I am trying to pull a report that includes the mfgcomments field from
the part table. When I query that field from a BAQ, I get atleast a
portion of the results (Scrolls of screen). If I query it from Excel,
or Crystal, I get nothing from that field. If I use SQL explorer, I
get about 254 characters of the field.
I am not getting any error messages, which is what really confuses
me. I am familiar with the field length errors from trying to query
the change logs, but in this case, I am not getting any errors.
Also, I was unable to find the answerbook listed below. Has it been
removed?
Craig
removed?
Craig
--- In vantage@yahoogroups.com, "A Mercer Sisson" <onelist@...> wrote:
> Thanks, you are quote right. Once I realized that I adjusted the
SQL
> widths in the wrong database and corrected the proper one all worked
> as described in the answerbook article. Since we are not in
> production with 8.x yet I have several databases in different
> locations. My apologies for the confusion.
> Thanks for your help.
> Mercer Sisson
> --- In vantage@yahoogroups.com, "Ross Hughes" <ross.hughes@> wrote:
> > Yes, it is the SQL width function that needs adjusting.
> > It works fine when I adjusted it. It is all spelled out in the
> answer book
> > page.
> > Ross
> > -----Original Message-----
> > From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On
> Behalf Of
> > A Mercer Sisson
> > Sent: Thursday, August 21, 2008 1:41 PM
> > Subject: [Vantage] Re: MS Access Linked Table to PartOpr
> > You think the field width is too LOW?
> > All of the memo type fields have a width of 2000, which always
seems
> > to translate to a Memo field in Access. It is possible that I
have
> > more than 1000 characters in come of the comment fields, could
that be
> > the culprit?
> > I have adjusted the field widths using the dbtools tool as well
as the
> > data dictionary to no avail, but I did not increase any of the
widths.
> > I am guessing that this error message is a bit of a red herring
and
> > that the ODBC driver is passing an error code that the Jet Engine
does
> > not understand.
wrote:
> > > I have found two ways around this. One it to create a view with
> > only the
> > > fields you want (hopefully the field you want is not the
culprit).
> > > The second is to read answerbook page 7069MPS.
> > > It basically says that the error comes from the SQL width
setting
> in the
> > > Data Dictionary being set too low for long fields like Part
> Description,
> > > etc.
> > > You need to go to the server and start the data dictionary in
write
> > mode and
> > > adjust the width settings for the required fields. It is
spelled
> > out in the
> > > AB page.
> > > It seems to work well.
> > > Ross
On
> > Behalf Of
> > > Gary Parfrey
> > > Sent: Friday, August 15, 2008 8:45 AM
> > > Subject: RE: [Vantage] Re: MS Access Linked Table to PartOpr
> > > John
> > > Did you include all the fields in the view you created?
> > > Just try including a few fields? You may be able to find the
field in
> > > issue, probably a comments field?
> > > Gary
> > > Dot Net IT Limited, Reg No 4412519
> > > From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> > > [mailto:vantage@yahoogroups.com <mailto:vantage%
40yahoogroups.com>
> ] On
> > > Behalf
> > > Of John Atwood
> > > Sent: 15 August 2008 02:01
> > > To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> > > I have the same problem with the PartOpr table and have not
found a
> > > direct solution. I'm using a workaround by writing a BAQ from
the
> table
> > > with the fields I need. I then setup the BAQ export on a
recurring
> task
> > > and link MS Access to the .CSV file created from the BAQ.
> > > John Atwood
> > > Stellar Microelectronics
> > > --- In vantage@yahoogroups.com <mailto:vantage%
40yahoogroups.com>
> > > <mailto:vantage%40yahoogroups.com> ,
> > > "amsisson" <onelist@> wrote:
> > > > When I try to create a linked table in MS Access to the
PartOpr
> table
> > > > in Vantage 8.x I get a "field size is to large" but it does
not tell
> > > > me which field is too large. I have created a View with out
effect.
> > > > I can create a Passthru query, but that won't allow what I
need
> to do.
> > > > Any suggestions?
> > > > Mercer Sisson
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You
> must have
> > already linked your email address to a yahoo id to enable
access. )
> > (1) To access the Files Section of our Yahoo!Group for Report
> Builder and
> > Crystal Reports and other 'goodies', please goto:
> > http://groups.yahoo.com/group/vantage/files/.
> > http://groups.yahoo.com/group/vantage/messages
> > (3) To view links to Vendors that provide Vantage services goto:
> > http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
