This is the error getting. anyone have any suggestions
@Jonathan @Theodorus_Gumilang @Jonathan_Lang @5775 @Bart_Elia @hkeric.wci @JeffLeBert
10/11/2023 2:21:06 PM (Server:localhost PID:6968 DB:EPICORDB\ERP10Live Task:1624358) -------------------- Starting --------------------
10/11/2023 2:21:06 PM (Server:localhost PID:6968 DB:EPICORDB\ERP10Live Task:1624358) Multi-Company Process - Started Multi-Company Process
10/11/2023 2:21:09 PM (Server:localhost PID:6968 DB:EPICORDB\ERP10Live Task:1624358) Multi-Company Process - Started Outbound Queue Processor
10/11/2023 2:21:12 PM (Server:localhost PID:6968 DB:EPICORDB\ERP10Live Task:1624358) Multi-Company Process - Started Inbound Queue Processor
10/11/2023 2:21:15 PM (Server:localhost PID:6968 DB:EPICORDB\ERP10Live Task:1624358) Multi-Company Process - Stopping Multi-Company
10/11/2023 2:21:15 PM (Server:localhost PID:6968 DB:EPICORDB\ERP10Live Task:1624358) Multi-Company Process - Stopping Inbound Queue Processor
10/11/2023 2:21:15 PM (Server:localhost PID:6968 DB:EPICORDB\ERP10Live Task:1624358) Multi-Company Process - Error: System.InvalidOperationException: The transaction associated with the current connection has completed but has not been disposed. The transaction must be disposed before the connection can be used to execute SQL statements.
at System.Data.SqlClient.SqlInternalConnectionTds.CheckEnlistedTransactionBinding()
at System.Data.SqlClient.TdsParser.TdsExecuteSQLBatch(String text, Int32 timeout, SqlNotificationRequest notificationRequest, TdsParserStateObject stateObj, Boolean sync, Boolean callerHasConnectionLock, Byte[] enclavePackage)
at System.Data.SqlClient.SqlCommand.RunExecuteNonQueryTds(String methodName, Boolean async, Int32 timeout, Boolean asyncWrite)
at System.Data.SqlClient.SqlCommand.InternalExecuteNonQuery(TaskCompletionSource1 completion, String methodName, Boolean sendToPipe, Int32 timeout, Boolean& usedCache, Boolean asyncWrite, Boolean inRetry) at System.Data.SqlClient.SqlCommand.ExecuteNonQuery() at Ice.Services.ContextFactory.SetLockTimeout(DbConnection dbConnection) in C:\_Releases\ICE\ICE3.2.300.12\Source\Framework\Epicor.System\Services\ContextFactory.cs:line 209 at Ice.Services.ContextFactory.InitializeContext(IceDataContext dataContext) in C:\_Releases\ICE\ICE3.2.300.12\Source\Framework\Epicor.System\Services\ContextFactory.cs:line 173 at Ice.Services.ContextFactory.CreateDirect[TContext](SqlConnection sqlConnection) in C:\_Releases\ICE\ICE3.2.300.12\Source\Framework\Epicor.System\Services\ContextFactory.cs:line 153 at Ice.Triggers.Default.DeleteTrigger2.DeleteChangeLog(LinqRow recordToDelete) in c:_Releases\ICE\RL3.2.300.0\Source\Server\Db\Triggers\Default\Delete.cs:line 41
at Ice.Triggers.Default.DeleteTrigger2.Delete(TRec oldRecord) in c:\_Releases\ICE\RL3.2.300.0\Source\Server\Db\Triggers\Default\Delete.cs:line 14 at Ice.DataTrigger2.Ice.ILinqTrigger.Delete(LinqRow oldRecord) in C:_Releases\ICE\ICE3.2.300.12\Source\Framework\Epicor.Ice\Triggers\TriggerBase.cs:line 33
at Ice.Triggers.TriggerQueue.ExecuteDeleteTrigger(IceDataContext context, LinqRow originalRecord) in C:_Releases\ICE\ICE3.2.300.12\Source\Framework\Epicor.System\Triggers\TriggerQueue.cs:line 259
at Ice.Triggers.TriggerQueue.RunDeleteTrigger(IceDataContext context, LinqRow linqRow) in C:_Releases\ICE\ICE3.2.300.12\Source\Framework\Epicor.System\Triggers\TriggerQueue.cs:line 124
at Ice.IceDataContext.DeleteObject(Object entity) in C:_Releases\ICE\ICE3.2.300.12\Source\Framework\Epicor.System\Data\IceDataContext.cs:line 230
at Erp.Internal.SI.SIM130_Direct.RunSIM130_Direct(String ipCurrentCompany, Int64 instanceTaskNum, String outputFilename, String ipProcessName, String ipProcessDesc, Decimal ipProcessingDelay, Int32 ipLogLevel, String ipProcessingBranch, String ipProcessingBranchName, Boolean ipContinuous, String ipExtCompanyList) in C:_Releases\ERP\UD10.2.300.12\Source\Server\Internal\SI\SIM130\SIM130-Direct.cs:line 424
10/11/2023 2:21:15 PM (Server:localhost PID:6968 DB:EPICORDB\ERP10Live Task:1624358) Multi-Company Process - Error: Stack Trace
10/11/2023 2:21:15 PM (Server:localhost PID:6968 DB:EPICORDB\ERP10Live Task:1624358) Multi-Company Process - Stopping Outbound Queue Processor
10/11/2023 2:21:16 PM (Server:localhost PID:6968 DB:EPICORDB\ERP10Live Task:1624358) Multi-Company Process - Stopped
