What version?
> child
do
> a
> that
> > information.
> Epicor
could
> find
this
> > information.
> > Brian
We are on 803.404 -
Right after I posted this I figured out a way to get this
information. I would love to see how you were doing this however.
What I did was make a Foreign Key and Sub Key view on the Time Phase
Form and then added a Group Box and a couple of Text Fields to show
the information they are looking for.
Have a great day!
Brian
Time Phase is a pure Progress report/app written in 4GL and using only temporary tables.
You would need the full blown Progress development environment (and source code) to copy from & then modify the copy to suit your needs.
Unfortunately, although BAQs are written in Progress language, BAQs only suport a small subset of the language and not what is required to build your own time phase from a BAQ. The biggest obstacle is no BAQ calculated field support for calculating the row # of each record (so the displayed order of supply demand after initial on-hand is correct). The time phase o/h calc from row to row also exceeds BAQ calc field language support.
Rob Brown
information.
information.
Brian
Of Robert Brown
temporary tables.
language support.
Rob Brown
<mailto:bdmang_83%40yahoo.com> > wrote:
From: bdmang_83 <bdmang_83@... <mailto:bdmang_83%40yahoo.com> >
information.
information.
Brian
Has anyone been able to recreate the Sales Tax report as a BAQ report?
We need to be able to break out freight charges when we file. Running
8.03.404B on Progress.
Jim
___
