I'm not sure I'm clear on what your objective is.
If you are trying to get a dashboard to report on multiple companies
AT THE SAME TIME, I don't think that is possible in Vantage.
But, if you are trying to get one dashboard to work in each of all of
your many companies, then that can definitely be done.
Pasted here are some instructions that another group member posted in
a message about 2 weeks ago:
1. Get the dashboard working exactly as you want it in Company A.
2. Remember the exact name you gave it in Company A.
3. Export the Dashboard with BAQs.
4. Go to Company B. Import Dashboard and BAQs. If you have system
BAQs, skip them since you can't overwrite them. The dashboard in
Company B will have BAQs with the Company B prefix.
5. Make sure you give the Dashboard the *exact same* name as you did
in Company A. Also make sure the description matches so you're not
confused.
6. Go to menu maintenance and link the dashboard where you want
it.
7. Now refresh your session. The dashboard should run as expected
in both companies.
If you find yourself reimporting because something got screwed up, be
sure to delete your custom BAQs before reimporting, as at least
in .405 it won't let you overwrite the BAQ on import.
These instructions worked for me. (Thanks bws!)
Lynn
--- In vantage@yahoogroups.com, "powersro" <bpowers@...> wrote:
> Hi, Newbie here. I'm trying to get a Multi-Company Dashboard to
work with a user BAQ. I got
> everything set up for Multi-Company and I can get a Multi-Company
Dashboard to work with
> one of the system BAQ's, but it doesn't get multi-company results
when I use a new BAQ. I
> even tried an exact copy of a system BAQ. Any suggestions as to
what I'm missing in this
> process. Thanks in advance.
> Bob
