Thanks to all for the advice, you have been very helpful. I think we
will plan on pushing back the cutover until we are ready to move
forward with both accounting & manufacturing, so that costing remains
straightforward and to avoid "unlinked data" and untidy account entries.
John Garner - Ken Garner Manufacturing, Inc.
--- In vantage@yahoogroups.com, "Mark Wonsil" <mark_wonsil@...> wrote:
> > Last year we implemented from legacy systems (a lightweight MRP
system and
> > a low end financial system) to 8.03.403. Any conversion is a daunting
> > task, so we considered implementing a module at a time. The problem is
> > there is so much integration between modules that you end up with
a bunch
> > of unlinked data. While it can be done, and we had a plan to do
it, Epicor
> > and most folks on this exchange recommended an all at once
implementation.
> > That was the course we ultimately chose, and I am pleased we did.
We had
> > one weekend of pain (I had to miss my favorite team's football
game on TV
> > which was a major loss for me), but then it was mostly done. I
think I got
> > good advice, primarily because of the data integration issues.
> I completely agree with Thom. You'll really have a difficult time
"cleaning
> up" the messes that would have been avoided had you went the whole
route at
> once.
> What you may want to consider is doing a separate financial
implementation
> in a test environment to get the accountants up to the same level as the
> rest of the company. We did a "Progressive Implementation" in a test
> environment where we started with an empty database and backed it up. We
> added the account numbers and the financial reports - then backed it
up. We
> kept adding elements and if we made an irrecoverable error, we would
restore
> the database to the previous step. It worked well in the early
stages but
> can get hairy as more folks are in there. However, your financials are
> common to all areas and I would make sure that works before floating
out the
> rest of your business.
> Mark W.
