Hi all.
I’m wondering if it’s possible to filter based on a multiple selection e.g
Two textboxes or dropdown menu FROM: “A” to “Z” and it fills the data in between in a criteria for SalesRepCode e.g B,C,D,E,F
Is that possible?
Aaron.
Hi all.
Is that possible?
Aaron.
For the BAQ, you can use the BETWEEN option I believe. If not, you can use > and <… This won’t be simple as a dashboard filter.
You can also try using parameters.
