MS Access and Merant 3.6 ODBC driver issues
Sorry. I use Access workgroups and the authorization error is what my
users report to me when they do not have access to the workgroup or
object. I'm assuming you are hitting the checkbox to save the password
otherwise Access would be prompting you for it from the ODBC driver. Is
it happening on just one machine or if it is happening on everyone's
computer? What version of Access are you using? Can you connect to the
database with another ODBC app to try an isolate if the problem is with
the ODBC driver, server or application?
Butch
Of ecfmis
Sent: Tuesday, October 04, 2005 10:26 AM
Subject: [Vantage] Re: MS Access and Merant 3.6 ODBC driver issues
I guess I am not being clear. The authorization fails with the
progress database, not the access one. Basically I can create an
access database, link the tables, and open them just fine. But once
I close the access database and come back in, the linked tables no
longer work. I then get the authorization error when trying to open
the linked tables. If I create a brand new access DB and link the
tables again it works. But only as long as I have it opened. Then
it breaks after I close it and come back in.
--- In vantage@yahoogroups.com, "Butch Menge" <bmenge@t...> wrote:
> The assumption is that your Access database is linked to the
Progress
> database so the data is always live. Access contains tables,
queries,
> forms, reports, etc. and that is what you are importing to a new
file.
> I don't believe you can import report builder reports. By
creating a
> new file, you are changing the owner of the objects - that is all -
> which may fix your authorization issue.
> Butch
Behalf
> Of ecfmis
> Sent: Tuesday, October 04, 2005 7:48 AM
> Thanks for responding, but wont this create a 2nd copy of the data
> so it will no longer be 'live' data that I am querying from? And
> how do you import reports from the report builder?
> thanks
> ecfmis
> > Create a new Access database and link the tables to vantage.
> Import in
> > all the other objects from the database you are having trouble
with
> > (queries, forms, reports, modules). When imported you will be
the
> owner
> > of the objects.
> > Butch
On
> Behalf
> > Of ecfmis
> > Sent: Wednesday, September 28, 2005 6:03 AM
> > Subject: [Vantage] MS Access and Merant 3.6 ODBC driver issues
> > I am trying to copy a report from the report writer into
Access.
> So I
> > link the tables in Access using the ODBC drivers. I use the
login
> of
> > the person who created the database. It will let me link the
> tables.
> > But as soon as I close the Access database and re-open them, it
no
> > longer works with the authorization failed message. Do I need
to
> > create a new user for the DB and transfer dba rights? Or will
> this
> > mess vantage up? I also tried to link a server in SQL but had
> > absolutely no luck with authorization failing everytime I tried.
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note:
You
> must
> > have already linked your email address to a yahoo id to enable
> access. )
> > (1) To access the Files Section of our Yahoo!Group for Report
> Builder
> > and Crystal Reports and other 'goodies', please goto:
> > http://groups.yahoo.com/group/vantage/files/.
> > http://groups.yahoo.com/group/vantage/messages
> > (3) To view links to Vendors that provide Vantage services goto:
> > http://groups.yahoo.com/group/vantage/links
> > YAHOO! GROUPS LINKS
> > * Visit your group "vantage
> > <http://groups.yahoo.com/group/vantage> " on the web.
> > * To unsubscribe from this group, send an email to:
> > vantage-unsubscribe@yahoogroups.com
> > <mailto:vantage-unsubscribe@yahoogroups.com?subject=Unsubscribe>
> > * Your use of Yahoo! Groups is subject to the Yahoo! Terms
of
> > Service <http://docs.yahoo.com/info/terms/> .
must
access. )
Builder
> YAHOO! GROUPS LINKS
> * Your use of Yahoo! Groups is subject to the Yahoo! Terms of
YAHOO! GROUPS LINKS
I am trying to copy a report from the report writer into Access. So I
link the tables in Access using the ODBC drivers. I use the login of
the person who created the database. It will let me link the tables.
But as soon as I close the Access database and re-open them, it no
longer works with the authorization failed message. Do I need to
create a new user for the DB and transfer dba rights? Or will this
On the dialog where you are picking the Vantage tables you want to link
there is a check box on the lower right corner labeled "Save
Password". Try clicking that box, that might solve your problem.
Brian Stenglein
Clow Stamping Co.
I
tables.
Create a new Access database and link the tables to vantage. Import in
all the other objects from the database you are having trouble with
(queries, forms, reports, modules). When imported you will be the owner
of the objects.
Butch
Of ecfmis
YAHOO! GROUPS LINKS
thanks
ecfmis
Import in
owner
> of the objects.
> Butch
Behalf
> Of ecfmis
So I
of
tables.
this
must
access. )
Builder
> YAHOO! GROUPS LINKS
The assumption is that your Access database is linked to the Progress
database so the data is always live. Access contains tables, queries,
forms, reports, etc. and that is what you are importing to a new file.
I don't believe you can import report builder reports. By creating a
Butch
Of ecfmis
thanks
ecfmis
Import in
owner
> of the objects.
> Butch
Behalf
> Of ecfmis
So I
of
tables.
this
must
access. )
Builder
> YAHOO! GROUPS LINKS
YAHOO! GROUPS LINKS
Hi,
Be aware if moving forward with 8.0 that a few of the tables in 8.0 have
more indexes out of the box than Access can handle (I think the limit is
30), so you may need to modify database to do this.
Geordie Dukas
CONCOA
> Butch
> Of ecfmis
> thanks
> ecfmis
> Import in
> owner
>>of the objects.
>>Butch
> Behalf
>>Of ecfmis
> So I
> of
> tables.
> this
> must
> access. )
> Builder
>>YAHOO! GROUPS LINKS
> YAHOO! GROUPS LINKS
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have already linked your email address to a yahoo id to enable access. )
> (1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.
> (2) To search through old msg's goto: http://groups.yahoo.com/group/vantage/messages
> (3) To view links to Vendors that provide Vantage services goto: http://groups.yahoo.com/group/vantage/links
> Yahoo! Groups Links
Progress
queries,
file.
creating a
> Butch
Behalf
> Of ecfmis
> thanks
> ecfmis
> Import in
with
the
> owner
> > of the objects.
> > Butch
On
> Behalf
> > Of ecfmis
Access.
> So I
login
> of
> tables.
no
to
> this
You
> must
> access. )
> Builder
> > YAHOO! GROUPS LINKS
of
must
access. )
Builder
> YAHOO! GROUPS LINKS
Hello,
Is anyone currently working with or testing RFID to work with Vantage? We are currently looking at ways we can better manage large, organic, dimensional inventory that resides outdoors.
Paul Krotts
J.H. Baxter & Company
Did you try checking the "Save Password" box when selecting the
tables you are linking like I mentioned after your initial question?
Its been a long time, but I swear I had the same issue when I first
got started with the new ODBC setup and I believe checking that box
took care of it. If not let me know and I'll start digging through
the dust bunnies in my memory.
Brian Stenglein
Clow Stamping
once
open
> Progress
> queries,
> file.
> creating a
all -
> > Butch
> Behalf
> > Of ecfmis
data
> > thanks
> > ecfmis
> > Import in
> with
> the
> > owner
> > > of the objects.
> > > Butch
> On
> > Behalf
> > > Of ecfmis
> Access.
> > So I
> login
> > of
> > tables.
> no
> to
> > this
tried.
> You
> > must
> > access. )
> > Builder
> > > YAHOO! GROUPS LINKS
> of
> must
> access. )
> Builder
> > YAHOO! GROUPS LINKS
I made a macro that links to Vantage Tables, create the tables needed
for reporting (you will know that not all fields are needed) and delete
the link tables again so no odbc connection is hanging all with 1 button
in a form. No user interference either since they only click on 1 button
to do it all. If you need help on this, email me directly and I will
help you.
Mario Aguirre
Lakin General Corporation, Inc.
Of Brian Stenglein
Sent: Tuesday, October 04, 2005 12:44 PM
Brian Stenglein
Clow Stamping
once
open
> Progress
> queries,
> file.
> creating a
all -
> > Butch
> Behalf
> > Of ecfmis
data
> > thanks
> > ecfmis
> > Import in
> with
> the
> > owner
> > > of the objects.
> > > Butch
> On
> > Behalf
> > > Of ecfmis
> Access.
> > So I
> login
> > of
> > tables.
> no
> to
> > this
tried.
> You
> > must
> > access. )
> > Builder
> > > YAHOO! GROUPS LINKS
> of
> must
> access. )
> Builder
> > YAHOO! GROUPS LINKS
YAHOO! GROUPS LINKS
