Has anyone had issues running Multi-pegging in Epicor 10 specifically in the cloud environment?
Error:
Program Ice.Services.Lib.RunTask raised an unexpected exception with the following message: RunTask: The transaction has aborted.
Stack Trace:
_ at System.Transactions.TransactionStateAborted.CreateAbortingClone(InternalTransaction tx)_
_ at System.Transactions.DependentTransaction…ctor(IsolationLevel isoLevel, InternalTransaction internalTransaction, Boolean blocking)_
_ at System.Transactions.Transaction.DependentClone(DependentCloneOption cloneOption)_
_ at System.Transactions.TransactionScope.SetCurrent(Transaction newCurrent)_
_ at System.Transactions.TransactionScope.PushScope()_
_ at System.Transactions.TransactionScope…ctor(TransactionScopeOption scopeOption, TransactionOptions transactionOptions, TransactionScopeAsyncFlowOption asyncFlowOption)_
_ at Ice.IceDataContext.CreateDefaultTransactionScope(Nullable`1 requiresNew) in C:_Releases\ICE\ICE3.2.200.4\Source\Framework\Epicor.System\Data\IceDataContext.cs:line 172_
_ at Erp.Internal.MR.Pegging.createLink(Boolean fillDemand, Int32& pegSeq, PegSupMst& PegSupMst) in c:_Releases\ERP\RL10.2.200.0\Source\Server\Internal\MR\Pegging\Pegging.cs:line 1394_
_ at Erp.Internal.MR.Pegging.linkPart(String ip_Plant) in c:_Releases\ERP\RL10.2.200.0\Source\Server\Internal\MR\Pegging\Pegging.cs:line 1859_
_ at Erp.Internal.MR.Pegging.RunPegging(Int64 Instance_TaskNum) in c:_Releases\ERP\RL10.2.200.0\Source\Server\Internal\MR\Pegging\Pegging.cs:line 469_
_ at Ice.Hosting.TaskCaller.InnerExecuteTask(IceDataContext newContext) in C:_Releases\ICE\RL3.2.200.0\Source\Framework\Epicor.Ice\Hosting\TaskCaller\TaskCaller.cs:line 98_
_ at Ice.Hosting.TaskCaller.ExecuteTask() in C:_Releases\ICE\RL3.2.200.0\Source\Framework\Epicor.Ice\Hosting\TaskCaller\TaskCaller.cs:line 57_
_ at Ice.Lib.RunTask.BpmFriendlyTaskLauncher.Run(String sessionIdPrefix, IceContext db, Action taskRunner) in C:_Releases\ICE\RL3.2.200.0\Source\Server\Services\Lib\RunTask\BpmFriendlyTaskLauncher.cs:line 63_
_ at Ice.Services.Lib.RunTaskSvc.InnerRunTask(Int64 ipTaskNum, Boolean suppressTransaction) in C:_Releases\ICE\RL3.2.200.0\Source\Server\Services\Lib\RunTask\RunTask.cs:line 547_
Inner Exception:
Transaction Timeout
Stack Trace:
