This is a multi-co environment (5 active companies). Inter-co drop-ship is viable for all companies.
GO LIVE was Jan 2023… started working here 4-20
AP Open Load was processed 12-31 with entries resulting as POSTED (AP Invc Tracker)
in that a consultant managed the loading… unsure if AP OPEN LOAD or DMT was used?!
A particular inter-co supplier IC06 with activity to only 2 other companies 03 and 08
Attempt REMITANCE - appropriate Invoices are listed
EPICOR message ~ UNPOSTED INVOICES
REMITTANCE processing for all other inter-co relationships is NOT problematic
Ran a BAQ - dumped Inter-co Supplier data for all data-fields
Intercompany and Intercompany-trader set as TRUE ! !
Have yet to deep-dive into INVOICE’s …but that would be the next step, unless
additional insight (pun intended) can be garnered from the forum
THANSK in advance !
