Multi Level Pegging Report?
Norman,
I can help you here... I have a BAQ that will probably do what you
need and I use this in a dashboard to try and establish when job
materials will be complete. It saves me having to run the multi-level
pegging display for every job. But, you have to be a bit careful with
pegging data as I find that sometimes it doesn't quite give you the
results you expect! I suspect its down to PO / job dates going
overdue as the MRP engine seems to take exception to these, but I
have yet to examine this further. You can always play around with it
if it doesn't quite do what you want...
Shall I email it to you directly ( it will be Tuesday if thats
ok )...?
Nick
--- In vantage@yahoogroups.com, "Norman Hutchins" <nhutchins@...>
wrote:
> Anyone out there have a report, BAQ, or something that is based off
Multi
> Level Pegging? I'm trying to make a report or BAQ but I can't
figure out
> how that table work. I found 3 table PegLink, PegDmdMst, and
PegSupMst, but
> I can't get a data I'm looking for. Right now I'd be happy with a
report
> that just displays the same thing the Multi Level Pegging does...
> Anyone?
> Norman Hutchins
> Network Administrator
> Howell Laboratories, Inc.
Anyone out there have a report, BAQ, or something that is based off Multi
Level Pegging? I'm trying to make a report or BAQ but I can't figure out
how that table work. I found 3 table PegLink, PegDmdMst, and PegSupMst, but
I can't get a data I'm looking for. Right now I'd be happy with a report
Anyone?
Norman Hutchins
